We have specially selected hardware to drop prices on for this week only. Save some money and build your dream PC at a better price!
OCZ Agility 3 240GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-240G) @ £334.99 inc VAT
As the third generation of the Agility Series, OCZ Agility 3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Agility 3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Agility 3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Agility 3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
- Capacity: 240GB
- Controller: SandForce SF-2281
- Maximum Read: 525MB/sec
- Maximum Write: 500MB/sec
- Max I/O Per Second (IOPS): 45,000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Was £349.99 Inc. VAT
Only £334.99 inc VAT.
ORDER NOW
OCZ Agility 3 120GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-120G) @ £152.99 inc VAT
- Capacity: 120GB
- Max I/O Per Second (IOPS): 50,000 IOPS (4KB File)
- Warranty: 3 Years
Was £159.98 Inc. VAT
Only £152.99 inc VAT.
ORDER NOW
OCZ Vertex 2 50GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTX50G) @ £69.98 inc VAT
Based on a cutting-edge new architecture, Vertex 2 Solid State Drives raise the bar once again and deliver unprecedented performance for the complete gamut of gaming and professional multimedia applications. OCZ designed the Vertex 2 to surpass the competition where it counts most, pushing the limits in both sequential and random read/write rates. With spectacular performance in 4k file writes up to 50,000 IOPS, these latest drives take productivity to the next level with over ten times the performance of the previous generation. Using the latest controller technology, Vertex 2 not only provides a faster, more responsive PC experience, but promotes cooler, quieter, and more energy efficient conditions compared to traditional mechanical hard drives. OCZ Vertex 2 SSDs come backed by a 3-year warranty and 2 million hour MTBF for ultimate peace of mind.
- Capacity: 50GB
- Controller: SandForce SF-1200
- Maximum Read: 285MB/sec
- Maximum Write: 275MB/sec
- Sustained Write: 250MB/sec
- Max I/O Per Second (IOPS): 50000 IOPS (4KB File)
- Warranty: 3 Years
Was £72.98 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
Samsung Port Duplicator with VGA, RS232 and RJ-45 @ £9.98 inc VAT
The Samsung port duplicator provides additional ports to your existing computer by using just 1 exisiting USB port!
- 15-pin VGA supporting max resolution of 1280x1024 at 16bit
- Two 3.5mm Audio: 1x Stereo out, 1x microphone in
- RS232 Serial
- RJ-45 Ethernet 10/100
- 2x USB 2.0 (white)
- 2x USB 2.0 Power Ports (Black providing up to 1AMP)
- 1x Software/Driver CD
Power and USB to host provided.
Requires a USB 1.1 to function however USB 2.0 is required for smooth video functionality.
Windows 2000 SP2 and above, Windows XP SP1 and above, Windows Vista and Windows 7 are supported.
Was £19.99 Inc. VAT
Only £9.98 inc VAT.
ORDER NOW
OCZ Vertex 2E 240GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE240G) @ £249.98 inc VAT
- Capacity: 240GB
- Warranty: 3 Years
Was £269.99 Inc. VAT
Only £249.98 inc VAT.
ORDER NOW
OCZ Vertex 2E 120GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE120G) @ £134.99 inc VAT
- Capacity: 120GB
- Warranty: 3 Years
- OCZACSSDBRKT2
Was £148.99 Inc. VAT
Only £134.99 inc VAT.
ORDER NOW
OCZ RevoDrive3 120GB PCI-E SSD - (RVD3-FHPX4-120G) @ £299.99 inc VAT
The OCZ RevoDrive 3 PCI-Express Solid State Drive Series was designed with power users and multimedia designers in mind and gives enthusiasts the cutting-edge storage they crave. Eliminating the SATA bottleneck, the PCIe-based Revo3 delivers ground-breaking 1GB/s of bandwidth and 130,000 4KB random write IOPS making this an ideal SSD for high performance applications, multimedia, and workstations. Along with unprecedented performance, the Revo3 features OCZ’s proprietary Virtualized Controller Architecture (VCA) 2.0 which provides features including TRIM support and SMART data monitoring, something previously unheard of with PCIe solutions. In addition, the Revo3’s SuperScale storage accelerator enables scalable SSD performance and significantly reduces the host CPU burden inherent to competing PCIe storage offerings. The RevoDrive 3 series is a premium feature rich storage solution that delivers superior performance and reliability through innovative design.
- Capacity: 120GB
- Controller: Dual SandForce SF-2281 (RAID)
- Maximum Read: 1000MB/sec
- Maximum Write: 900MB/sec
- Max I/O Per Second (IOPS): 130,000 IOPS (4KB File)
- Interface: PCI-Express x4
- Warranty: 3 Years
Was £319.99 Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Roccat Kave 5.1 Surround Sound Headset @ £61.98 inc VAT
nonl2br
<br>
A Desert Eagle isn't worth its fancy name, if you don't know where to aim. Imagine your advantage within the heat of the battle when you exactly hear where your opponents are before you can actually see them. Knowing the position of your enemy is half the frag. Realistic 3D surround sound makes you locate your opponents easily by the noise they generate. The desktop control enables you to adjust to situations quickly with sound and microphone mute buttons and volume control for different channels. <br>
<br>
- Real 5.1 Surround sound with speakers aligned at a 12° angle<br>
- Microphone with mute LED fully rotatable and completely removable<br>
- Tip’N’Control desktop remote for central management of all volume functions<br>
- Dual sound-profile with movie and game settings<br>
- Solid aluminium hinges enabling heavy duty use<br>
- Hand-sewn comfortable earcups featuring external noise cancelling<br>
- Adjustable vibration unit for a realistic gaming experience <br>
- Headband with three pads for equal weight distribution<br>
- Easy to carry folding and compact design <br>
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/125bfd1f2f2cc9251cc512dfde5e4fb1.jpg">
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/f620e869ce025933aeef18e4d0fd3894.jpg">
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/798d360d6701787365c7266f8cf96fbe.jpg">
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/48545abd6c12c63d38c082c343da0099.jpg">
<br>
<script type="text/css">
#youtube {
float:right;
margin-left: 50px;
</script>
<div id="youtube">
<iframe width="640" height="390" src="http://www.youtube.com/embed/yEyXafzsrB0" frameborder="0" allowfullscreen></iframe>
</div>
Was £64.98 Inc. VAT
Only £61.98 inc VAT.
ORDER NOW
Plantronics GameCom 367 Gaming Headset (79732-05) @ £16.98 inc VAT
The closed-ear GameCom 367 gaming headset delivers an immersive audio experience with 60mm stereo speakers and specially designed earpods that redistribute pressure for maximum comfort. When you’re ready to fire off orders, unveil the hidden, noise-canceling mic boom to strategize clearly with team members. Responses coming in? Adjust audio levels using in-line volume and mic mute controls. When you’re done, rotate and tuck the mic boom inside the headset - then let your score do the talking. This Plantronics headset is rugged, military-like design and extra-strength cables keep your hardware hardcore - game after game after game.
- Closed-ear headset delivers an immersive audio experience.
- Concealed mic boom stays hidden until you’re ready to use it.
- Specially designed ear pods redistribute pressure for maximum comfort.
- In-line volume and mic-mute controls allow for easy audio adjustment.
- Noise-cancelling microphone lets you communicate clearly.
- Rugged, military-like design and extra-strength cables make your hardware hardcore.
Was £19.98 Inc. VAT
Only £16.98 inc VAT.
ORDER NOW
Plantronics GameCom 777 USB 7.1 Surround Sound Headset @ £41.98 inc VAT
This open-eared headset with 7.1 Dolby Headphone technology gives you an unparalleled audio advantage that lets you hear your opponents before you see them. Connect with the Dolby USB sound card for a true 7.1 experience. But if needed, an analogue connection is also provided. Stay comfortable with a lightweight frame and specially designed ear pods that redistribute pressure. When you’re ready to fire off orders, unveil the hidden, noise-cancelling mic boom to strategize clearly with team members. Responses coming in? Adjust audio levels using in-line volume and mic-mute controls.
