Just bought a Cogage Arrow cpu cooler but the damn thing is too big for the board. First issue was the top bracket that screws through the board into the back plate was touching a cap, and then when it was mouted (test mouting I never turned it on) it was blocking the first pci-e slot.
First question is although ive opened the packets to mount the brackets etc can I still return it under dsr?
Secondly anyone with the board what coolers do you have installed. Looks like I may be going back to the H100 idea.
Cheers
pic below gives you and idication of how the fit was, thats with a cheap gt430 didnt want to risk my gtx 570 as that has a load more chips etc and exposed pins that could easily short.
Obviously its not a limitation of the case but the board, currently using a freezer pro rev 2 which tbh is ok but i want something better
Cheers
