Possibly saft motherboard question.
3 Oct 2010
Looking at a few different options to bring my pc up to spec, and the main one in my mind at the moment is the mobo to run SLI with my 460.
Now, if I wanted to keep everything else in my spec below, but just get rid of my crappy Gigabyte mATX motherboard, what else would I HAVE to replace.
I'm literally dead happy with every other aspect of my PC, other than the mobo, and if possible I don't want to Format!
Any advice would be appreciated, as I've never just swapped a mobo before.
EDIT: Also, recommendations of what to replace it with would help immensely.
Actually it does seem to have good reviews, what about cooling as far as SLI is concerned, is just the onboard cooling of both cards good enough?
Also, if I just bought another copy of Win7, installed on an SSD, and then used my current as a slave, would the installed copy of windows interfere being slave or can it just be deleted upon first startup?
Never done this before, sorry lol :/
Oh and
A: Dont seem to be able to buy my card from OCUK any more, would any 460 work in SLI?
B: Would my GX750 power supply (Coolermaster) be enough?
pretty sure the stock cooling will do, although the top card will always be quite a bit hotter than the bottom
as for the windows install, huh what? sorry, totally lost me there lol
i think any other 460 will work, i'm not totally savvy RE nvidia cards and SLI so might be wrong
psu, yes i think so, 460 uses two 6 pins does it not?
Thanks.
Im pricing this up and its half the value of the pc and ive had it under a year! I may just settle for running games on lower settings cause its a bit daft to me lol.
Which board is it?
If it's the GA-880GM-UD2H (that comes with the OcUK bundle) then I have the same board and have also been contemplating replacing it.
As it happens the board I would most likely replace it with was the Asus board Seraph suggested. Except I've heard there are still teething issues with the 990 chipsets. So I'm a bit nervous in case I just swap one set of issues with another lot.
Which board is it?
to be fair, i haven't noticed any issues with the board in question yet,
only thing thats bugging me senseless is the damned Uefi bios if only it could be switched back lol,
Just install win7 on ssd and use current hdd as secondary drive. No need to buy win 7 again.
What chip are you running it the board? Have you overclocked? How does it compare (overclocking-wise) to the AM2+/AM3 boards?
Phenom II 955, clocks fine, i've had it up as far as 3.8 at stock volts so far, not going any higher on air due to the high temps,
i'd say it's easily as good as my old M4A79XTD Evo board i had before, heck it's basically the same board but with sata 3, and a 900 chipset instead of 700,
lots of nice build features, the northbridge actually runs cooler than it did on my M4a board too even with overclocked cpu ram and gfx,
Which board is it?
Yep one in the same, was very restricted in budget and what I bought at the time was the best my money could buy.
Sorry I don't follow, if I have a new Mobo, wont I need another copy anyway?
Also, ive just realised as my 1055t was pre overclocked, would the same Oc profile still work on the new motherboard or will it need to be redone?
for a new motherboard you will need a re-install tbh, very slim chance of windows working without one,
and yes new board means you'll need new overclock settings because it's a different board, chances are the settings you'll need might be very different to the old ones :)
Ahh, I've never overclocked a CPU before so that will be interesting lol
it's not hard at all, have a look at the Phenom II Hex overclocking thread in CPU's for suggestions ideas and a general place to start :)
If you are using new SSD yes. But you can install an existing HDD without having to re-install windows. Just connected hdd to new mobo (Sabretooth P67) yesterday and windows is working fine.