- Dolby Headphone technology delivers a 5-channel audio experience.
- Dolby USB sound card is the only way to get the 7.1 experience. If needed, an analog connection is also provided.
- Open-ear design keeps you connected to the game and your surroundings.
- Rugged, military-grade design and extra-strength cables make your hardware hardcore.
Was £47.98 Inc. VAT
Only £41.98 inc VAT.
ORDER NOW
Speedlink Spes Clip-On Metal Microphone (SL-8691-SBK) @ £5.99 inc VAT
The microphone is attractively designed and is extremely practical. The noise-suppression system filters out bothersome background noises and makes internet chat easy and uncomplicated. Furthermore, the clothing clip allows you to clip the mic anywhere you like.
- Lots of freedom of movement thanks to the 2.4m cable
- You'll hardly notice you're wearing the mic thanks to it's low weight
- Easy to attach to clothing thanks to the clip
- Highly sensitive microphone featuring noise suppression
- Robust design made from black metal
Was £6.98 Inc. VAT
Only £5.99 inc VAT.
ORDER NOW
OcUK HD 2 Megapixel Webcam Pearl - Black (W250) @ £14.99 inc VAT
The new award winning OcUK HD webcam stands out because of its stylish, deviating design and the good value for money. The webcam is available in 8 different colour settings. Thanks to the 2 MP sensor and the high-quality lens consisting of 5 elements with wide-angle position the user can enjoy razor sharp detailed pictures and moving images in HD quality. The adjustable stand offers the possibility of placing or hanging the webcam on or from the monitor or notebook. The plug & play USB webcam is equipped with a snapshot button and built-in microphone. Moreover, the webcam works with all known Instant Messaging applications, like Skype™, MSN™ etc.
- Built-in microphone
- Snap shot button
- 1600 x 1200 Sensor resolution
- Light exposure control
- USB powered
- LED indicators
- Face tracking
- PC / MAC
Was £16.98 Inc. VAT
Only £14.99 inc VAT.
ORDER NOW
Synology Diskstation DS110J Gigabit Ethernet Network Attached Storage Enclosure @ £113.98 inc VAT
The Synology Disk Station DS110j is designed to provide a cost-effective file storage and backup solution. The system firmware, Synology Disk Station Manager 2.2, delivers rich features for multimedia enjoyment, worry-free backup and file sharing across your network.
- Easy to use
- DLNA Certified
- 2.5" and 3.5" HDD Support
- Cool and Quiet
Was £116.98 Inc. VAT
Only £113.98 inc VAT.
ORDER NOW
TP-Link 300Mbps Wireless-N USB Adapter (TL-WN821N) @ £12.49 inc VAT
The TL-WN821N Wireless N USB Adapter complies with IEEE 802.11n, IEEE 802.11g, and IEEE 802.11b standards. Wireless transmission rates can reach up to 300Mbps. The adapter employs MIMO technology and has internal Intelligent Antennas providing even better wireless performance, transmission rates, stability and coverage. At the same time, CCA technology automatically avoids channel conflicts using its channel selection feature. This product supports 64/128-bit WEP encryptions, as well as WPA/WPA2 and WPA-PSK/WPA2-PSK encryptions and mechanisms in addition to the adapter’s QSS (Quick Secure Setup) feature, allowing users to quickly and easily setup wireless security. This product can also simultaneously operate bandwidth intensive applications such as voice, and video. Applications using a lot of bandwidth that are sensitive to interruptions such as voice and video applications are given priority in order to assure quality. It also works well with other 11g and 11n protocol wireless products.
- 300M Wireless transmission rate
- MIMO technology with stronger signal penetration strength, wider wireless coverage, providing better performance and stability
- CCA technology automatically avoids channel conflicts using its channel selection feature
- Compatible with 11g and 11b equipment, Intel Centrino Compatibility tested
- Supports Sony PSP for online game
Was £12.98 Inc. VAT
Only £12.49 inc VAT.
ORDER NOW
TP-Link AV200 200Mbps Mini Powerline Starter Kit (TL-PA211KIT) @ £38.99 inc VAT
nonl2br
<b>What This Product Does</b><br>
TP-LINK's powerline adapter TL-PA211 takes advantage of your home's existing electric wires to transfer data while transferring traditional power. That means, with no additional wiring required, users can simply plug the TL-PA211 into existing power sockets and establish networking infrastructure in a flash. With high-speed data transfer rates of up to 200Mbps, you can enjoy HD video streaming, online gaming, VoIP or any other high bandwidth intensive tasks all.<br><br>
<img src="http://www.tp-link.com/Resources/UploadFiles/Image/products/overview/PLC/nonewwirespa211.jpg"><br><br><br><br>
<b>Super Small Design</b><br>
With the new ultra-compact housing design, TP-LINK TL-PA211 is much smaller than most other 200Mbps Powerline Products. At just 30mm thick and with its high quality, elegant white shell, it almost blends in completely in front of any power outlet and additionally can be placed anywhere in the room.<br><br>
<img src="http://www.tp-link.com/Resources/Up...uct Features/[Features]super small design.jpg"><br><br><br><br>
<b>Up to 200Mbps, 300 Meters</b><br>
With advanced HomePlug AV technology, TL-PA211 provides users with stable, high-speed data transfer rates of up to 200Mbps on a line length of up to 300 meters. Together with its built-in Qos and powerful AES encryption, the TL-PA211 is a great choice for a whole home solution to connect all network compatible devices--from computers and game consoles to set-top boxes for IPTV to printers and NAS hard drives.<br><br>
<img src="http://www.tp-link.com/Resources/UploadFiles/Image/products/overview/PLC/PA211022.jpg"><br><br><br><br>
<b>Twin Pack Design</b><br>
The PLC connection is transmitting the data through the electric wire between two outlets, so it at least requires two PLC adapters pluged into the outlet to transform the data streaming. With twin pack design, the starter kit ensures to establish a powerline network for the first time.<br><br><br><br>
<b>Reduces Power Consumption Up to 65%</b><br>
The TL-PA211, a new-generation Powerline Adapter, with its logical practical product design and sophisticated Power-Saving Mode, it now consumes less power when compared with existing Powerline Adapters. When there is no data transmission or reception occurs over a certain period of time, it will automatically switch from its regular "Working" Mode to "Power-Saving" Mode that will reduce the energy consumption by up to 65%.<br><br><br><br>
<b>Pair Button for Easy Network Security</b><br>
Simply by pushing the Pair button on the adapters, users can set up a hassle-free Powerline network within minutes, complete with 128-bit AES encryption for network security and data protection.
It's that simple!
1. Plug the adapter into the power outlet
2. Connect the device via the network cable to the adapter
3. Press the encryption buttons—and you're done<br><br><br><br>
<img src="http://www.tp-link.com/Resources/Up...ct Features/[Features] PLC 'Pair' Button .jpg"><br><br><br><br>
- HomePlug AV standard compliant, high-speed data transfer rates of up to 200Mbps <br>
- Twin Pack design helps establish a powerline network initially <br>
- Super small design with a new exterior, blends in completely in front of any power outlet <br>
- No new wires, Easy Plug and Play operations, No configuration required <br>
- <b>UK Standard Plug <br></b>
- Patented Power-Saving Mode automatically reduces power consumption by up to 65%<br><br>
Was £39.98 Inc. VAT
Only £38.99 inc VAT.
