I vote for the K-62. Never owned one, hadn't even seen one before. But I do own a CM 690 II.
Waste of money. Looks ok, but feels cheap, isn't as room as I expected and it vibrates.
Can't really think of any good things to say about it.
In short...
K62 is the more stylish (imo) and higher quality case. It's a delight tbh, especially for its cost. Not really any faults - good cooling, dust filters, decent cable management, all solid + metal w/ painted interior, excellent HDD bays. In terms of appearance you can't really tell in pictures, but side by side the 690 looks a bit thin and cheap, while the K62 is metallic and quality.
If you have a direct choice between the two I'd say you'd be a bit silly to pick the CM - the difference is a lot more than £5 .
