6950/6970 card length, anyone know it?
6950 reference Rev1
[/IMG]
Looking at the Lian Li Q11 as im want something tiny. I could chnage GFX to fit if i must
I had a antec p150 and just upgraded to a lian li pc-7fnwb; didnt want to be limited by GPU length. But before I upgraded my case I went out and looked up Every 6950 length.
They are all different lengths ... but the 2 that were the smallest that I can remember were the sapphire and the xfx (might have to double check me thou); the sapphire one with the single fan (didnt check the dbl fan at the time).
I think the xfx was 10.2 inches or maybe that was the sapphire ... but go check em yourself if need be.
Well I think the XFX card would be the one with a fan in the middle as that is a non ref card. Are you sure you were looking at 2gb cards?