ORDER NOW
Seagate Freeagent Goflex TV 1080p HD Media Player @ £55.98 inc VAT
nonl2br
Enjoy all of your movies, music and photos on your TV, in full 1080p HD with vibrant surround sound. The GoFlex TV HD media player makes it easy to access, view and play your digital media files on your home entertainment system. And because it works with just about every format available, you can enjoy all of your entertainment on your TV or in your home theater - from Flip videos to photos to DVDs - regardless of resolution.<br><br>
- Plays MKV File format<br><br>
- Plays your content on your TV directly from your GoFlex ultra-portable drive, or accesses your content from your digital camera, flash drive or other external drives (either Windows® or Mac®) through the additional USB port<br><br>
- Hooks up to your TV in seconds via a digital HDMI® cable
Connects to your PC or Mac computer, home network and the Internet via Ethernet or wirelessly with the optional Wi–Fi Adapter<br><br>
- Lets you watch streaming media direct from the Internet, your computer and your USB devices<br><br>
- Displays all the content that is included with your DVDs, including menus, commentator tracks and subtitles<br><br>
- Makes navigating and accessing your digital media files easy with the included remote control and intuitive on–screen menus<br><br>
- Creates exciting slideshows with your own music track for enjoying memories with friends and family
Fits seamlessly within your entertainment centre<br><br>
<b>Flexible options for accessing your content</b><br><br>
- Access content directly from your GoFlex or GoFlex Pro ultra-portable drive through the integrated GoFlex ultra-portable drive slot, or any USB external drive through the USB ports<br><br>
- Access content from your network through a GoFlex Net media sharing device, in-home media server, or network-connected PC or Mac<br><br>
<b>Access the Internet services you use every day</b><br><br>
Now you can enjoy some of the most popular Internet sites right on your TV, including:<br><br>
<img src="http://www.seagate.com/images/ProductPhoto/FreeAgent/freeagent-goflex/youtube-logo-86x57.jpg"><img src="http://www.seagate.com/images/ProductPhoto/FreeAgent/freeagent-goflex/vtuner-logo-90x60.jpg"><img src="http://www.seagate.com/images/ProductPhoto/FreeAgent/freeagent-goflex/flicker-logo-86x57.jpg"><br><br>
- YouTube<br>
- Paramount<br>
- vTuner<br>
- Mediafly<br>
- Picasa<br>
- Flickr<br>
- Video Feeds (RSS)<br>
- Text Feeds (RSS)<br>
- Finance Widget<br>
- Weather Widget<br><br>
<b>What's included?</b><Br><br>
- GoFlex TV HD Media Player<br>
- AV, component and Ethernet cables<br>
- Power supply<br>
- Remote control<br>
- 1-year limited warranty<br>
Was £64.98 Inc. VAT
Only £55.98 inc VAT.
ORDER NOW
Sennheiser PC 360 Gaming Headset @ £129.98 inc VAT
Developed with the top eSport team mTw, the PC 360 is a new flagship for pro gaming. It has an open design that makes sure you keep a cool head – and delivers a natural listening experience so you can stay in touch with your surroundings. Thanks to the ultracomfortable ear cups, pro microphone and quick-access controls, it’s also the only headset you’ll ever
need for music, videos and skyping.
Professional gaming with a cool head - the open design lets air in and delivers a natural listening experience;Sennheiser sound – excellent hi-fi sound and acoustics from your games, music, movies and internet calls;Noise canceling clarity – the microphone reduces ambient noise for crystal-clear conversations;All-in-one headset – when you want to enjoy movies or music, just move the microphone out of your way;Practical microphone mute – automatically mute the microphone by raising the boom.
- Cable length: 3m / 9.8ft
- Connector sockets: 2 x 3.5mm for desktop/laptop
- Weight: 300g
Frequency response:15–28,000Hz
- Sound pressure level: 112dB
- Microphone:
Frequency response: 50–16,000Hz
- Pick-up pattern: Noise canceling
Sensitivity: -38dBV/PA
Was £134.98 Inc. VAT
Only £129.98 inc VAT.
ORDER NOW
Logitech C510 HD 720p 8 Megapixel Webcam (960-000594) @ £28.98 inc VAT
With HD 720p video calling and one-click HD upload to Facebook, now you can share your HD world—anywhere, anytime.
- HD video calling (1280 x 720 pixels) with recommended system
- Video capture: Up to 1280 x 720 pixels
- Logitech More HD technology
- Photos: Up to 8 megapixels (software enhanced)
- Built-in mic with Logitech RightSound™ technology
- Hi-Speed USB 2.0 certified (recommended)
- Universal clip fits laptops, LCD or CRT monitors
- 2-year limited hardware warranty
Basic requirements:
- 1 GHz
- 512 MB RAM or more
- 200 MB hard drive space
- Internet connection
- USB 1.1 port (2.0 recommended)
- Windows® XP (SP2 or higher), Windows Vista® or Windows® 7 (32-bit or 64-bit)
For HD 720p video calling and recording:
- 2.4 GHz Intel® Core™2 Duo
- 2 GB RAM
- USB 2.0 port
- 1 Mbps upload speed or higher
- 1280 x 720 screen resolution
Was £31.98 Inc. VAT
Only £28.98 inc VAT.
ORDER NOW
Datawrite CD-R x52-Speed 700MB - 100 Discs @ £8.50 inc VAT
CD-R - 700MB - 52x Write Speed - Cakebox - 100 Pack
- Manufacturer: Datawrite
- Max Write Speed: 52x
- Max Storage Data: 700MB
- Max Storage Time: 80min
Was £8.99 Inc. VAT
Only £8.50 inc VAT.
ORDER NOW
Intel Core i3 550 3.20GHz (Clarkdale) (Socket LGA1156) - Retail @ £89.99 inc VAT
The wait is over - now everyone can move up to smart performance. As the first level in Intel’s new processor family, the new 2010 Intel Core i3 processor is the perfect entry point for a fast, responsive PC experience. The new 2010 Intel Core i3 processor also features Intel Hyper-Threading Technology, which enables each core of your processor to work on two tasks at the same time, delivering the performance you need for smart multitasking. Don’t let too many open applications slow you and your PC down. Get smart performance now.
- Lithography Process: 32nm
- Cores: 2
- Threads: 4
- Frequency: 3.20GHz
- Integrated Graphics Frequency: 733MHz
- Cache: 4MB Shared L3
- Memory Controller: Dual Channel DDR3 800/1066/1333MHz
- TDP: 73w
- Socket: LGA1156
Was £94.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
AMD Green Baseball Cap @ £1.19 inc VAT
Be the envy of the world with our exclusive limited time only AMD baseball cap. This cap is great as one size fits all, as it includes a unique sizing strap at the rear of the product. This will surely help increase your 'sex appeal', great for getting a girlfriend/boyfriend, especially now the warm weather is arriving soon. You will be the envy of everyone on the beach.
This cap will do it all.....
Was £1.99 Inc. VAT
Only £1.19 inc VAT.
ORDER NOW
AMD Athlon II X2 Dual Core 265 3.30GHz (Socket AM3) - Retail @ £47.99 inc VAT
AMD Athlon II Dual-Core processors put the power of dual-core technology on the desktop. Dual-core processors contain two processing cores, residing on one chip, that perform calculations on two streams of data to increase efficiency and speed while running multiple programs and the new generation of multi-threaded software. AMD Athlon II Dual-Core processors deliver TRUE multi-tasking, allowing users to switch from one program to another without always pausing for the computer to catch up and reducing annoying processing pauses.
- Dual-core Technology
- 3.30Ghz clock speed (AM3 Socket)
- 2.0MB L2 Cache
- Cool & Quiet Technology for Energy Efficiency
- Enhanced Virus Protection
- 64-bit Technology
- Hyper Transport Technology
- Virtualization technology
- 3yr Warranty
- Retail Boxed with Heatsink & Fan
Was £51.98 Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
AMD Phenom II X4 Quad Core 965 Black Edition "125W Edition" 3.40GHz (Socket AM3) - Retail @ £95.99 inc VAT
The AMD Phenom II processors are the most advanced processors for true multitasking offering true quad-core design. AMD Phenom II processors deliver virtually uninterrupted information flow between processor cores, main memory and graphics and video accelerators for amazingly rapid system response and phenomenal system performance. AMD Phenom II processors deliver unbeatable multi-core value with superior high definition computing, advanced multitasking performance, and innovative, energy efficient solutions.
