I have a TT armor, I'm looking to get a TJ07 now. I would put a thread up in the wanted section but I don't have enough posts
. Not sure what other forums I use would be good to put wanted posts up since most are based in America. Might throw one on ***** though.
End of Augest!!, Damn i'll be looking into building another system by then lol.![]()
Antec skeleton![]()
It's this one
http://forums.overclockers.co.uk/showthread.php?t=18214411
but I'm not sure, might see if I can get a lian-li case![]()
well I'd quite like to get one like this one
http://forums.overclockers.co.uk/showthread.php?t=18258875
I use three just now, but Id only end up using one or two anyway
just looked for a lian-li case on the bay and saw one that can fit two 480mm rads in the bottom![]()
they're stacked on top of each other too, I'm pretty sure you could fit two 240mm rads behind them too![]()
it's also £205!![]()
I could wheel it around like a suitcase![]()
I kinda want to do a case which hasn't really been used for watercooling before![]()
