- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
I cracked the whip and got the king of overclocking to bench the shiny new H100 sample from Corsair. The results were quite good.
The biggest shock is that the fans are much better than the H80 fans meaning the results are better than expected. This is the quiestest closed CPU loop we have used so far. We used the stock thermal gunk, no 3rd party aftermarket paste was used. This was all tested in an Antec 1200 case.
What really stands out is the fact that Rjkoneill normally doesn't like the closed retail kits as he is a massive fan of "proper" custom watercooling loops, but he is quite happy with the performance of this and would be willing to use it in his system.
Well a screen shot says a million words. 5GHz on a 2500k with fans on medium settings and it doesn't go above 77 degrees.
The stock will be arriving next week, so get your orders in now!
Corsair Hydro H100 Extreme Performance Liquid CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3) @ £94.99 inc VAT
Featuring a full 240mm radiator and two performance matched 120mm fans, the Corsair Hydro Series H100 extreme performance liquid CPU cooler is designed to deliver cooling performance that meets the needs of even the most demanding performance enthusiast.
The H100 fully supports Corsair Link Digital connections, so you can be in complete control of your cooling. Monitor a wide range of parameters, including pump speed, coolant temperature, and fan speed, and customize your own performance profiles*. (*Requires the Corsair Link Commander, sold separately). The low-profile integrated pump and cold plate includes push-button control so you can select the fan speed and cooling performance setup that best suits your needs. The cool blue LED display lets you know at a glance which profile is being used.
- Dual length 240mm radiator for increased surface area and cooling potential.
- Corsair Link™ Digital compatibility means that you can be in complete control of your cooling.
- Push-button fan control so you can select the fan speed and cooling performance that best suits your needs.
- Two all-new 120mm fans optimize static pressure and airflow for amazing performance.
- FEP tubing provides extraordinarily low coolant evaporation levels.
- A new improved micro-channel cold-plate design more efficiently transfers heat.
- Quick and easy installation brackets make it easier than ever to upgrade to watercooling.
- Includes mounting hardware compatible with all modern CPU socket designs
- Radiation Dimensions: 120mm x 275mm x 27mm
- Fan Dimensions: 120mm x 25mm
- Air Flow per Fan: 46 - 92 CFM
- Combined Fans Noise Level: 25 - 42 dBA
Only £94.99 inc VAT.
ORDER NOW
ORDER NOW