- 3.40GHz clock speed
- 2MB L2 cache
- 6MB L3 cache
- DDR3-1333 support
- 45nm process technology (125W Edition)
- True Multi-core Processing
- Direct Connect Architecture
- Integrated Dual-Channel Memory Controller with up to DDR3-1333 support
- HyperTransport 3.0
- AMD Balanced Smart Cache
- AMD Wide Floating Point Accelerator
- AMD Memory Optimizer Technology
- AMD Digital Media Xpress 2.0
- AMD Virtualization with Rapid Virtualization Indexing
- Cool‘n’Quiet 3.0 technology
Was £109.99 Inc. VAT
Only £95.99 inc VAT.
ORDER NOW
AMD Phenom II X4 Quad Core 980 Black Edition "140W Edition" 3.70GHz (Socket AM3) - Retail @ £119.99 inc VAT
3DNow! instructions set, PowerNow! technology, HyperTransport technology, AMD64 technology, integrated memory controller, Enhanced Virus Protection, AMD Cool'n'Quiet Technology, AMD Virtualization, AMD CoolCore Technology
- 3.70GHz clock speed
- 2MB L2 cache
- 6MB L3 cache
- DDR3-1333 support
- 45nm process technology (140W Edition)
Was £139.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
AMD Phenom II X6 Six Core 1055T 2.80GHz (Socket AM3) - Retail @ £113.99 inc VAT
Six-core processing power for massive performance headroom - at the price of the competition's quad-core products. The AMD Phenom II X6 processor features AMD Turbo CORE technology that enables unlocked performance for cutting-edge applications, and dynamically switches to three cores for raw speed. Direct Connect Architecture that enables leading-edge performance and responsiveness, even on the most demanding applications. HyperTransport 3.0 Technology enables incredible system agility for 3D gaming and ultra-high resolution entertainment. AMD Dedicated Multi-cache that extends the memory bandwidth for intensive applications, delivering fast performance per core.
- Six Core Technology
- 2.80GHz Clock Speed
- 4.0 GT/s System Bus
- AM3 Socket
- 3MB L2 Cache
- 6MB L3 Cache
- 64-Bit Technology
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan Included
Was £119.99 Inc. VAT
Only £113.99 inc VAT.
ORDER NOW
AMD Phenom II X6 Six Core 1090T Black Edition 3.20GHz (Socket AM3) - Retail @ £125.99 inc VAT
- Multiplier Unlocked
- 3.20GHz Clock Speed
- AM3 Socket
- 3MB L2 Cache
- 6MB L3 Cache
- 64-Bit Technology
- 3 Year Warranty
Was £134.99 Inc. VAT
Only £125.99 inc VAT.
ORDER NOW
AMD Phenom II X6 Six Core 1100T Black Edition 3.30GHz (Socket AM3) - Retail @ £143.99 inc VAT
- 3.30GHz Clock Speed
- AM3 Socket
- 3MB L2 Cache
- 6MB L3 Cache
- 64-Bit Technology
- 3 Year Warranty
Was £149.99 Inc. VAT
Only £143.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport 12GB (3x4GB) DDR3 PC3-12800C10 1600MHz Triple Channel Kit (BL3KIT51264BA160A) @ £65.99 inc VAT
Overclockers UK brings you one of the most notable names in system memory today.
These high performance modules are engineered to deliver the fastest, most reliable memory for gaming and performance enthusiasts. Upgrading has never been this easy!
If you‘re new to performance memory and like what Ballistix has to offer, the Crucial Ballistix Sport Series is a great place to start. This line was created for mainstream users and general enthusiasts. They feature heat spreaders for thermal performance along with standard timings and voltages, making this reliable, quality module ideal for maximum stability and compatibility.
This memory allows you to plug it into your system and get back in the action for an affordable and easy upgrade for any X58 based system.
- PC3-12800 1600MHz CAS 10-10-10-28
- Designed for Entry-Level & Mainstream Users
- Integrated Heat Spreaders
- 1.5v VDIMM
- Triple Channel Memory Kit, Ideal for X58 Based Systems
- Limited Lifetime Warranty
Was £77.99 Inc. VAT
Only £65.99 inc VAT.
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C8) @ £71.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 8-8-8-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 8-8-8-24 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Was £79.99 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) @ £59.99 inc VAT
This 8GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 8GB memory kit (2 x 4GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 9-9-9-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
Was £67.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) @ £23.99 inc VAT
This 4GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 4GB memory kit (2 x 2GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- XMS Heat Spreader
- Sandybridge compatible (use sub 1.60v)
Was £27.98 Inc. VAT
Only £23.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel Kit (BL2KIT25664BA1339) @ £22.79 inc VAT
This memory allows you to plug it into your system and get back in the action for an affordable and easy upgrade, ideal for any Intel Sandybridge or AMD AM3 based system.
- PC3-10666 1333MHz CAS 9-9-9-27
- 1.5v VDIMM
- Dual Channel Memory Kit, Ideal for any Intel or AMD Dual Channel based system
Was £23.99 Inc. VAT
Only £22.79 inc VAT.
ORDER NOW
OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel Kit (OCZ3G1333LV4GK) @ £22.79 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the upcoming Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements at 1333MHz.
Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for the midrange desktops.
OCZ DDR3 PC3-10666 Gold Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1333MHz DDR3
- CL 9-9-9-20 (CAS-TRCD-TRP-TRAS)
- Gold Z3 XTC Heatspreader**
- Lifetime Warranty
- 1.55-1.65 Volts
- 240 Pin DIMM
Was £25.99 Inc. VAT
ORDER NOW
Kingston HyperX 4GB (2x2GB) DDR2 PC2-8500C5 1066MHz Dual Channel (KHX8500D2K2/4G) @ £53.99 inc VAT
HyperX DDR2 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. HyperX DDR2 offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR.
- Size: 4GB Kit (2x2GB)
- Speed: 1066MHz
- Timing: 5-5-5-15
- Format: 240-Pin DDR2 DIMM
- 2.1 Volts
- Lifetime Warranty
Was £59.99 Inc. VAT
Only £53.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport 4GB (2x2GB) DDR2 PC2-6400C5 800MHz Dual Channel Kit (BL2KIT25664AA80E) @ £47.99 inc VAT
This memory allows you to plug it into your system and get back in the action for an affordable and easy upgrade, ideal for any Intel or AMD Dual Channel based DDR2 system.
- PC2-6400 800MHz CAS 5-5-5-15
- 1.8v VDIMM
- Dual Channel Memory Kit, Ideal for any Intel or AMD Dual Channel based DDR2 system
Was £59.99 Inc. VAT
ORDER NOW
HIS ATI Radeon HD 6950 IceQ X Turbo 2048MB GDDR5 PCI-Express Graphics Card with FREE Dirt3 PC Game @ £199.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Core Clock: 840MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5120MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 450W minimum PSU recommended
- Warranty: 2 Years
- Supplied with Dirt3 Download Voucher (Subject availability)
Was £224.99 Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
XFX ATI Radeon HD 6870 Black Edition 1024MB GDDR5 PCI-Express Graphics Card with Dirt3 & Shogun 2 PC Games @ £131.99 inc VAT
With the 6000 series, XFX is literally putting you in the game. The AMD Radeon HD 6870 is 3-D ready and one of the first HDMI 1.4a and DisplayPort 1.2 solutions for Stereoscopic 3-D on the market.
The AMD Radeon HD 6870 ushers in a new era of gaming that takes users to an entirely new level. The AMD 3-D experience is truly immersive and seamless. AMD has also teamed up with other Open 3-D ecosystem partners to provide consumers with more choice, more innovation and lower cost.
