Been messing with the overclock settings again today using 3Dmark11 and heaven benchmark. I managed to score some decent numbers however slightly worries about the voltages I'm using to get them stable.
Overclock settings:
Core: 852
Shader: 1700
Memory: 4002 (2000)
Vcore: 1.065v
Heres the graphics score results:
Stock settings on performance level
3Dmark11: 6200ish
3Dmark Vantage: 21702
Heaven (4xAA, 1600 res as per ocuk thread): 1204
Now I'm running a lot of gear off a corsair HX650w psu and I'm thinking because of this that I'm having to use more volts to get my gpu stable, would I be right in saying this or is the card just a higher volter in general? Also I can run 3Dmark11 on much lower volts but will crash on heaven bench unless I push them much higher.
Has anyone encountered this before? Also if you could post up your results Aswel and most importantly the vcore used and benchmark tests used to test for stability.
Thanks!
Overclock settings:
Core: 852
Shader: 1700
Memory: 4002 (2000)
Vcore: 1.065v
3Dmark11: 6200ish
Thanks!
