** MEMORY MEGA SALE AT OCUK UNTIL 4PM SATURDAY 30/07/2011 ** - GET YOUR WALLETS OUT!!!!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
I have an incredible trio of memory deals for you guys and the pricing is incredible, infact probably the lowest by far in the UK and it all Kingston with Lifetime Warranty:-
Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9AD3B1K2/4G) @ £25.99 inc VAT
Kingston® proudly introduces HyperX® blu, a new line of reliable memory ideal for the entry level gamer or PC enthusiast.
HyperX blu features a new streamlined clipless design. Its heatspreaders provide thermal performance at an improved price point.
- Kingston Hyper-X Blu KHX1600C9AD3B1K2/4G
- 4GB Kit - 2x 2GB Modules
- DDR3-1600
- CL9
- 1.5v
- 240pin
Was [£29.99] Inc. VAT
Only £25.99 inc VAT.
ORDER NOW
Kingston HyperX Genesis 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel (KHX1600C9D3K3/6GX) @ £43.99 inc VAT
HyperX DDR3 memory; the latest generation of DDR memory technology. Like all Kingston HyperX products, DDR3 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. DDR3 memory offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR2. HyperX DDR3 modules are available in single, dual and triple-channel memory kits.
Features:-
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL X58
CAS Latency: 9-9-9-27 2N
Capacity: 6GB (2GBx3)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.60-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Warranty: Lifetime
Was [£49.99] Inc. VAT
Only £43.99 inc VAT.
ORDER NOW
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) @ £47.99 inc VAT
Kingston's KHX1600C9D3X2K2/8GX is a kit of two 512M x 64-bit 4GB DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 8GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
Model Name: KHX1600C9D3X2K2/8GX
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
Capacity: 8GB (4GBx2)
Test Voltage: 1.50-1.65V
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Was [£59.99] Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
Remember this is Kingston which is one of the worlds largest and most reliable brands, plus this is 1600MHz memory and is ideal for both Intel and AMD including low voltage platforms such as Sandybridge. You have until 4pm Saturday to grab yourself a bargain, don't hang around, get your wallets out! :D
Interested in the Kingston Grey. Are memory prices expected to go up in the coming months? I am going to build a 2500K system but not until the end of the year. Would it be silly of me to buy the Kingston Grey 8GB now? Is it a good choice for a 2500K?
Perfect for a 2500k. Amds new chips support 1800+ speeds, and manufacturing has matured so prices will fall slightly for the current ram, but not much since all the chips out only officially support 1333 and the 1600 stuff is the sweet spot for overclocking.
