Well tell me, all the reviews you've seen for the 4870x2 .... any recently?
My comment has nothing to do with reviews.
I was commenting on on the FPS figures you gave which indicated more than 100% scaling which is impossible.
Hang on. My 4870 supports Dx11.
So why won't his?
What makes you believe your card supports DX11? (genuine question, not trolling). The 4870 supports up to DX10.1, but the 5000-series were the first ATI cards that supported DX11.
Aye, you have. That's just the version of DX that Windows 7 usesIt was this that gave me the idea it was....or have I got the wrong end of the stick?
especially when a PSU is most efficient at around 60% load.
That's probably not the case any more.
Look at this review for example.
http://www.kitguru.net/components/power-supplies/zardon/corsair-ax750-power-supply-review/4/
Check the efficiency score a bit down the page.
92% between 360-450W.
That back ups nearly exactly what I said!! lol
Its maxmimum reading of
Which is surprisingly around 60% of its rated wattage.
