Hello all,
Firstly if you finish reading this, You deserve a cookie!
Finished my first water-cooling build last week (29/08/11) which is the following:
EK Supreme HF Full Nickel CPU Block
EK-FC580 GTX+ - Nickel Plexi Waterblock
Laing D5 Vario MCP655 12V DC Pump
EK-Multioption RES X2 - 250 Advanced
XSPC RX480
XSPC RX240
All was running excellent was very pleased with the results. Overclocked my i7 2600k to 4.7GHz with a random fixed vcore of 1.35 just for testing purposes which I will be soon lowering to find the lowest stable.
The temps was pretty good imo (54,57,60,55) on 100% load. My GTX 580 was maxing out on 100% load at 40c which was also excellent as it was reaching 87c on air.
As I said I was very pleased with the results of my first water-cooling build, Until the next day I noticed a very very small minor leak coming from under the port of the RX240 rad, It was a very small leak I checked it with a torch and noticed around the port there was a very fine opening where XSPC didn’t weld it correctly. So I partly drained my loop and took out the dual rad and got it RMA'd (which I must thank welsh Tom and Paul(XSPC) for the excellent speedy RMA, Dispatched a new rad the same day)
I got my new rad Friday and put the loop back together, I did re-use the fluid.
Now here is my problem, The temps I was getting before I partly drained the system and put the new rad in was CPU(54,57,60,55c) and GPU(40c) now I have the system re-built and with the new rad and re-used the fluid temps are now CPU(60,64,66,62c) and GPU(47c) that was last night's testing.
As you can see the temps have increased by around 6-7c, Now I was thinking this could be just room temp difference but I don’t think it is as 6-7c is quite a difference in room temp.
Do you think somehow when I re-used the fluid it could have got a few little bits in it and has clogged up somewhere in the loop? Which is causing the temp difference since I’ve re-built the loop.
Here is a screenshot from when I was testing before I changed out the radiator.
Here is a screenshot from last night with the loop re-built with the new radiator.
And today I’ve ran prime95 and the temps are around the same as last night all but 1c which I would account for room temp difference.
What do you guys think could be the cause of this temp difference since I’ve re-fitted the new radiator, Do you think it could be something in the loop that has clogged a little?
I don’t fancy taking the whole loop apart and cleaning right now, If you guys think it could be something in the loop that has clogged can it do any damage if I left it until I change the fluid in around 3months time?
Also do you think these temps are about right for my setup?
Many thanks in advanced for your help!
XSPC RX480
XSPC RX240
