It's not as simple as that, I made sure the insurance company knew that some things couldn't be tested - for example my two network switches. I had no way to test them without anything here to use so they went on the list. When I was able to get some equipment here to test I discovered that all the ports on one were blown and three out of five on the second had popped.
I knew my ADSL modem had gone so I replaced that yesterday and since then it appears that my Time Capsule may not be working as it should as it can't keep the Internet up. It all looks OK and the wireless works but although the green light is on and I can connect to it, the Internet keeps dropping out. It's either the new ADSL model or the Time Capsule and I know which one is most likely to be broken. I'm going to replace all my network cables as a matter of course and although not expensive, they weren't part of the claim.
Nothing will be sold, even if stuff appears to work I simply can't guarantee it so the comment I made before about stuff being disposed of is genuine.
Although I'll end up with a bunch of new shiny stuff, I will almost certainly be out of pocket at the end of this.
