PNY GTX 580
2 Oct 2004
Hi guys just a quick one.
Wanting an upgrade from my HD5770, feeling rash and spending a fair wedge on a 580.
I can only find one review of the PNY flavour one, and it is ~50 quid cheaper (week only deal) than the ASUS DirectCUII which I have heard good things about. Any reason not to go for the PNY that anyone knows of?
Also would my 700w OCZ PSU be ample if I got a 580 and then ramped up my 2500K clock a bit?
The only reason against te PNY would be that the CS isn't great. However thats all handled by overclockers so you will be fine.
700w would be pushing it a bit too miuch. I would upgrade.
Well I definately think I'm gonna order the PNY tomorrow.
I am however doubting my PSU capabilities, all I seem to find is conflicting information on whether this http://www.ocztechnology.com/resources/drivers/GameXstream_700W_chart.jpg is ok to run an i5 2500k, GTX580 and the standard other crap.
I did have an Antec 650w truepower new (after thinking my OCZ had blown up, turns out that was my CPU instead) but that failed within 6 months and got returned. Just whacked the OCZ back in and its fine, had it since May 07... If it wasnt good enough would I'm assuming I would just experience some crashes?
Thanks guys, just ordered now :) Luckily I remembered to get a 6 pin to 8 pin PCI-E adaptor or I'd have felt silly
Dealt with them two years ago and wasn't inpressed. Maybe they've improved
:confused:
A 700watt PSU will be perfectly fine for a single GTX 580 and overclocked 2500k cpu..
Agreed im running 650w
Yeah, I fail. Just read OP again. For some reason I thought he had a direct CU 580 and was getting another one *facepalm*
