Permabanned
- 9 Jun 2009
- London, McLaren or Radical
What's wrong with the second one, it looks even better than the first to me. It's had a forged 2.1 stroker rebuild by scooby projects (who are top guys and know what they're doing) along with a bob rawle remap (he is a subaru mapping guru!) Also the D2 8 pots are excellent (I know as I have the ksport 8 pots on mine which are identical) and the only mods I would get rid of is the HID kit and OTT I.C.E. setup. With a bigger turbo (peraps an sc46 or md321) and a £150 remap tweak (what bob rawle charges for a map tweak) you could be looking at 400bhp + which is going to be pretty rapid in a classic scoob. Also the fmic lag thing, I think you're overstating it I've been in a number of fmic-equipped Impreza's with no noticeably increased lag over a tmic-equipped car.
I'm not slating the quality of workmanship, more the questionable owner (as any owner is).
I agree with you that the choice of components is good...
But something like this is much much higher risk... the build may be good, but if the owner's not taken the best care of it then it's at risk of not lasting much longer.
I did not get the impression the op was looking for a potential project...
Rebuild in March -> sell so soon after makes me wary... if you've spent such an incredible amount (a stroked rebuild that's cost upwards of £5k, plus £1k for the wheels, plus £1k for the brake conversion) on something and then sell it so soon after...
He could well have a valid reason to sell... but I would not take the risk unless you're prepared for a few expensive problems...
If it's genuine and all ok... then it's a frikkin bargain. But a big risk at the same time...
As for FMIC... the difference is immense... even a well-done FMIC is noticeable over a TMIC... but maybe that's just because of so many years n/a racing experience... even the lag from a TMIC annoys me sometimes, but you get used to it..
