I've recently rebuilt my machine and since my Radeon 5870 has been overheating.
On idle it generally sits around 45oC, but as soon as i go into any 3D application or game the temperature can reach as high as 90oC
I have got a 120mm case fan on the side of the machine sucking air out away from the card, just as i did before I upgraded the machine. I've tried to re-seat the card and I checked the fan which seems fine(i can also hear the fan speed up when the card heats up during gameplay)
I've also tried it without the side of the case on and it still gets hot
As soon as I minimize a game the temperature quickly drops back down to 45 or so, but once i go back into a game it'll heat back up again within 10-20seconds.
There doesn't seem to be any loss of framerates in game nor artifacts, particular after some time playing.
However, last night whilst playing GTAIV the computer did randomly switch off, I turned it back on but everything seemed normal.
The graphics card isn't overclocked. I did turn TPU on to boost the processor but i've switched it back off to troubleshoot the GPU. I've also tried resetting BIOS settings and i'm running the latest Radeon drivers.
These are the stats from CCC whilst I type this with the card on idle:
Temperature - 44oC
Activity - 0oC
Fan Speed - 40%(set to speed up as the temp goes up, tried it on different settings though but doesn't change anything)
I've looked on the Asus AI Suite to see about the processor stats as well, just in case:
VCore: 0.968 V
+12V: 11.904 V
+5V: 5.080 V
+3.3V: 3.360 V
CPU 37oC (when under load this goes to about 65oC)
Motherboard: 33oC
CPU fan: 859 rpm
Any help would be greatly appreciated. I am really confused and frustrated by the problem
Temperature - 44oC
Activity - 0oC
VCore: 0.968 V
+12V: 11.904 V
+5V: 5.080 V
+3.3V: 3.360 V
Motherboard: 33oC
CPU fan: 859 rpm
