** DELL U2412M 24" E-IPS LED MONITOR NOW AVAILABLE! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We have stock of this new E-IPS 24" with LED backlighting due in next week, were also bringing onboard their professional TN panel as well with fully adjustable stand:-
Dell UltraSharp U2412M 24" Widescreen LED Monitor - Midnight Grey @ £299.99 inc VAT
Enjoy widescreen performance, any way you want it. With a 24" 16:10 panel, IPS technology and LED backlight, the U2412M provides a brilliant view, plus amazing adjustability to suit any style. Powerful:
- Experience IPS technology, featuring a wide viewing angle with high-quality color representation for a peerless viewing experience.
- Flexible: Pick the view that works best for you with an almost unlimited range of tilt, swivel, pivot and height adjustments.
- Customizable: Change your energy usage settings, text brightness and color temperature with the touch of a button to help conserve energy with this eco-designed arsenic-free and mercury-free panel.
Whether for work or for play, the Dell UltraSharpTM U2412M can deliver an unmatched viewing experience.
- Clearly outstanding: Watch your graphics come to life on a vast 24" (61cm) LED-backlit screen featuring a crystal-clear 1920x1200 resolution on a 16:10 widescreen aspect ratio so you can’t lose screen area just because your customized applications support a different resolution.
- Contrasting view: Get ready for blur-free viewing with 2 million:1 (typical) high dynamic contrast ratio and 8ms with overdrive gray-to-gray (typical) response time that helps ensure crisp, sharp and ghost-free images.
- Colorful character: Enjoy an amazing range of rich, dramatic and accurate colors, thanks to IPS technology designed to give you color consistency across a broad viewing angle and a wide color gamut at 82% (typical).
- Premium Panel Guarantee: 100% replacement of Dell UltraSharp series monitors sold if any bright pixel is found, valid within the warranty1 period.
Specification:-
- 24" (60.96 cm) viewable area
- Widescreen (16:10)
- Panel Type, Surface: IPS (In-Plane Switching), anti glare with hard coat 3H
- 1920 x 1200 at 60 Hz
- 1000 : 1 (typical)
- 2,000,000:1 (dynamic)
- 300 cd/m2 (typical)
- 8ms (gray to gray) Typical
- 178º / 178º
- 16.7 million colors
- Color Gamut: 82% (CIE 1976)
- 0.27 mm
- 1x Digital Visual Interface connectors (DVI-D) with HDCP
- 1x DisplayPort(DP)
- 1x Video Graphics Array (VGA)
- 1x USB 2.0 upstream port
- 4x USB 2.0 downstream ports
- DC power connector for Dell Soundbar
- Height-adjustable stand, tilt , swivel , pivot and built in cable-management
- Flat Panel Mount Interface
- VESA Mount
Only £299.99 inc VAT.
ORDER NOW
Dell Professional P2411H 24" Widescreen LED Monitor - Midnight Grey @ £209.99 inc VAT
Fulfilling your demands for high productivity, great user comfort, and minimized environmental impact with EPEAT Gold rating, the Dell™ Professional P2411H 24”(61cm)W Monitor with LED is the ideal display for the professional office space.
- Environmentally sensitive: Use of recycled materials and halogen-free laminates in its circuit boards; arsenic-free glass and energy-efficient, mercury-free LCD panel to help reduce environmental impact.
- Puts you in the comfort zone: Raise, lower, tilt, pivot or swivel the P2411H monitor to fit your working style and enhance your viewing comfort.
- Excellent screen performance: The 24"(61cm) high-definition LED-backlit display performs brilliantly for complex tasks as well as everyday applications.
The Dell Professional P2411H monitor combines excellent connectivity and outstanding comfort with a superb front-of-screen performance for all your office productivity needs.
- Tilt, swivel and adjust the height of the P2411H to match your working style and enhance viewing comfort
- Use the pivot function to alternate between landscape and portrait views for excellent productivity
- Get convenient access to preset modes, brightness, contrast, menu, exit power button via the on-screen display control
- Secure the P2411H via slots for a security cable lock and stand lock (locks not included)
- Use the two USB 2.0 ports to connect peripherals such as keyboards, mice and thumb drives.
