Z68 Questions
18 Oct 2002
Melksham
I'm contemplating upgrading my aging P5Q Pro/E8400@4GHz system to a nice shiney 2500K@<whatever> system,
From what I have read overclocking with the Sandy Bridge chipsets is 'simply' increase multipler/maybe voltage, and job done, if this is the case then does the actual motherboard make much difference?
I believe the cheapest Z68 OcUK sell, the Gigabyte Z68A-D3 for £72, seems to have all the slots/functionality I need and is considerably cheaper than some of the other Z68 boards, would this hold me back from overclocking, or are there any glaring issues with it that I may have missed?
Cheers in advance for any help.
The Gigabyte P67 and Z68 boards have been poor overclockers. My P67 was difficult to get stable at 4.5ghz. I have read the same with the Z68 boards. If you can stretch to the ASrock Z68 Pro3 is the best overclocker board under £100
Personally I only use GB boards. My P67A-UD4 will do 4.5 ghz everything on auto, just raise the multi. Any higher needs voltage increase so didn't bother trying for max oc.
You would get a overclock out of cheaper boards but I wouldn't push them to far.
Edit
Thats with a 2600k.
It has no Lucid virtu or Quicksync and has no display outputs, its shameful to call it a Z68 board.
Ah, didn't realise the overclocking was compromised, read a link from another post and seen a similar report (albeit 'only' 4.7GHz rather than 4.8 :p)
Edit
Thats with a 2600k.
The overclock is probably the most important bit really, although I've used gigabyte before with no issues it then wasn't the best clocking either.
To be fair those things don't matter to me in the slightest, but as above the OC'ing does so probably worth paying the extra for the Asrock one.
Cheers all :)
The Giagbyte has a 4phase vrm setup, the Asrock has a 4+1+1, and a few reviews of the Asrock show it to do 4.5ghz easily.
