Spec me underwater.. Just out of curiosity
22 May 2011
Edinburgh
Hey all,
I was considering the other day about the distant upgrade path of my PC and I would really like to water-cool it.
So I was wondering if all you expert peers could spec me a WC set-up (as is done with general components in other sections of the forum)
Case is a CM 690 II
I would need cooled:
i5 2500K
2x GTX 560ti
Probably 2x240mm Rads
I'd prefer it to contain a dual bay res.
Naturally you all know the best equipment for a setup, I do not as I am a WC nub.
(If i have missed any vital information out please feel free to tell me!)
CPU block: £50 EK nickel olexi easy mount
Radiators: £130 ( two sr1 240's)
GPU block £140 two blocks
Pimp £60 Laing DDC
red £46 EK dual bay res
£40 for other stuff like fluid and fittings.
Total £460
You can knock £70 off by getting a single 580. There aren't that many blocks for the 560s but if you are happy with nickel acetal then it's fine. I've soecced the higher end parts but I think it would be a worthwhile investment.
Pimp £60 Laing DDC
Total £460
Pimps for £60 :) SWEET!
