- 29 Aug 2010
- Cornwall
So, I decided I was going to watercool my 5870.
It had been working fine, but I decided not to leave it alone ("If it ain't broke, tweak it!!")
The result was that after I fitted the EK waterblock it all looked lovely. The process had it's tricky moments but I was quite pleased. So I plugged the card in, connected up the tubing, leak tested it, all good. Turned the PC on and the monitor went to standby
Did a bit of fiddling, tried different DVI ports, different power cables, everything I could think of but the card doesn't want to work. Took it out, re-atached the air cooler. Still didn't work. Different PC, noting. lent it to a friend, no luck either.
So basically I have a dead card that, other than not actually working, seems in perfect condition.
Is there anything worth salvaging from it? Anything worth trying to sell?
It's one of the really early Sapphire reference 5870s with reference cooler. Before I broke it it ran lovely and didn't strike me as being loud.
Is there a market out there for the reference HSFs?
Do people buy the faulty cards to use for spare parts?
Cheers.
Cheers.