Along with the new series XFX debuts the 3E Trilogy, incorporating AMD Eye-Definition (utilizing AMD’s HD3D technology & DirectX 11 for explosive performance and stunning effects), AMD Eyefinity (which supports multi-display gaming) and AMD Eyespeed (improves video image quality and application performance for amazing visuals) technologies.
- Core Clock: 940MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4600MHz (Effective)
- Memory Bandwidth: 135.6GB/s
- Processing Cores: 1120
- HDCP Capable
- OpenGL 3.2 Support
- ATI Avivo HD
- Warranty: 2 Years
- Supplied with Dirt3 & Shogun 2: Total War PC Games (Subject to availability)
Only £131.99 inc VAT.
ORDER NOW
Asus ATI Radeon HD 6670 SILENT EDITION 1024MB GDDR3 PCI-Express Graphics Card @ £64.79 inc VAT
Packed with the latest GPU technologies, the Radeon™ HD 6670 graphics processors offer advanced video and display features, Eyefinity multi-display technology, as well as AMD’s 2nd generation support for DirectX® 11 to give you the ultimate in “visual immersion” for your PC.
The flattened copper heat-pipe contacts GPU directly for 0dB cooling experience. Super Alloy Power technology uses special alloy formula in critical power delivery components for a 15% performance boost, 35°C cooler operation and 2.5 times longer lifespan. Intelligent system monitoring for efficient overclocking with an intuitive slide bar. Real-time overclocking, benchmarking and video capturing in any PC game!
Features:-
- Effective and quiet DirectCU Silent 0dB thermal design
- Pump up graphics performance with Super Alloy Power that delivers 15% Performance boost, 2.5 longer lifespan, 35C cooler operation
- Core Clock: 800MHz
- Memory Clock: 1800MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 480
- Display Connectors: 1 Dual-Link DVI-I, 1 HDMI
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Was £67.99 Inc. VAT
Only £64.79 inc VAT.
ORDER NOW
Asus ATI Radeon HD 6450 SILENT EDITION 1024MB GDDR3 Low Profile PCI-Express Graphics Card @ £35.99 inc VAT
Packed with the latest GPU technologies, the Radeon™ HD 6450 graphics processor is a next-generation visual upgrade that delivers Eyefinity multi-display technology, HDMI 1.4a for stereoscopic (3D) displays, Displayport 1.2 as well as 2nd generation support for DirectX 11 for the most versatile solution for everyday computing.
Silent passive cooling runs 0dB quiet, perfect for hushed gaming and multimedia joy. Ideal for home theater PCs and multimedia centers with low profile design and high power efficiency. Reduces 66%* of electromagnetic interference both given off and received by the card - resulting in a stable signal, clearer screen display and a safer, healthier computing environment. Intelligent system monitoring for efficient overclocking with an intuitive slide bar. Real-time overclocking, benchmarking and video capturing in any PC game! Optimizes colors in various entertainment scenarios with five special modes — standard, game, scenery, night view and theater.
Features:-
- SILENT
- Core Clock: 625MHz
- Memory: 1024MB GDDR3
- Memory Clock: 1200MHz (Effective)
- Memory Interface: 64-Bit
- Processing Cores: 160
- HDCP Capable
- ATI Avivo HD
- Dimension 146(L)x22(W)x94(H) mm Size.
- Low Profile
- Warranty: 3 Years
Was £39.98 Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
Asus GeForce GTX 580 Matrix 1536MB GDDR5 PCI-Express Graphics Card @ £401.99 inc VAT
The Republic of Gamers consists only the best of the best. We offer the best hardware engineering, the fastest performance, the most innovating ideas, and we welcome the best gamers to join in.
In the Republic of Gamers, mercy rules are only for the weak, and bragging rights means everything. We believe in making statements and we excel in competitions. If your character matches our trait, then join the elite club, make your presence felt, in the Republic of Gamers.
TweakIt provides users with flexible overclocking control even when running benchmark programs! The “+” and “-” button puts overvolting adjustments in the user´s fingertips, offering them performance optimization options during game play to gain the competitive edge.
ProbeIt takes the guesswork out of locating the graphics card´s measurement points, identifying them clearly in the form of 6 sets of detection points so you´ll know exactly where to get quick yet accurate readings using a multimeter.
Safe Mode button resets the graphics card back to default frequencies & BIOS. This is a very welcomed feature for hardware enthusiasts, think of it like the "Clear CMOS" on a motherboard.
Built with exclusive 19-phase Super Alloy Power technology, the MATRIX GTX 580 guarantees much greater overclocking headroom, with a 15% performance boost, 2.5 times longer lifespan and 35°C cooler operation than the reference card design.
Cooling is well taken care of by exclusive DirectCU II technology that puts copper heat pipes in direct contact with the GPU. The pipes efficiently transfer heat through two massive fans that deliver 600% more airflow than the reference design, resulting in a 20% lower operating temperatures.
A multicolored LED MATRIX indicator at the rear of the ROG MATRIX GTX 580 gives an instant and easy-to-understand visual display of the current GPU load.
Features:-
- Overclocking hardware tools, TweakIt and ProbeIt are directly embedded onto the graphics card firmware, while a Safe Mode button offers an easy reset option worry-free hardware overclocking.
- All new GPU Tweak provides professional graphics overclocking for PC enthusiasts
- 19-phase Super Alloy Power technology provides more headroom for overclocking with a 15% performance boost, reduced running temperatures and prolonged product lifespan
- Award-winning DirectCU II thermal technology with sound-dampened dual fans provides 600% greater airflow and 20% cooler performance than the reference design.
- Core Clock: 816MHz (Fermi GF110) (Upto 950MHz core possible)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1536MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 512
- Shader Clock: 1632MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters), 1x DisplayPort.
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
Was £419.99 Inc. VAT
Only £401.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 580 "GOOD Edition" 1536MB GDDR5 PCI-Express Graphics Card @ £359.99 inc VAT
The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580. Experience blockbuster games like Call of Duty®: Black Ops and Tom Clancy's H.A.W.X® 2 in their full glory with everything cranked to the max. Not only does the NVIDIA GeForce GTX 580 rip through the latest games, it also runs quieter than the previous generation. And as you have come to expect from the GeForce GTX GPU, the GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX and SLI. With all these features and more, it is easy to see how the NVIDIA GeForce GTX 580 obliterates the competition.
Features:-
- Core Clock: 783MHz (Fermi GF110)
- Memory Clock: 4020MHz (Effective)
- Shader Clock: 1566MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Was £371.99 Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 560Ti OC 1024MB GDDR5 PCI-Express Graphics Card @ £182.39 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560Ti - arm yourself for battle.
Features:-
- Core Clock: 900MHz
- Memory Clock: 4000MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 384
- Shader Clock: 1800MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £199.99 Inc. VAT
Only £182.39 inc VAT.
ORDER NOW
MSI GeForce 8400GS 512MB SILENT GDDR3 "Low Profile" PCI-Express Graphics Card @ £23.99 inc VAT
co-development by MSI and Rivatuner, MSI releases the ultimate graphics card utility “Afterburner”. This utility enables all MSI graphics cards users to boost performance and to monitor all kinds of critical information in real-time. Afterburner is a completely free utility which is compatible with almost all MSI graphics cards.
MSI StarOSD is a very helpful utility for the avid PC gamers. Users can easily access the StarOSD to adjust the contrast, brightness, overclocking and temperature according to each user’s individual preference.
Note:Star OSD function that be used on different games has some difference cause the game different design.
MSI Live Update 4 is a single utility software that automatically checks BIOS, driver and utility updates and installs for you , which can save your time for searching and lower the risk while updating.
The HDCP provides a robust, cost-effective and transparent method for transmitting and receiving digital entertainment similar to DVI/HDMI-compliant digital displays. HDCP encrypts the date transmitted between the DVI/HDMI connector on the graphics adapter and the display.
