OcUK Ultima Mammoth - New System Project
OcUK Staff
8 Oct 2009
OcUK HQ
Myself, Nathwraith and RJK are working on something a little special for our system range, it's going to be epic that's all I am saying at this moment in time.
Check back for updates about the Mammoth new system project.
The case that we are using for the build is one of these;
The Internals of the case look like this from the factory, however the aren't going to remain this way for long :D
And from the front with the front panel removed
The First Job on the very long list of things is to strip the case of all the things that we need out of the way for all the watercooling that we are going to fit into the case.
Here is a picture of the case after it has been gutted
Once we had done this we can get a real feel for the space that we have to work with and what we can fit in.
So we firstly fitted the double 140MM radiator in the roof of the case which is a perfect fit.
Next we started to look at mounting the 360's in the front, for this we are using the EK Rad mounts which are very versatile.
Now that we have these in place we started to mount the first rad and secure this top and bottom.
Then all we did was repeat this method for the second rad that would will be mounted behind the first.
And now some more pics now that the rads are all in.
I just wanted to represent the non-dons in this thread.
You're going to need a bigger case. That one clearly isnt large enough.
ah, is this going to be the fully watercooled rig you were talking about in the other build log?
if so, i am very dissapointed at the lack of a window in the case :(
HI Guys,
This is the fully W/C system that we have been working on for a while, The case as standard doesn't come with a side panel, we are looking at getting one fitted to this system however, it would be a shame not to be able to see all the lovely components that will be in this machine.
The case doesn't look that big from the image, it does have 11 rear slots and can fit extended boards without any trouble.
would have thought the Xigmatek Elysium would have been the ideal case for a mega wc setup
The Elysium is a very large case and has the ability to have a lot of watercooling installed inside it, However the look of the case doesn't really meet with our expectations of what a Flagship computer system should look like.
Now this really does look like a brute of a setup, when can we expect more updates to this build? Or is everthing on hold until you get the side panels made/sent? :eek:
