- 1 Aug 2011
hi guys was wondering which of the above settups would give best fps gaming at 1080p budget is £270 for cf i would have to get a new psu tho, thanks
lol advantage with cf is i can buy 1 card this month and 1 card next month with new psu seen somewhere cheaper elsewhere for the 6870
Bang on budget, without a doubt, if you can afford a 3 slot gpu, I would get this:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-250-AS&groupid=701&catid=1914&subcat=
OC it to hell and back and it will win more than it loses!
Ignore the foolishness above. Play Metro 2033 on 2 6870's and you can expect nearly double the performance at 1920x1200.
If your video card is running out of VRAM it can use your system ram as temporary measure, its only once you start to go massively over you get inconsistent performance.
this card is just beautiful.
To the OP: if you decide to follow a fool like this, then better not to look into the following comparison:
skip
Swings and roundabouts.
The 1GB cards may have more spikes in the framerate but the 2GB cards have a whole section where they drop below the frame rate of the 1GB cards.
When talking about vram limitations, I'd like to count the total percentage of time with instantaneous framerate below a certain threshold e.g. gaps above 33ms. This defines the smoothness of the play.
Like with the 2GB cards where they drop below 10FPS for several seconds?
That's a lot of gaps of 33ms.
What? Everything about the 1G cards is better on that comparison, higher max framerate, even higher min framerate. Average rate is higher as well.
An important point to make is that neither setup is actually playable. The benchmark is running below 20fps for most of the "action section" which is simply not enough. This is a pure example of GTX560TI SLI not being powerful enough rather than purely running out of memory.
Settings would have to be dropped to bring up the minimums in both cases.
The same would be true for any of the setups the Op is considering.
Metro 2033 is hardly the best comparison but I think it's generally true that it's a bad idea to go SLI/CFX with 1GB cards.
You do need to go look at fps graphs of games on [H] - one of the only review sites that shows you how fps changes over a period of time, rather than most sites that just plop a meaningless number down for you. Even with a lower 'average FPS', some card setups might be more playable than cards with a higher average which suffer from heavy spikes and stuttering every 5 minutes.
