Is this soundcard really going to make a difference over onboard sound?
13 Jan 2004
South East
Hi all,
I've just built a new SandyBridge system, with an ASUS P8P67 Pro motherboard, currently using onboard sound.
I think the sound quality is awesome in games and from music as well through my Sennheisser HD555 headphones.
I wondered if it would be worth getting one of these as they're pretty cheap: http://www.overclockers.co.uk/showproduct.php?prodid=SC-012-AS&tool=3
Will it make much difference really?
Thanks
Absolutely, onboard sound has come a long way but it still pales in comparison to a dedicated soundcard, even one as cheap as the DG.
I sold my mid/high range sound card to fund for upgrades on the computer and just used the onboard sound... using the same speakers the difference can definitely be noticed.
Where are the biggest 'gains' to be had? Processing, components? Limited to analogue outputs or digital ones also?
Is there much interpretation in terms of processing done and if outputting in digital are there any discernible gains to be hard? (Digital output is usually a works or does not work affair no? Unlike analogue where interference and quality of components could have an effect on quality)
So I'm guessing for £20 that ASUS DG one might be a good deal. I'm not a massive audiophile, but if for £20 I can make a noticeable difference then I may as well.
Is it just powered from the Motherboard or will other power be required?
I picked one up yesterday. like you I'm not an audiophile, and when listening to music/movies I seriously can't tell any difference over onboard, even when quickly switching between the two. Games though are a night/day difference. After firing up the witcher 2, I was hearing loads of new little things that had gone straight over my head with onboard. All the ambient noises like wildlife, and the crackling of fires are now much more vivid.
For 20 it definitely seems to be worth it so far. The only problem is that the 20 will turn into much more, as I'm now tempted by a really good quality set of headphones/speakers to make the most of it!
Result of soundcard or the built in amplification though? I had the same transition but I did not change soundcard, just put an amp in-between on-board and headphones.
I've always run sound out through a home cinema system so it probably won't be down to the amp. I've also got an old 24bit soundblaster external card, and the sound made by the xonar is very different to that in games as well.
Onboard uses really cheap and nasty DACs and cheap caps, where as a sound card uses better quality ones and what you usually notice are: more balanced output, no/less clipping in the highs or lows, more separation between instruments in music/channels in movies and games, directional audio is better, more 'details' can be heard. Processing these days is a null point as any modern processor has enough power, I believe most sound cards don't even do the processing anymore per se, but instead just do the conversion.
If you're using digital then you won't see any benefit as the card will be doing naught (unless you enable Dolby Headphone). Digital output is no different to analogue in so much as the same conversions are happening and the audio quality is determined by the receiver, so basically you're moving the conversion to a later stage, usually away from the computer which is electrically noisy.
The amp of the DG is ok, it's nothing amazing but at £20 you really shouldn't be expecting it, it's a useful addition but by no means a replacement to a proper headphone amp.
Cool, cheers for the info. Pointless exercise for me then as I am moving sound out of the PC optically to be worked with on my amp.
Take a chance on a Xonar DG and some Goldring DR50s. It'll only cost you a shade over £40 for the pair and you'll be mighty glad you did.
TBH I came from a X-Fi and I can't tell the difference.
ive got a an Xfi titanium fatality pro, and on a new build in a couple of months time, i was thinking of getting the Asus Xonar Essence ST, are you saying there's no difference, i've read music sounds better on the Xonar!.
All I'm saying is that I cant tell the difference.
I'm no audiophile, but my Hendrix, Led Zep, Motorhead, Albinoni etc sound just as good to me on my Xonar DG as they did on my Xtreme Gamer with the added bonus of the DG being great for my headphones.
yea i play all the rock and metal stuff, do you play flac and CD's on your system or is it mp3's and itunes stuff, i'm not saying your wrong m8, just finding out if it's worth buying or not!.