- Connect via the DVI-D(HDCP) port to enable high image quality
- Rely on the VGA port for everyday analog connectivity needs
- Enjoy a brilliant view with the high-definition LCD panel (active-matrix TFT) with LED backlight
- Experience vivid, lifelike details via the 2,000,000:1 dynamic contrast ratio (1,000:1 typical)
- Easily share the P2411H for group viewing, thanks to the 160º/170º wide viewing angle with 16:9 aspect ratio
- 5 ms response time (typical, black to white) designed to reduce ghosting and deliver razor-sharp images
Specification:-
- 24" (24" wide viewable image size)
- TN- Twisted Nematic, active matrix - TFT LCD
- 1920 X 1080
- 1000 : 1 (typical), 2 million:1 (dynamic)
- LED
- 250 cd/m2
- 5 ms panel (Black to White)
- 160°(vertical) / 170°( horizontal)
- Color Gamut (typical): 81% (CIE 1976)1
- Color Depth: 16.7 million colors
- Pixel Pitch: 0.277 mm
- Widescreen (16:9)
- 1x VGA
- 1x DVI-D with HDCP
- Height adjustable stand, tilt, pivot and swivel.
- Built in USB 2.0 High Speed Hub
Only £209.99 inc VAT.
ORDER NOW
Nice!
1920x1200 on the U2412M is a welcome change from all of thoese 1080P panels!
A fantastic price compared to the older U2410 too! :D
Without looking at reviews, what is the U2414M like, compared to the U2410?
From what I understand there is no need to upgrade from your U2410 thats for certain.
Isn't the U2412M e-IPS? I don't think E-IPS is the same, I'm sure badass will confirm.
Excuse my lack of Googling skills this early in the morning, but is the U2412M meant to be the successor to the U2410? Have monitor prices dropped so much that this can be introduced for a price 34% lower than that of the U2410? Or have Dell gone for cheaper components/technology this time around? (Does the M signify anything significant?)
Oh, I see, this is standard gamut (among other changes). It's not going to be as popular with photographers, then. (At least not those who use Adobe RGB.) :p
Nope, the U2410 is still superior, especially for photographers, but I'd be waiting for reviews.
The U2412M is an E-IPS, which is a value IPS panel. The U2410 is a full blown IPS, better quality.
P.S. They both come with 3yr warranty too.
E-IPS is still a good bit better than TN though!
I haven't read any reviews yet, but IIRC the U2410 also has more inputs and lower lag than the U2412M...
Gibbo, on the subject of Dell monitors would you mind taking this one off this week only? I would be interested in several then...
http://www.overclockers.co.uk/showproduct.php?prodid=MO-041-DE
We can no longer do the price we were doing a couple of weeks back, basically we were too cheap and DELL got rather upset with us and as we want them to keep selling to us and provide the warranty they do and not block us were do whats required to keep all happy.
As far as I'm aware the U2412M is e-IPS which stands for economy (24"WS LG.Display e-IPS (LM240WU8-SLA2). E-IPS is Enhanced IPS which the U2412M could not have at this price point.
LG.Display started to produce their so called "Enhanced IPS" (E-IPS, not to be confused with e-IPS) panels.
http://www.tftcentral.co.uk/articles/content/panel_technologies_content.htm
The screen will feature an e-IPS panel combined with W-LED backlighting....
Source: http://www.tftcentral.co.uk/news_archive/24.htm#dell_u2412m_specs
If I didn't already have the excellent u2410 I would be tempted to buy 3 u2412Ms for surround gaming, my pick based on price/features.
Highlights u2412M (£299.99 inc VAT) vs u2410 (£455.99 inc VAT)
brightness : 300cd/m² - 400cd/m²
contrast (dynamic) : 1000:1 (2,000,000:1) - 1000:1 (80,000:1)
standard-gamut (82%) - wide-gamut (110%)
colours : 16.7 million - 1.07 billion
response times : 8ms - 6ms
typical power consumption (maximum) : 38W (72W) - 75W
u2412M : There's also a lack of memory card reader, HDMI/component/composite connections (info from Dell site), if your using this you'll connect via DP or DVI-D and already have a USB2.0 card reader.
U miss the point mate,
Take a look at the "was" price ;)
