Davloa you're a legend. Thanks very much matey! <3
Go to \Steam\steamapps\common\vampire the masquerade - bloodlines, right click on the vampires.exe and set it to run in Windows XP service pack 3 compatibility mode.
Install this unofficial patch: http://www.gamefront.com/files/service/thankyou?id=20563891
Next, go to http://www.fileplanet.com/156598/15...e-Masquerade:-Bloodlines---Resolution-Patcher and download the resolution patcher.
Follow these instructions:
0. VTMB cannot run at the time of patching.
1. Copy VTMBResPatcher.exe into the folder with "engine.dll".
2. start VTMBResPatcher.exe
3. change the values like you want them to be like or use one of the default sets of resolutions.
4. click "Patch It".
Start the game.
Press Esc 4 times to skip the intro movies, they don't seem to play for me I get a black screen.
Go to settings, choose the 1080p resolution.
Restart the game.
Enjoy!
just tried that to the letter on Win 7 64 bit. I get "Failed to find steam" before and after i install the patch.![]()
When you install the patch you have to select the folder in which VTMBL is installed otherwise it tries to install it to C:\program files\Vampire - Bloodlines
After reading this I dug out my old CD version and started playing again. Never really gave it much of a go first time around because it was so buggy on release. Just finished the mission in the old haunted hotel. That part is really freaky, especially with headphones. The weird voices and sounds were beginning to freak me out.
Any ideas on how to fix a "Failed to find Steam" error message?
I applied the unoffical patch and resolution patch, but it won't start.
edit: I went to verify the games integrity etc and there's over 200 files that need to be reacquired :O.
I've also read that it could be the UAC. I'll report back if it's fixed, incase others are having the same problem.
EDIT2: Nothing![]()
Do you guys play/prefer 1st or 3rd person perspective?
LOL!!!!Been playing it through as a Nosferatu this time, named it after my ex-gf![]()
In this game?
It depends on the situation. If I am sneaking I will change to 3rd person. If I'm shooting I will change to 1st.
