http://www.anandtech.com/bench/Product/292?vs=305
6970 vs 580. Both top end cards for both manufacturers, the 580 has the edge in some tests, and in others it dominates.
And read what i posted again.
http://www.anandtech.com/bench/Product/298?vs=308
Even for a dual card setup, the 580 beats AMD in a lot of the tests.
http://www.hardwareheaven.com/revie...tx-590-oc-vs-radeon-6990-oc-introduction.html
They are pretty much level with each other.
Phenom II is so useless I can't even use it for toilet paper...
^This to be honest.Core i5 2500k and MSI P67A-GD53.
Job done.![]()
BFBC2 loves 6 cores & will scale to 8.
Also Dirt 3 loves the AMD Hex core as well.
http://www.techspot.com/review/403-dirt-3-performance/page7.html
Poor choice of benchmark to promote the AMD hex core TBH.
Phenom 1100T X6 3.3 GHz slightly slower than the i5 750 2.66GHz (quad core).Also it's one of the few benchmarks where the new i5 is slower than the old i5 for some unknown reason.
This one without a doubt.
http://www.overclockers.co.uk/showproduct.php?prodid=CP-266-AM&tool=3
Looking at what everyone is saying,from the die hard intel guys and the die hard amd guys it comes down to you and the choice that you make. Each CPU is good in there own way, i have used both Intel and AMD, and unless your pushing your system to the max it all comes down to personal choice and also the other components you use with the CPU. That is what makes a good system.
Just no,
Why would someone (who is looking to upgrade both the CPU and motherboard) choose the slower, more power hungry and equivilantly priced Phenom X6 over the i5 2500k / P67A-GD53 combo?
The only reason I can see to choose the Phenom is if you already have a decent AM3 board and are looking for a a reasonably cheap upgrade.
It was not to promote the Phenom 1100T X6 as faster than Intel but to show that there are games that benefit from 6 cores & that context is clear as day when you look at the comment it was in reply too.
And seeing as they didn't have an Intel hex in the benches that just leaves the PhenomII 1100T X6 as proof when compared to the PhenomII x4.
What is the 1100T's turbo?
That benchmark doesn't prove it uses 6 threads.
Another fun fact: Dirt 3 seems to prefer hexa-core processors over their quad-core counterparts as the higher clocked Phenom II X4 980 performed worse than the Phenom II X6 1100T.
