New PC - bit out of touch
8 Nov 2003
UK
Hi Guys,
I am wanting a new PC but haven't really been interested in the latest tech since nearly 10 years ago when I built my own PC so have lost touch of what's what!
I built a PC which had a Asus P4C800-E Deluxe (I think) with an Intel Prescott 2.8Ghz overclocked to 3.2Ghz with 512Mb of RAM.
I upgraded about a year ago and bought a PC from a mate for £50. It's very small and has no space for additional hard drives or anything because it's built to house only what it was sold with. It has no extra power cables!
It's a Packard Bell iMedia something or other with Intel Core2 1.86Ghz and 2GB of RAM.
It's time for something new...
I am thinking of going AMD as it's generally cheaper. I was thinking going for the AMD Phenom II X6 Six Core 1100T Black Edition 3.30GHz (Socket AM3) with about 8GB of RAM (memory is so cheap now, I can't believe it!!).
I am aware there will be a new AMD processor coming out at some point so would like to get a new AM3+ mobo (which correct me if I'm wrong will work with the above CPU) so if I want I can upgrade easily.
I want a decent graphics card, preferably don't want to spend more than £200 on one. I am told you can combine two together now?
I've got plenty of hard drives, sata an regular ones. I would need a new case, power supply and whatever else I may have forgotten.
PC will be used mainly for browsing, E-mail, MS Office apps, programming - C#, SQL, VBA, etc. I distro hop quite a bit (Linux) and use Windows 7. And potentially the odd game, I stopped gaming on my old PC because it couldn't handle the newer games that were coming out, for example Doom 3. So may well do a bit of gaming, like I said I don't want to limit myself. If I get an decentish graphics card and do decide to game I would consider adding a 2nd gfx card - maybe.
Budget around £700. Case needs to be big, don't want to limit what can be installed by getting a small one.
Not overly interested in overclocking, if it can be achieved easily without adding a million fans or going watercooling I would be interested.
Your help would be very much appreciated.
PC with everything apart from a HDD for a touch under £700. The motherboard/power supply/case could all handle a 2nd graphics card if required for a later upgrade.
The reason I suggest Intel over AMD is that the performance of the Intel chip beats the AMD hex core (in most applications) and there's still nothing to show if the next generation AMD chips will be better value for money than the current generation Intel (plus you won't have the hassle of reselling the Phenom X6).
Asus GeForce GTX 560Ti DirectCU II 1024MB GDDR5 PCI-Express Graphics Card £173.99
(£144.99) £173.99
(£144.99)
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £161.99
(£134.99) £161.99
(£134.99)
Asrock Z68 Extreme4 Intel Z68 (Socket 1155) DDR3 Motherboard £144.98
(£120.82) £144.98
(£120.82)
Antec TruePower New Modular 750W '80 Plus Bronze' Power Supply ** FREE 3D Mark 2011 Advanced ** £84.98
(£70.82) £84.98
(£70.82)
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £49.99
(£41.66) £49.99
(£41.66)
BitFenix Shinobi Gaming Case - Black £46.98
(£39.15) £46.98
(£39.15)
Samsung SH-S222AB/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £16.99
(£14.16) £16.99
(£14.16)
Sub Total : £566.59
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.75
VAT is being charged at 20.00% VAT : £115.67
Total : £694.01
Thanks very much, Redmint. You must have spent quite some time doing that for me. :)
How many cores do these i5 & i7's have? I've just seen that they have built-in graphics so I could do away with the GFX card and replace the i5 with the i7?
The 2500K/2600K both have 4 physical cores but the 2600K has hyper-threading for 4 extra virtual cores.
if you want to do any sort of gaming then you cannot use the onboard. i honestly wouldnt be surprised if the onboard graphics were worse than the graphics card you have now
Yeah agree with this, if you want to do any kind of gaming then you'll need a dedicated card. Onboard is basically only designed for videos and very basic/old games.
(£144.99) £173.99
(£144.99)
(£134.99) £161.99
(£134.99)
(£120.82) £144.98
(£120.82)
(£70.82) £84.98
(£70.82)
(£41.66) £49.99
(£41.66)
(£39.15) £46.98
(£39.15)
(£14.16) £16.99
(£14.16)
Sub Total : £566.59
DPD Next Day Parcel
Total : £694.01
This is a good build that will keep you going for anything from a couple right up to 4 years.
Some issues :
No storage / SSD - If you've ever loaded visual studio or kicked off a compilation from SSD then you'll eyes will pop out of your head >>> Tis FAST :eek:
BTW Are you based in Enfield or is that actually your name :)
Thanks guys, like I said I'm not especially interested in gaming so am tempted to leave the GFX card for now. I can always buy one after my next pay day.
SSD, I know absolutely zero about these...
No, not based in Enfield, just a name I chose yonks ago. I'm in Hampshire not far from Redmint actually.
Edit: Reference the Asrock mobo - I've not heard of the manufacturer - are they reliable? I'm under the impression that the mobo is the most important part.
Not sure sure about SSD. I don't like the sound of it degrading in performance.
If I were to get the i5 2500k, would it overclock to 4ghz easy with that RAM? Also what CPU cooler to get?
The G.Skill RipJawsX 4GB (2x2GB) DDR3 PC3-12800C7 1600MHz Dual Channel Kit (F3-12800CL7D-4GBXM) has lower timings than the Kingston and is same price...
This is what's currently sat in my basket. Anything there to change?
Krypton Z68 600i Intel Core i5 2500K 3.30GHz @ 4.60GHz Overclocked Bundle £235.21
(£196.01) £235.21
(£196.01)
Options applied to the above product:
(£41.66) £49.99
(£41.66)
Asus P8Z68-V Intel Z68 (Socket 1155) DDR3 Motherboard £129.98
(£108.32) £129.98
(£108.32)
(£144.99) £173.99
(£144.99)
(£70.82) £84.98
(£70.82)
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) £66.98
(£55.82) £66.98
(£55.82)
(£39.15) £46.98
(£39.15)
Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST3500413AS) £30.98
(£25.82) £61.96
(£51.64)
(£14.16) £16.99
(£14.16)
Fractal Design 140mm Silent Cooling Fan £12.24
(£10.20) £12.24
(£10.20)
Lian Li PT-AF14B 140mm Washable Air Filter - Black £4.07
(£3.39) £4.07
(£3.39)
OcUK Professional 2 Meter HDMI Cable - Gold Plated £3.98
(£3.32) £3.98
(£3.32)
Akasa "Y" Power Splitter £1.99
(£1.66) £3.98
(£3.32)
Sub Total : £742.80
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £13.75
VAT is being charged at 20.00% VAT : £151.31
Total : £907.86
Degrading will take a long, long, long time on modern drives.
(£196.01) £235.21
(£196.01)
(£41.66) £49.99
(£41.66)
(£108.32) £129.98
(£108.32)
(£144.99) £173.99
(£144.99)
(£70.82) £84.98
(£70.82)
(£55.82) £66.98
(£55.82)
(£39.15) £46.98
(£39.15)
(£25.82) £61.96
(£51.64)
(£14.16) £16.99
(£14.16)
(£10.20) £12.24
(£10.20)
(£3.39) £4.07
(£3.39)
(£3.32) £3.98
(£3.32)
(£1.66) £3.98
(£3.32)
Sub Total : £742.80
DPD Next Day Parcel
Total : £907.86
Looks good. :)
