- 12 Jan 2009
hi i just got the above mentioned graphics card, however my powersupply has 1 pici-e 6 pin connector it takes 2 it came with the connectors and i have to put 2 4 pin connectors into the adaptor and the end is a 6 pin pci-e connector the motherboard light comes on but the pc will not turn on.
If i unplug one of the pci-e connectors it starts but then i get a beeping noise and pc will not show anything.
It says min power is 500w for this card but i have a 600w powersupply its a Hiper 625w i believe black finish with mesh on the cables.
Motherboard: Asus M5A97 Pro
Ram: Kingston HyperX Genesis Grey 1600mhz but runs at 1333mhz 2x4gb
CPU: AMD phenom II X2 555
