hardly a tool, more like a realist. Clearly some people cant face that it should have been so much better.
Might as well play TF2, this is what it's trying to be.
It's a shame as the performance is dodgy. Teamplay wise this is one of the few options at the mo if you're into class/objective based shooters and at times it's brilliant. Unfortunately it's been hit by the CoD stick a little too much and dumbed down for the masses
Problem is if you put it up along side TF2, it fails miserably. That is a REAL class based shooter, this is basically a normal FPS game with perks in a similar way to how Bad Company 2 is a normal FPS game but has different classes. That is 1 thing that let it down. Every opponent looks the same and for the most part, plays the same too. You get more variation in how you play if you select a Heavy body type over a Light body type than if you choose Engineer or Soldier.
...What? It has classes and two teams. Ergo it's trying to be TF2?
It's more trying to be an ET game, which is hardly surprising given who developed it.
