24GB ram - Sandybridge 3.4 - GTX580...
i hate to say this, but that motherboard is the biggest rip off ive ever seen (not OcUK's fault, its gigabytes fault). there are precisely no differences between that one and the one that i recommended that was £55 cheaper
also, if you look in the cases section you will see that the quality control department for the fractal XL case is a toddler group. i have seen 5 seperate threads complaining about them, and i hardly ever go in the cases section
Good points. I didn't delve into the motherboard specs too much, I just took it as red that the Gigabyte would be better, but you're spot on!
Never had a fractal design, I just like the sleek look on the outside and the practicality inside.
