Cheers guys!
Yep, Llano was chossen for the for its general all round ability, which includes gaming. It's actually replacing my uncles old pentium 3 (or 4?) PC so
any performance difference between i3-2100 won't be noticed
Thanks, this Corsair should do the job?
http://www.overclockers.co.uk/showproduct.php?prodid=MY-203-CS&groupid=701&catid=8&subcat=1517
Ok cool, so the extra £16 is probably worth it. I need to read that anandtech review
Needs at least 1600mhz ram, ram speed directly affects Llano graphics performance - http://www.anandtech.com/show/4476/amd-a83850-review/4
YOUR BASKET
1 x AMD Llano A8-3850 2.90GHz (Socket FM1) APU Processor (AD3850WNGXBOX) with FREE DIRT3 PC Game £99.98
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-00599) £79.99
1 x MSI A75MA-G55 AMD Hudson D3 (Socket FM1) DDR3 Llano MIcro-ATX Motherboard £71.99
1 x Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £40.99
1 x Cooler Master GX 450W '80 Plus' Power Supply £34.99
1 x Crucial Ballistix Sport 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel Kit (BL2KIT25664BA1339) £23.99
1 x Sony Optiarc AD-5260S 24x DVD±RW SATA ReWriter (Black) - OEM £15.98
1 x TP-Link 150Mbps Wireless PCI Express Adapter (TL-WN781ND) £9.98
Total : £391.40 (includes shipping : £11.25).
Go for that then, mug someone for 7quid and you'll be reet
by the looks of things http://www.anandtech.com/bench/Product/403?vs=399 - cpu wise that cpu is only slightly better but from the reviews I can find, the gpu difference is much better for the slightly extra cost, which I saved some pennies by dropping the psu to a cooler master instead to keep within budget.
I'm very fast learning that to get any kind of rig thats worth the money, 400quid just isnt enough unless you're willing to waste money on a lesser machine for slightly moar
