Titan Fenrir Evo CPU Cooler Alternatives?
18 Jun 2011
I think the fenrir may be too big for my Bitfenix Shinobi as I heard it was a really big cooler. I ordered the sandybridge i5 and I need a cooler but I'm really not sure what to go for.
Suggestions?
bitfenix.com said:
Q: What is the maximum clearance for CPU coolers on Shinobi and Shinobi Window?
Shinobi Window maximum CPU cooler height = 159.5mm
Shinobi maximum CPU cooler height = 161.5mm
source
titan-cd.com said:
Outline Dimension: 124 x 107 x 160 mm
source
so, it looks like if you have the windowed case it will be a very tight squeeze, but if you have the ordinary case it will fit just fine.
if your worried about it then go for the Zalman CNPS9900MAX blue LED or Red LED. i guarantee they will fit in your case with room to spare
I have the ordinary case so I will go for the fenrir.
UNLESS there is an alternative around £35 that is better. The other ones are a little over budget, I know it's only a tiny bit but I'm over budget as it is :D
