Asus P8 Z68 Deluxe advice please.
I dont think you should worry about it, you will always find more people posting there issues with a piece of equipment than the people who have zero issues.
Thanks, you just restored my faith. The asus it is then :-)
the only thing i get is when you auto clock @4.6 and when you retart the pc it goe's through a start,shutdown then restart phase.
asus spokesman said this normal if overclocking is done it is down to internal pll overvoltage.
the pLL option is needed to boost the performance under overclocking
apart from that everything is great so far am happy with it
But not everyone gets this so not sure about being normal.
Had my board for about a week. Mild OC to 4.3 and no problems. I did disable internal pll overvoltage in the bios to stop the double booting issue. I think it only needs to be enabled at much higher OC. 4.3 is fine for my needs so not an issue.
