Installing windows7 on new build error... advise please
5 Jun 2005
Southampton
building my first intel i7 pc, always had amd, and getting this msg pop up,
im using the same usb created win764bit install i used earlier today, and dont have a dvd drive installed yet ?
its a shuttle sh67h7 and i cant see any drivers i need, am i missing a trick in the bios being an AMD boy?
Are you trying the usb stick on the usb3 port, i had the same problem recently cant remember what i did, ended up connecting a dvd and installing via disk in the end i think
That's because the S-ata controller isn't been picked up automatically. You require the controller drivers. They should be able to be obtained from the motherboard website. What board is it?
being a shuttle this is the drivers page for my model, i cant see what i would need
http://global.shuttle.com/products/productsDownload?productId=1477&osId=7&panelId=2
oh ok, its usb3 at the front, not sure on the rear?
i just tried a usb dvd drive and got the same, but think i have a sata somewhere
fixed!
fixed! dont use the front usb 3 ports! use the usb2 ones around the back!
thanks bradmax!
Np was trying to think what the problem was, i didnt figure that it was the usb3.0 ports at the time and ended up connecting the dvd and installed via disk will remember next time ;)
If anyone else hits this problem and its not usb 3.0 orientated I had the same problem and it turned out to be the marvell sata3 controller, disabled it in bios, installed windows 7 then re-enabled it.
