Most tiptronic-style boxes will do as expected as long as you don't hit the limiter (and so they shift up).I thought it was just because the gearboxes weren't doing as they were told?
Well there's all sorts of other vehicle-specific reasons that could cause wrong reads, but that's just unfortunate. If you are hitting the speed limiter you can try using a lower gear, but then when you have something like an E55 you are probably not going to be able to prevent wheelspin without making the rollers very sticky indeed.Yeah, I wasn't aware the dyno produced inaccurate readings in that case! I can't remember the outcome of all the runs I've seen with tiptronic boxes, I just remember TomO's Mercedes not giving full power because it was reaching the speed limiter![]()
Mac,
If you still have issues I can clear all your faults via The INPA stuff I am now offering as a sideline, it's really easy to do and I its just fault clearing and you drive to me - it's free
I had 11 seperate fault codes after my RR![]()
Ensure to watch in HD![]()
That's normal![]()
Link to thread? Specs?You must have![]()
Who's was the yellow Cooper?
Just looking at the Porsche graph, does it really have that flatspot around 5200rpm or did it just slip on the rollers a bit or something?
I would say you can feel the dip, only because you feel a kick just afterwards, not because you feel a noticable dip in power.
