I overclocked my cpu to 4.5Ghz and has it stable for 2 days however I never ran Prime95 for a reasonable amount of time (around 30mins).
I ran it today, and after 2 hours on the Blend setting, I had this error:
[Sun Aug 07 11:17:29 2011]
FATAL ERROR: Rounding was 0.4998091459, expected less than 0.4
Hardware failure detected, consult stress.txt file.
The only thing I have done to OC is change the multiplier and left the vcore on auto. Also, my ram is rated at 1600MHz but is only running at 1333MHz.
I've had a look around some forums and apparently the rounding error is caused by RAM timings, however mine are all at stock speeds.
I have been running the Small FFT test to rule out my cpu and I have no errors after 4 hours.
