- 18 Oct 2002
- North
As title... should I return it? I dont find laptop too hot to touch and seems cooler than any laptop Ive had before (sat gaming on my knee's)... its just Coretemp reporting these temps.
The Core temp is on while playing - soon as I exit I can see the temp.... you trying to be smart![]()
Yes its a high spec laptop in a very small case... One that im mighty impressed with so far.
I just expected lower... All my self buit PCs idle at about 30degs and hardly ever go above 50 degs. Its at 45 degs now just surfing at 800Mhz, silent with no fan on and feels only a bit walm to touch.
can't compare desktop to laptop
You're comparing a self-built, well-ventilated desktop... and a laptop for temps?
*Looks at Vegetarians join date and number of posts*![]()
I admit Im not blessed with same intellegence and insite as you
All I wanted to know if this temp was normal for for a 2011 laptop as Ive been out of the moble scene for a bit.
area512003 - Case is not that hot and only real bit of warmth comes out of the back vent...(which is directed upwards by the LCD screen.