MSI DOT Express Technology is the most advanced Dynamic Overclocking Technology Express enabling supreme overclocking, cooling and de-noise performance. It is an advanced overclocking engine, designed to deliver up to 10% extra performance and greatly enhances the synchronized GPU & DDR performance.
Dual-link DVI convertible output supports Video signal through DVI to HDMI interface, which drivers resolution of a digital display up to 1920x1200 or higher.
Both support the latest specifications of Blu-ray and HD DVD(High Definition DVD). It comes with the latest GPU and DDRIII superior processing performance in which users can easily enjoy the high-definition video of 1920x1080(1080p/i).
NVIDIA® CUDA™ technology is the world’s only C language environment that enables programmers and developers to write software to solve complex computational problems in a fraction of the time by tapping into the many-core parallel processing power of GPUs. With millions of CUDA™-capable GPUs already deployed, thousands of software programmers are already using the free CUDA™ software tools to accelerate applications—from video and audio encoding to oil and gas exploration, product design, medical imaging, and scientific research.
Was £25.99 Inc. VAT
ORDER NOW
Samsung S22A350H 22" Widescreen LED Monitor - Glossy Black @ £143.99 inc VAT
Brilliant colours and amazing picture clarity just aren’t enough these days. The Samsung SA350 LED monitor recognises today’s real needs and has introduced several new energy saving modes that let you enjoy the best visual experience while also conserving energy. With a host of Eco features, including the automatic Eco light sensor and the Eco motion sensor, reducing your footprint has never been so easy. The Eco motion sensor automatically turns your monitor off/on so that it is ever unnecessarily left on, the Eco light sensor automatically optimises your screen brightness for visibility and energy savings. Add to this the Samsung Magic features for unbelievable picture clarity, and you have a monitor that is loaded with huge potential and ready to transform the way you watch content.
Experience amazing new levels of colour, brilliance and picture quality through the very latest in Mega Dynamic Contrast Ratio. Samsung SA350 monitors deliver images so real-to-life that it will transform your whole viewing experience. Packed with breathtaking 5,000,000:1 contrast ratio, the highest level currently available, the SA350 monitor ensures that blacks are at their absolute darkest and (with pristine whites) colours are at their brightest. You will immediately notice the crystal clear picture and its unbelievable intensity. It is like an explosion of colours and leaves other screens seeming dull in comparison. So, take your viewing pleasure to the next level with Samsung Mega Dynamic Contrast Ratio – and enjoy your multimedia content with the professionalism it deserves.
Eco saving makes saving energy easy. It adjusts the brightness of your Samsung monitor based on how much energy you want to save. And with the choice of three energy saving modes (50%, 25% and Power Saving off), you can really tailor your monitor use to meet your own personal needs. Samsung’s commitment to saving energy is designed to help both you and the environment, and with up to 50% saving on consumption, you can really make a positive impact on your eco footprint. Take the effort out of saving energy and take control with Eco saving.
How do you like to watch movies? Do you like lying down on the couch? Sitting in your favorite chair? Cooking or exercising? Whether you’re standing, sitting or lying down, Samsung’s Magic Angle makes sure that the movie always takes center stage and that you’re always comfortable. This means, thanks to the 5-mode angle management, that whatever angle you watch your Samsung monitor, you will enjoy a full visual experience with amazing picture clarity. So, start seeing your favourite movies and other multimedia in total comfort and without limitations thanks to Magic Angle.
Features:-
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 50000000:1
- Brightness: 250cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x HDMI, 1x Analogue
- Warranty: 3 Years On-Site
ORDER NOW
LG D2342P 23" Passive 3D Widescreen LCD Monitor - Black @ £215.99 inc VAT
Redefine standards with the LG D42P, a full HD LED wall mountable 3D monitor, with a stylish slim design created for a new level of experience. Using its 3D player you can transform photos, home
videos or even movies, from 2D to 3D at the touch of a button. The D42P revolutionises the way you watch home content; giving you the power to watch 3D at will.
Get ready for the most Cinema 3D entertainment you're ever experienced - in the comfort of your home. Forget the heavy, uncomfortable glasses and the dizzying picture quality of conventional 3D technology. You can now enjoy what 3D was meant to be, just like at the movies. The LG Cinema 3D monitor, the standard in 3-dimensional excellence!
Features:-
- Screen Size: 23" Widescreen
- FPR 3D glasses included
- Contrast Ratio: 5000000:1
- Response Time: 5ms
- Inputs: 1x DVI-D & 1x HDMI
- VESA Compliant
Only £215.99 inc VAT.
ORDER NOW
Samsung S23A550H 23" Widescreen Ultra Thin LED Monitor - Glossy Black @ £173.99 inc VAT
Do you want the best-looking display on the market, both in terms of industrial design and image quality? How about a monitor that does more than just display content, one that simplifies your life and is eco-friendly? Samsung’s SA550 LED monitors deliver ultimate image quality, unparalleled elegance, and a suite of features that make them eco-friendly and easy to use.
You can make an artistic statement with a SA550 LED monitor because its design naturally blends subtle color gradations into the monitor frames. The bezel combines a crystal look with Samsung’s Touch of Color, and it is complemented by a transparent base. Also, the cables from the SA550 are hidden in the neck of the monitor so you always have a simple clean look.
The SA550 LED monitor has features to make it so easy to use, while helping you save energy. This monitor uses close to zero watts when it’s in power saving mode. The Eco Motion Sensor alerts the monitor when you sit down and when you walk away, automatically powering it on and off. And, the Eco Light Sensor automatically adjusts the monitor’s brightness to match the ambient lighting in a room. If the room is sunny, the picture shines brighter and in darker surroundings, the intensity is reduced. The result—reduced eye strain and smarter power consumption.
Features:-
- Contrast Ratio: 10000000:1
Was £179.99 Inc. VAT
Only £173.99 inc VAT.
ORDER NOW
ViewSonic VP2365wb 23" Premium IPS Panel Widescreen LCD Monitor @ £191.99 inc VAT
The VP2365wb is one of ViewSonic’s new LCD Professional Series monitors that utilizes the power of IPS panel technology. With IPS true colours, high contrast ratio and wide viewing angles coupled with 1920x1080 Full HD resolution, the VP2365wb is the perfect solution for designers, manufacturers, medical applications and movie production. A 4-port USB hub for cluster free connectivity, ergonomic functions with pivot, height adjust, tilt, swivel and slim bezel make the VP2365wb a feature-packed monitor.
- Screen Size: 23" IPS Widescreen
- Contrast Ratio: 1000:1
- Brightness: 300cd/m²
- Response Time: 14ms
- Viewing Angles (H/V): 178°/178°
- Inputs: 1x Analogue & 1x DVI-D
- 4-Port USB 2.0 Hub
- VESA Compliant
- Dimensions: 548.0mm x 433.0mm x 250.0mm
- Weight: 6.8kg
Only £191.99 inc VAT.
ORDER NOW
Iiyama ProLite B2409HDS 24" Widescreen LCD Monitor - Black @ £167.99 inc VAT
Iiyama's ProLite Business LCD, the B2409HDS is the latest product to follow the true HD resolution of 1920x1080. The Business Line models come with Height Adjustable and Portrait Mode base, complimented by a Slim Bezel design. The incredible 2ms Response Time and 20000:1 Contrast Ratio panel ensures vibrant images and blur free Video. Triple Input support of Analogue, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded Notebook outputs.
- Screen Size: 24" Widescreen
- Contrast Ratio: 20000:1
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Adjustable Stand
- Dimensions: 561.0mm x 413.5mm - 523.5mm x 249.0mm
- Weight: 7.7kg
Only £167.99 inc VAT.
ORDER NOW
Iiyama ProLite E2710HDS 27" Widescreen LCD Monitor - Black @ £215.99 inc VAT
The Prolite E2710HDS 27” LCD Display features a stunning 2ms Response Time and a High Definition 1920x 1080 Resolution. The 20000:1 Advanced Contrast Ratio and 400cd/m² brightness offer the user clear and vivid images, and the DVI, D-Sub and USB connections ensure compatibility across a range of devices including games consoles and work stations.
