- 16 Jan 2003
- Nottingham
I'm assuming this cooler will be fine for 4.5GHz?
I have rev 1, but so far as cooling capabilities are concerned, rev 2 is exactly the same, they just tilted the assembly backwards to ensure less interference with memory.
New of Rev. 2 Tranquillo:
The heat pipe constellation was optimized to prevent any conflict from the components on latest mainboards in the market. Additionally the shape of the small heat sink was optimized for a better heat transfer.
The fan is the same, the mass is also the same, the number and diameter of the heatpipes are the same, and it appears that the area of the fins is also unchanged. So, the difference in the cooling ability should be minimal, if any at all.Are you sure there's no difference in cooling, the Rev 2 seems to have changed the mini heatsink as well.
From what I understand these chips do run hot and less you have really good cooling and a huge heatsink. I wouldn't woryr too much about it unless it goes north of 80.
Don't forget it is summer and these lats few days have seen high humidity and ambient temps.
With a 4.5GHz i5 2600k you are looking at a heat load of 135-140W. This is close to the 150W where the Tranquillo becomes less efficient.Clearly, the Gelid Tranquillo heatsink is best suited to 95-85W TDP processors where it easily manages to keep temperatures in check while operating at whisper quiet levels.
When stressed with the 150W heat load the Tranquillo heatsink can at best yield 'good' thermal performance on the Intel test platform. However, a half-dozen other heatsinks cool better with the same, or nearly identical sound output. Bottom line, Gelid Solutions have produced a good quiet heatsink, with good thermal performance.
