Are you struggling in games with your current setup?
well i got a bfg gtx 285 OUCU, im thinking on getting a gtx 460/GTX 560ti or GTX 570 but leaning more towards a 460 to tie me more until the 28nm come out as the GTX 460 im looking at is just little over £100
but at least they may be down to around £200 by then.well i got a bfg gtx 285 OUCU, im thinking on getting a gtx 460/GTX 560ti or GTX 570 but leaning more towards a 460 to tie me more until the 28nm come out as the GTX 460 im looking at is just little over £100
Witcher 2 and Crysis 2 maxed bring it down to the low 40's to low 50s FPS.
I'm just thinking about the future. Like Skyrim, SWTOR and other PC titles.
PS. Did think about SLI with the HAWK (especially at the price they are) but I suspect there would be heat issues with the cards dumping most of the heat in the case.
from what i under stand is that the MSI GeForce GTX 460 HAWK "Super-OC" being a non rev design that msi had solve the heating and some of the power hungry issues that were present in the 4xx series rev cards.
Those frame rate is fine, and for Witcher 2 I would recommend NOT enable UberSampling, as that graphic options kill frame rate by 55-60%. While it make the graphic looks a bit "different" than with it not enabled, it does NOT make it look "better" in anyway.Witcher 2 and Crysis 2 maxed bring it down to the low 40's to low 50s FPS.
Most would happily do 850MHz plus on the core clock.
Also, no single GPU card on this gen is fast enough to worth "downgrading" from your GTX460 SLI. Also, if you have not overclocked your GTX460s, you are wasting themMost would happily do 850MHz plus on the core clock.
