Is 500w enough for this spec?
18 Jul 2011
XFX ATI Radeon HD 5770 Single Slot 1024MB GDDR5 PCI-Express Graphics Card with Stalker & AVP Games
AMD Athlon II X3 Tri Core 450 3.20GHz (Socket AM3) - Retail
Gigabyte GA-MA78LMT-US2H 760G (Socket AM3) DDR3 Motherboard
OCUK EZCool NA-705 Case - Black (500w PSU)
OcUK Value 5.1 PCI Sound Card
Akasa AK-FN051 80mm Smart Fan (Blue)
These are parts I'm taking from my old computer:
2GB RAM
Basic optical drive
320GB hard drive
So will the 500w PSU provided with the case be enough to run this spec?
Thanks in advance,
Billy
You will need some adapters:
The 5770 needs a PCI-E 6pin plug which the PSU doesn't have. So you'll need a molex to PCI-E adapter
The PSU only has 1 SATA adapter. So you'll need some Molex to SATA adapters for your optical drive / HDDs.
The PSU in the bundle which Stulid suggested has all cables needed.
500W is enough, but I'd strongly advise a better quality PSU.
Even the Corsair CX430, whilst not an amazing unit, has enough power for that spec and is better than the OcUK value unit or the Elite Power 500W.
Should be, as its all low power stuff, but the most important part of a PC is its PSU so try and get a better quality unit.
Can you afford this case+PSU bundle - http://www.overclockers.co.uk/showproduct.php?prodid=CA-225-CM&groupid=701&catid=7&subcat=29
Thanks! The problem is that I have a limit of £250 for the whole system.
At the moment the cost is £245 incl. Shipping and VAT
Is there any of the parts I have selected that could be cut back to make them cheaper while still getting good quality?
Thanks for the MoBo but the stuff is still over £250 (£274)
Are fans for the case really that "necessary"? And are there any other parts I could cut back on?
I get £265
Your basketProduct Name Qty Price Line Total
XFX ATI Radeon HD 5770 Single Slot 1024MB GDDR5 PCI-Express Graphics Card with Stalker & AVP Games £77.99
(£64.99) £77.99
(£64.99)
Cooler Master Elite 430 Windowed Case - Black (with 500w Elite Power PSU) £64.99
(£54.16) £64.99
(£54.16)
AMD Athlon II X3 Tri Core 450 3.20GHz (Socket AM3) - Retail £59.99
(£49.99) £59.99
(£49.99)
MSI 870-C45 AMD 770 Chipset (Socket AM3) DDR3 Motherboard £45.98
(£38.32) £45.98
(£38.32)
Antec Tri-Cool 3-Speed 120mm Fan - Black £1.99
(£1.66) £1.99
(£1.66)
Sub Total : £209.12
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.75
VAT is being charged at 20.00% VAT : £44.17
Total : £265.04
(£64.99) £77.99
(£64.99)
(£54.16) £64.99
(£54.16)
(£49.99) £59.99
(£49.99)
Gigabyte GA-M68MT-S2 (AM3) Motherboard - Retail £36.00
(£30.00) £36.00
(£30.00)
(£1.66) £1.99
(£1.66)
Sub Total : £200.80
DPD Next Day Parcel
VAT is being charged at 20.00% VAT : £42.51
Total : £255.06
But this motherboard doesnt support 125W processors, so any upgrades will mean you can only fit a 95W CPU maximum into it.
The MSI board does support all CPU's.
Thanks for all the replies. I'll go with that final build with the MoBo that only supports 95W CPUs. If I ever upgrade, the chances are I'll upgrade the MoBo aswell. (Either that or I'll just save up some more pocket money!)
Thank you for your help and support stulid.
One last question. Is the CPU I'm getting 95W?
Thank you,
Billy
