Writing To Program Files Folder - How (Access Denied) ?
22 Dec 2009
Upper Skurt
Hi,
I need write/full access to some files that are located in the Program Files folder on a Windows 7 64 bit machine but keep getting access denied messages. Can anyone please tell me how to temporarily allow write/full access to this folder?
I am the PC owner with admin priveliges but just cannot seem to get round the permissions to enable write/full access.
Rgds
Open Start menu > Type Windows Explorer > Right Click Windows Explorer > Run as Administrator > Copy files in that elevated Explorer instance
If you need to write files FROM another application (IE not a copy) follow the same process but substitute Windows Explorer for the required application. (Needs to run elevated as an admin in order to be able to write to Prog Files)
Sin_Chase,
Thx, worked perfectly.
Rgds
Bintos
