Will the Artic Cooler be good enough to still hit around the 4.5ghz mark safely? It seems to get lowish reviews.
Also could I not mount the Radiator to the side panel?
Thanks.
Jcb33.
It will do 4.5ghz, it gets lower reviews because its physically smaller so its cooling capacity is less than a cooler that uses a 120mm fan.
And then how do you get the side panel on and off easily? theres nothing to disconnect to separate the radiator from the CPU head and the tubes are not that long in length.
