You could try the older Gentle Typhoons, for example the 1850rpm ones. For a start they should be easier to connect to a fan controller and they don't draw nearly as much current (I'd guess you could get 2 or 3 on a single channel on the Scythe). Plus they're pretty quiet and I think they also have good static pressure which I believe may be useful on a stealth rad.
A top is something that basically makes the pump more efficient
It's in the op. It says pump with top![]()
6 may be a bit overkill for me since i want to make use of the top controller as well, and also who can resist a nice lcd display hahaha
Im hoping that this Lamptron FC5 will be ok, im honestly not so good with this whole amp/watt thing :S this has upto 30w per channel....
