Spec me a GPU
2 May 2011
Woking
Hey guys,
I need a GPU for under £100. I don't play a huge number of games but I'd like the capability to run most games at fairly high spec. Primarily The Witcher 2 right now at max would be wonderful.
I was looking at the preorder for theXFX AMD Radeon HD 6770 1024MB GDDR5 PCIe. At £85 this seems like a bit of a steal,do yu think thiswill be suitable?
I'm running an i5 @4.5GHz, 4GB ram. ANything else you need to know please ask.
Cheers,
Jono
Haha fantastic, thanks man. I'll try and squeeze some funds out of somewhere then!
I feel a bit silly going for the first suggested gpu. Could you recommend any others? And as this is an OCUK card, do you know what the outside equivalent is so that I can read up on it?
For the money, yeah :). Just been looking around and you could probably even get away with AA and higher settings in The Witcher 2 at your res :D. Just make sure you disable Ubersampling, that hits the FPS very, very hard.
Alright, that's excellent! Now to find £110...
Edit: Going up the price range a bit to maybe £130, would I be able to get a lot more for my money?
