We have dropped our CCTV prices in a push for home safety. If you have expensive items in and around your house spending a small amount of money compared could save a lot of trouble. Perfect for over looking cars.
Storage Options CCTV 2TB DVR 2+2 Cams @ £327.98 inc VAT
A 4 channel digital video recorder with pre-installed hard disk drive, designed to be used with the
Storage Options CCTV Range. Records in H.264, the latest compression technology, which gives
improved image quality and a longer recording time. Remote viewing is available as standard across your network or through the mobile phone/tablet application. Just add cameras for a complete security
solution.
Storage Options offers a range of affordable CCTV Solutions for home or small business security. With a range of cameras, digital video recorders and other accessories, our aim is to offer high-quality products and service without the premium price.
- 2TB hard disk drive installed
- Real time Viewing/Recording of up to 4 CCTV Cameras
- Easy Setup and Operation, Simple User Interface
- H.264 Compression Technology Provides Higher Quality and Longer Recording Times
- Simultaneous Viewing, Recording, Playback, Backup and Network Operation
- Android TM and Apple® Applications for Mobile Devices Available
- Compatible with Most Modern CCTV Cameras
Package Contents
1x Storage Options Digital Video Recorder
2x Storage Options Indoor CCTV Camera
2x Storage Options Outdoor CCTV Camera
Motion Detection
The Storage Options CCTV system has built in, sophisticated software that can detect movement. If your camera spots movement it can trigger an event to record this to your hard drive, giving you peace of mind that your home or office is constantly being monitored & protected. Most users however will set it to record continuously, this feature is mostly used to save disk space as well as only record when movement is detected.
Flexibility…
The Storage Options CCTV Camera range is designed to appeal as many different customers as possible, with options for different capacity hard drives & types of camera available you can expand your surveillance or change the type of application (e.g indoor to outdoor) just by replacing or adding cameras.
e.g. – Customer purchases a 2 outdoor camera bundle for watching the drive & front door, he then decides he would like to watch the rear garden & also his home office…. No problem, just buy one indoor , one outdoor camera & connect using the provided cables – Instant upgrade!
The User interface was designed with simplicity at its core, although it has many advanced functions. We wanted to ensure it was easy to set-up and get started, but also provides all the advanced features you could ever want should you need them. (e.g. Motion detection or privacy masking.)
Pentaplex
The Storage Options CCTV System is capable of performing multiple tasks at the same time, it can record, playback, live-view, back-up & network all simultaneously!! (Pentaplex) This ensures your property is still being protected regardless of what you are doing to the system, a great feature and one that ensures you never miss a thing.
Recording Time
The length of recording time is determined by 2 key factors, the size of the hard disk & number of cameras being used. Up to 400 days recording is possible. The device is smart too, it will alarm when the disk is full too. (this can then be re-formatted or removed for archive and a new drive fitted)
Time & Date Stamped Recordings
Time & Date stamped recordings show you exactly when an event occurred, a feature needed should the recordings be used in any criminal investigations. Recordings are stored in date order too so it makes searching for the footage you need even easier. The recordings are grouped into manageable sized chunks for easier copying or backing up
Back-up Facility
We recognise that at some point you will need quick access to footage stored on your DVR, and so to make it easier, we have included a handy USB port so you can plug in a USB Flash or Hard Disk Drive (HDD) and copy footage across to these devices – whether its just a short clip or a full back-up of your system should you wish to archive.
It’s as easy as selecting the Date range (from & to) and which cameras (one or even all)
Network
Although this is an analogue CCTV solution, it has a killer feature in that it is network enabled. This feature means that if you connect it to your network you can view your system live from anywhere in the world on any internet connected PC, no need to install software. (Viewed through the web browser)
Alternatively there are apps available for iPhone & Android for remote viewing also. You are never more than click away from viewing your home or business.
Was £349.99 Inc. VAT
Only £327.98 inc VAT.
ORDER NOW
Storage Options CCTV 1TB DVR 2 Cameras @ £222.98 inc VAT
solution.
- 1TB hard disk drive installed
Package Contents
Motion Detection
Flexibility…
Pentaplex
Recording Time
Back-up Facility
Network
Was £239.98 Inc. VAT
Only £222.98 inc VAT.
ORDER NOW
Storage Options CCTV 500GB DVR 2 Cameras @ £205.98 inc VAT
solution.
- 500GB hard disk drive installed
Package Contents
Was £219.98 Inc. VAT
Only £205.98 inc VAT.
ORDER NOW
Storage Options CCTV 500GB DVR 2+2 Cams @ £279.98 inc VAT
solution.
Package Contents
Motion Detection
Flexibility…
Pentaplex
Recording Time
Back-up Facility
Network
Was £299.99 Inc. VAT
Only £279.98 inc VAT.
ORDER NOW
Storage Options CCTV 500GB DVR 4 Cameras @ £269.98 inc VAT
solution.
Package Contents
4x Storage Options Outdoor CCTV Camera
Motion Detection
Flexibility…
Pentaplex
Recording Time
Back-up Facility
Network
Was £279.60 Inc. VAT
Only £269.98 inc VAT.
ORDER NOW
Storage Options CCTV 1TB DVR 4 Cameras @ £279.98 inc VAT
solution.
Package Contents
Motion Detection
Flexibility…
Pentaplex
Recording Time
Back-up Facility
Network
ORDER NOW
Storage Options CCTV 500GB DVR @ £168.98 inc VAT
solution.
-Simultaneous Viewing, Recording, Playback, Backup and Network Operation
Only £168.98 inc VAT.
ORDER NOW
Storage Options CCTV 1TB DVR @ £185.98 inc VAT
solution.
Only £185.98 inc VAT.
ORDER NOW
Storage Options CCTV 2TB DVR @ £219.98 inc VAT
solution.
Only £219.98 inc VAT.
ORDER NOW
solution.
Package Contents
Motion Detection
Flexibility…
Pentaplex
Recording Time
Back-up Facility
Network
ORDER NOW
solution.
Package Contents
Motion Detection
Flexibility…
Pentaplex
Recording Time
Back-up Facility
Network
ORDER NOW
solution.
Package Contents
ORDER NOW
solution.
Package Contents
Motion Detection
Flexibility…
Pentaplex
Recording Time
Back-up Facility
Network
ORDER NOW
solution.
Package Contents
Motion Detection
Flexibility…
Pentaplex
Recording Time
Back-up Facility
Network
ORDER NOW
solution.
Package Contents
Motion Detection
Flexibility…
Pentaplex
Recording Time
Back-up Facility
Network
ORDER NOW
solution.
ORDER NOW
solution.
ORDER NOW
solution.
ORDER NOW
