- 7 Jan 2009
Hey guys,
Just wondering which is the best to use as i had a nic card lying around ?..Ive tested both in my system and i get very good results with both the intergrated nic and dedicated nic.
Reason i thought about using the dedicated card because i heard it takes some load off the Cpu...even if it is a little amount.
Intergrated (On mobo)
Realtek RTL8168D/8111D PCI-E Gigabit Ethernet Adapter
Dedicated Nic card (Pci)
Realtek RTL8139/810x Family Fast Ethernet NIC
I have a Killer K1 card,But unable to use it because using it i cant join BC2 servers no matter what settigns i try for the killer K1 and bigfoot networks support is non existant.
