The smallest cars have gotten larger but only marginally so, as in there's nothing really old-Mini sized, but that's because the old Mini was incredibly small, dangerous and now sits in a segment less expensive than virtually everyone can afford. The biggest cars have also remained more or less the same size.
What's actually happened is that there are more models and people are choosing to buy larger cars.
Hopefully they'll continute to get larger and larger so women have to learn how to park the ****s![]()
If you are asking me to make the comparison I think you are missing the point. There is a Fiesta and a Ka to consider. The Ka is 3620mm long, which is shorter than a Ford Anglia let alone an Escort. Ford have a larger range of models now. The desire of the consumer to have larger cars with more safety features is what's driven the absolute increase of particular model lines, but cars themselves are pretty much as big as they always were (with the exception of some tiny models, as I mentioned). People are just choosing to buy bigger.Compare the current Ford Focus to it's Mk3 Escort ancestor, or the Mk1 Golf to the MkV. Both are getting on for 50% heavier and 10-20% larger in most dimensions.
Yes that's exactly what I was getting at. The vast majority of people wouldn't tolerate a car of the old Mini's proportions anymore, and as such it doesn't exist in that segment. A car of it's size could be made today and still be safe. Look at the Smart Fortwo - it's shorter, just a smidgen wider and a fair bit taller (and missing some seats).To extrapolate on that comment about the Mini slightly - is some of the increase in size/weight not due to increased safety features? Other than that I'd guess that people tend to expect a certain standard of features/luxuries in their cars now and these will normally add weight over more basic cars that might have been the norm 20+ years ago.
The current 7 series is vast and considerably longer than the earlier versions.
You are looking at it in the context of one manufacturer and therefore are assuming that the manufacturer has only continued to offer cars in the same segments and size brackets, and they haven't.I would say that the larger cars have also got considerably bigger. A Mondeo is now larger than the Granada / Scorpio (and that was a large car at the time). The current 7 series is vast and considerably longer than the earlier versions.
[TW]Fox;19729626 said:What is it with people stating opinions based on loose assumption as fact?