- Screen Size: 27" Widescreen
- Brightness: 400cd/m²
- VESA Compliant
- Dimensions: 642.0mm x 438.5mm x 210.0mm
- Weight: 6.9kg
Was £239.99 Inc. VAT
ORDER NOW
MSI GX660R 15.6" WLED TFT Intel I7-740QM, 6GB DDR3, 1TB HDD, ATI HD 5870 1GB GDDR5 Graphics, Win7 Home Premium 64-Bit - Black/Red @ £977.99 inc VAT
nonl2br
<img src="http://www.msimobile.com/img-overview/GX660/Topbanner.jpg" height="480" width="768" alt="GX660" /><br>
<br>
<Br>
<font size="4"><b>Key Features</b></font><br>
<br>
<b>• The latest Intel Quad Core i7-740QM 1.73GHz Processor</b><br>
• Genuine Windows 7 Home Premium<br>
• DTS Surround Sensation UltraPC<br>
• Exclusive TDE Technology<br>
• 16:9 Full HD LED Display<br>
• High-end ATi Radeon HD 5870M graphics<br>
• HDMI (High-Definition Multimedia Interface) Output<br>
• Built-in HD Webcam<br>
• 802.11 b/g/ n Wireless LAN with Bluetooth<br>
<br>
<br>
<font size="4"><font color="Blue"><b>New Level of Sound and Performance</b></font></font><br>
<font size="4"><b>MSI + Dynaudio = New Standard of Gaming Notebook</b></font><br>
<br>
<b>Dynaudio Premium Sound Technology</b><br>
<br>
The complex and interconnected elements that comprise excellent sound were painstakingly identified one by one to ascertain how to systematically develop the proper notebook technologies. After undergoing a very long process of cooperative development, Dynaudio and MSI have come up with the GX660. The four directions used to develop Dynaudio Premium Sound Technology are summarized below. For serious gamers who demand extreme audio performance, the GX660 is the best and only choice!<br>
<br>
<img src="http://www.msimobile.com/img-overview/GX660/speaker-1.jpg" align="centre" alt="GX660" /><br>
<br>
<b>Speaker Placement</b><br>
<br>
In the past, limited space on notebooks meant speaker position was always considered last, which resulted in muddled sound in notebook speakers. Because of this, speaker position was considered during the initial stages of the GX660's development to facilitate optimum audio performance and to avoid sacrificing audio quality for incorrect speaker placement.<br>
<br>
<b>EQ Tuning: Adjusted for Optimization of All Types of Sounds</b><br>
<br>
Different types of music represent distinct requirements for sound ambience. Jazz, pop, rock, or classical all possess special characteristics that affect computer game and movie sound performance and each has specific tone balance requirements. To express different types of music authentically, Dynaudio and MSI spent over 1,200 hours of continuous, repetitive testing and fine tuning of high, mid, and low range frequencies so authentic reproduction of different types of music can be achieved.<br>
<br>
<br>
<img src="http://www.msimobile.com/img-overview/GX660/inteli7" align="right" alt="" />
<font size="4"><font color="Blue"><b>Choose The Best!</b></font></font><br>
<br>
<b>Powerful Hardware Under the Hood Deliver Enhanced Horsepower and Blazing Speed</b><br>
The GX660 includes the world’s most advanced Intel® Core™ i7 quad core processor, which boasts superior multimedia performance and can retrieve data from Blu-ray disks or update online photo albums twice as fast as conventional dual core notebooks. The processor also comes with Intel’s Turbo Boost technology, allowing you to power up or down as necessary, depending on the load requirements of the task at hand.<br>
<br>
<br><img src="http://www.msimobile.com/img-overview/GX660/turbo.jpg" align="left" height="300" width="373" alt="GX660" /><br>
<br>
<br>
<b>Accelerated CPU Performance MSI’s Exclusive TDE Technology</b><br>
<br>
By overclocking the CPU and memory frequency, the TDE Technology brings more calculating speed to enhance the system performance. It benefits the video decoding/ encoding, gaming and art work designing. With MSI TDE Technology, you can experience fast-response time and efficient real-time data processing.<br>
<br>
<br>
<b>Exclusive Cooler Boost Technology</b><br>
Only one finger!! Exclusive Cooler Boost technology provides powerful cooling capabilities and receives real-time notification of the GX660's core temperature variations and fan speed.<br>
<br>
<br>
<br>
<br>
<br>
<font size="4"><font color="Blue"><b>Marvel At The Most Amazing Images Around</b></font></font><br>
<b>The ATI Radeon™ HD 5870 Graphics (with GDDR5 1GB VRAM)</b><br>
<img src="http://eu.msi.com/uploads/Image/product_img/other/nb/gx660/gx660_05.jpg" align="centre" alt="GX660" /><br>
The 1GB GDDR5 internal memory and the ATi Radeon™ HD 5870 graphics card provide a high-definition gaming experience that puts you right in the middle of the action sequences. Delivering full support for Microsoft DirectX® 11, the GPU enables richer and true-to-life graphics performance so that you can enjoy immersive games or movies.<br>
<br>
<b>16:9 Full HD* LED Backlit Display</b><br>
<img src="http://eu.msi.com/uploads/Image/product_img/other/nb/gt660/gx660_hd.jpg" align="centre" alt="GX660"/><br>
The 15.6” Full HD screen of the GX660 delivers more details of the high definition content; brings you more pleasure while playing games or watching movies.<br>
<br>
<font size="4"><b>Specifications</b></font><br>
<br>
<b>CPU</b> Intel Core™ i7-740QM 1.73GHz Processor <br>
<b>OS</b> Genuine Windows 7 Home Premium <br>
<b>Chipset</b> Intel PM55 <br>
<b>Memory</b> 6GB DDR3 1066 MHz<br>
<b>LCD Size</b> 15.6" FHD 1920*1080 TFT-LCD Display (LED Backlight) <br>
<b>Graphics</b> ATi Mobility Radeon HD 5870M <br>
<b>Graphics</b> VRAM GDDR5 1GB <br>
<b>HDD</b> 2x500GB in RAID 0 SATA <br>
<b>Optical Drive</b> Super-Multi DVDRW<br>
<b>Audio</b> 2 Theater Class Speakers +1 Subwoofer <br>
<br>
- HD Webcam <br>
- Card Reader XD/SD/MMC/MS <br>
- LAN 10/100/1000 <br>
- Wireless LAN 802.11 b/g/n <br>
- Bluetooth V2.0EDR <br>
- D-Sub (VGA)<br>
- HDMI<br>
- 2x USB 2.0 port <br>
- 2x USB 3.0 port <br>
- eSATA <br>
- 120W AC Adapter<br>
- 9 cell Battery<br>
Was £999.00 Inc. VAT
Only £977.99 inc VAT.
ORDER NOW
"Primo 6100i" Intel Core i3 550 3.20GHz DDR3 System @ £379.98 inc VAT
The "Primo 6100i" features a Intel Core i3 550 3.20GHz processor seamless multi-tasking capabilities which is perfect for home/office use. Awesome power contained within a small chassis the "Primo Ignition" has the option to upgrade to one of many of the latest Low Power, energy efficient Nvidia series graphics cards for extra graphical punch. Utilising Hyper threading technology the "Primo Ignition" makes short work of video encoding and multitasking.
Why You Should Buy This System?
