my pc is in my signature, i thought the 530w psu was limite,d and then I got a power monitor today, amd found that it only uses 160W on idle, and around 250W-300w on boot. Crazy stuff.
I also found that when powered off the tower uses a constant 6-7w of power..
My monitor on the other hand uses a measly 15w of power when on and comepletely 0 watt when turned off, which is amazing because it's actually "awake" when powered down, because when the pc is turned on the monitor comes on automatically.
Why does the tower use 6w when turned off, where is that 6w get used? I know that the lan lights etc are on, and some of the mobo lights are obviously off as well.
What can I do to get the wattage down to as close to 0w as possible?
im scared to just leave my pc off but still being powered on at the mains. My old monitor some how fried itself :\ so if you dont want it to use power when switched off, switch it off at the mains as well or flick the psu switch
