- 3 Aug 2011
- Scotland
Plus the i7 2600k is only 5% faster than the i5 2500k.The i5 2500K is a great price and performer.
The i7 950 is on a dead socket/more power hungry/more heat and slower.
Socket 1366 is not dead yet, and there are no doubt be budget 6 core processors in the pipeline to keep the upgrade path open.
I should have said at best it's only 5% faster - and given the difference in price between the 2500k and 2600k, the 2500k is a no-brainer.Sometimes, sometimes its not. Sometimes HT is working, Sometimes it isnt. Sometimes HT actually causes problems and then the i7 lags behind i5.
Stating i7 is 5% faster than i5 isnt always true, so shouldnt really be said.
I could say i7 is slower than i5, And I'd be right due to it sometimes being the case
It is dead. The 2500k outperforms the I7 970 / 980 (non x), which cost the same as a brand new Z68 motherboard and 2500k.
It isnt obsolete, but there is absolutely no point to buying a new X58 system right now. Z68 + 2500k is cheaper, far faster and much more power efficient.
The only value that Gulftown still has is for silly people like me who splashed out on a Rampage III Extreme or similar uber high end mobo that obviously dont want to change that board now, but 6 core X58 CPUs are still far too expensive when they provide less performance than an overclocked 2500k for the majority of people.
for goodness sake, why is anyone suggesting the i7 950 when the i7 2600k is clearly far superior for the same price.
http://www.anandtech.com/bench/Product/287?vs=100
the i7 2600k beats the i7 990X
http://www.anandtech.com/bench/Product/287?vs=142
also, there will be no new processors on socked 1366 as it is being replaced by socket 2011, whereas some ivybridge processors will be coming to socket 1155.
The 2600K is not better than a 990x.
You should actually bother to read the title aswell, he said he can get the i7 950 for £125, and the 2600K for £200, so no, in this case they aren't the same price.
FYI, it's incredibly stupid to throw up some gaming benchmarks and then claim that a 2500K/2600K is a better CPU than a 980x. The IPC/per core performance of Sandybridge is abit better than Gulftown, therefore it's common sense that it's going to do better in applications (or games) that cannot utilize >4 threads effectively. If you can make use of the extra cores/threads of Gulftown, then a 2500K/2600K doesn't come close.
Basically, compare a 980x at 100% load with the 2500K/2600K at 100% load. The 990x stomps them every time.
Whenever HT decreases performance, the drop is so small it isn't even worth mentioning (1-2% usually).
Having owned all 3, and currently settling for a 2500K I make the following observations.
Performance
Unless you are addicted to benchmarks, you will not be able to tell the difference between them. On paper the 2500K and i7 950 are equal, with the 2600K being slighlty ahead but in real life (gaming, general Windows apps and the occasional encode) I noticed no difference.
Efficiency
The i7 pulls approximately 15W more electricity at idle and 40W more when fully loaded than the 2500K. Run both for 4 hours per day and the i7 will cost about £5 more per year than the 2500K (~25W average x 4 x 365 / 1000 x 15p per kWh). Not much in it really, especially when graphics cards, monitors and the rest of the system components will pull a lot more.
Cooling
2500K and 2600K do run a lot cooler (10-15 degrees).
Motherboards
1366 mobos tend to be expensive compared to the budget 1155 mobos.
Conclusion
If you can pickup a cheap used 1366 mobo and i7 920-960 they are well worth the money. Sandy Bridge is NOT a massive step forward unless you are building a Small Form Factor PC, where the improved thermal performance and onboard graphics will make a big difference. For anyome who already runs a 1366 system it is not worth upgrading unless you have nothing better to do with your time.
For anuyone buying brand new, Sandy Bridge offers much better value and equal to slightly better performance. If you currently run 1366, wait for Ivy Bridge.
Other thought's
I only moved sideways from 1366 to 1155 because I wanted to downsize from a full tower HAF-X case to a Sugo. I have measured the power consumption with a plugin monitor and the savings are not that great. I have however squeezed equally powerful components into a much smaller case, but it did cost a lot to do so.
I used to think along the lines of "dead sockets", but in the systems I have built for myself over the last few years I have always changed the mobo and the cpu together.
But with socket 155 and Sandybridge you can just change to Ivy bridge without needing to change the board.
Still means buying the SB cpu first though and coming from a 920 is a pointless upgrade.