- Intel Core i3 550 3.06GHz (Clarkdale) Processor with Hyperthreading technology for 4 Virtual cores
- 500GB Hard drive gives massive storage capacity including DVD Re-Writer Make this system perfect for data backup
System Specification
- Case: OcUK EZCool NA-705 microATX Case
- Power Supply: OcUK 500W PSU
- CPU: Intel Core i3 550 3.20GHz (Clarkdale)
- Motherboard: Intel H55 (Socket 1156) DDR3 microATX Motherboard
- Cooler: Intel Approved Cooler
- RAM: 4GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: Western Digital Caviar Blue 500GB SATA 6GB/s
- Graphics Card: Onboard Intel GMA graphics or a choice of energy efficient graphics cards
- Sound: High Definition 7.1 Onboard Sound Card
- Optical Drive: LG GH22NS50 22x DVD+RW SATA ReWriter
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
With multiple video outputs, compact size and advanced hyperthreading technology the "Primo 6100i" is perfect for the user looking for a highperformance system for a low price.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £389.98 Inc. VAT
Only £379.98 inc VAT.
ORDER NOW
Antec 902 Nine Hundred Two (V3) Ultimate Gaming Case (with USB3.0 Support) - Black @ £104.99 inc VAT
Antec’s popular and award-winning Nine Hundred gaming case became an instant favorite among gamers, delivering versatility, style and performance to establish itself as “The Ultimate Gaming Case.” Now Antec introduces the Nine Hundred Two, the next generation in premier gaming enclosures. Building on the tried-and-true designs of both the Nine Hundred and the powerful Twelve Hundred gaming cases, the Nine Hundred Two maintains popular features such as a perforated front panel, up to six variable-speed fans for maximum cooling, and a sleek, aggressive aesthetic. The Nine Hundred Two adds exciting improvements such as a top 200mm Big Boy TriCool™ fan now with blue LED, fan control knobs plus built-in washable air filters right in the front panel, and eight expansion slots for even greater versatility. Dominate your competition and maximize cool with the Antec Nine Hundred Two: “The Ultimate Gaming Case, Evolved.”
- 9 drive bays
- External 3 x 5.25"; Internal 6 x 3.5" for HDD, or
- External 6 x 5.25"; Internal 3 x 3.5" for HDD, or
- External 9 x 5.25"
- Advanced cooling system:
- 1 rear 120 x 25mm TriCool™ blue LED exhaust fan
- 1 top 200 x 30mm “Big Boy” TriCool™ blue LED exhaust fan
- 2 front 120 x 25mm special black blue LED intake fans with front speed control
- 1 side (Optional) 120 x 25mm fan mount
- 1 middle (Optional) 120mm fan mount
- Built-in washable air filters
- 8 expansion slots to support multiple graphics cards, including NVIDIA 3-way SLI®
- Front mounted I/O ports
- 2 x USB 2.0
- 1 x eSATA
- Audio In and Out (AC’97 and HDA compatible)
- Motherboard: Mini-ITX, microATX, Standard ATX
- No power supply included
Only £104.99 inc VAT.
ORDER NOW
Cooler Master CM-690 II Case Window Side Panel @ £15.98 inc VAT
Make your case components gleam with the new side window for all models of the CM-690 II case. Makde with an appealing design, much better than most generic square windows.
- 120mm vented fitment for side fan to give an optimal cooling solution
- Studded window fitment
Was £17.99 Inc. VAT
Only £15.98 inc VAT.
ORDER NOW
Cooler Master CM-690 II Advanced Dominator Case - Black @ £79.98 inc VAT
The CM 690 II Advanced raises the bar again with practical improvements over the top-selling CM 690. The spacious mid-tower will keep enthusiasts happy with room for up to 3 vga cards, high-end CPU coolers, top or bottom mount water cooling radiator and 1.8"/2.5" drive adapter. It also features much improved airflow with oversized mesh and enough space for up to 10 fans. Maintenance will be a breeze with the tool-free drive bays, new cable management and CPU cooler retention hole.
- Dimensions: 214 x 511 x 528mm
- Motherboard Compatiblity: ATX, Micro-ATX, Mini-ITX
- Room for 120 x 240mm Radiator inside the top and bottom
- External SATA HDD dock
- Includes SSD Adapter
- Cable management and CPU retaining holes for easy maintainence
- Support Tri-GFXs
- 4 x 5.25" Drive Bays
- 7 x 3.5" Drive Bays
- I/O Panel: USB2.0, 1 x eSATA, 2 x Audio
- Front Cooling: 1 x 140mm Blue LED Fan
- Rear Cooling: 1 x 120mm Fan
- Top Cooling: 1 x 140mm Fan
- Bottom Cooling: 2 x 120mm Fans (optional)
- Right Side Cooling: 2 x 120 or 140mm Fans (optional)
- Left Side Cooling: 1 x 80mm Fan
- HDD Cage Cooling: 1 x 120mm Fan (optional)
- VGA Holder: 1 x 80mm Fan (optional)
Was £84.98 Inc. VAT
Only £79.98 inc VAT.
ORDER NOW
"Titan Triceratop" Intel Core i5 2500K 3.30GHz @ 4.40GHz DDR3 Sandybridge System @ £583.98 inc VAT
Strong, resolute, powerful, the "Titan Triceratop" the natural enemy of the T-Rex. Providing immense graphical power and CPU processing speed. The "Titan Triceratop" has a ludicrous 4.40GHz overclock, which enables you to power through the latest games and applications. Own your game with the "Titan Triceratop"!
- A guaranteed 4.40GHz performance for the price of 3.40GHz
- True DX11 gaming performance available from a choice of compatible graphics cards
- Precision built and cabled by Overclockers UK expert technicians
- SATA 6GB/s and Intel Ethernet for next gen computing
- Case: Coolermaster Elite 335 Case - Black
- Power Supply: OCZ ZS 650W PSU
- CPU: Intel Core i5 2500K 3.30GHz Sandybridge overclocked to 4.40GHz
- Motherboard: Intel P67 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Cooler: Xigmatek Dark Knight
- Graphics Card: Choice of the latest DX11 Graphics cards
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
Powerful and reliable. The two qualities you need to get you through your game, the "Titan Triceratops" lauches you into the next generation of computing.
Was £603.97 Inc. VAT
Only £583.98 inc VAT.
ORDER NOW
Fractal Design Define R3 Midi Tower Case - Black Pearl @ £69.98 inc VAT
The Define R3 case is reaching new heights in combining stylish, contemporary design with maximum functionality and noise absorbing features. The minimalistic, yet stunning front panel design, fitted with noise absorbing material on the inside, creates an aura of exclusivity. The patent pending feature ModuVent™, in which you can choose whether to have side and top panels open or not, makes the case appealing for users seeking optimal silence, as well as the performance hungry ones. The sleek black interior is matched with pre-fitted, dense noise absorbing material on the side panels, efficiently absorbing noise and vibrations. You can fit an astonishing total of eight(!) hard drives into this case, using the user friendly HDD-trays. All painted in a nice white color and using black silicone mounts. PSU is mounted in the bottom of the case, with a convenient pull-out filter beneath it. Are you one of those users always ending up with a case full of tangled cables? No more. The Define R3 offers a convenient and good looking way of hiding them away. The motherboard has rubber covered holes in which you can easily route the cables behind the motherboard.
- Stunning front panel design
- Patent pending ModuVent™ design, allowing the user to either have optimal silence or optimal airflow
- Pre-fitted with dense, noise absorbing material
- 8 white painted HDD-trays, with silicone mounting
- A total of 7 fan slots (2x120mm in front, 2x 120/140mm in top, 1x120mm in back, 1x 120/140mm in side panel, 1x 120/140mm in bottom)
- 2x 120mm Fractal Design 120mm fans included
- Fan controller for 3 fans included
- Easily removable front fan filters with clip-on holders for 120mm fans
- Supports graphic card lengths up to circa 290mm and CPU coolers with height of maximum circa 165mm
- 1 rear Fractal Design 120mm @ 1350rpm included
- 1 front Fractal Design 120mm @ 1350rpm included
- 1 front 120mm fan (optional)
- 1 bottom 120mm/140mm fan (optional)
- 1 side panel 120mm/140mm fan (optional)
- 2 top 120mm/140mm fan (optional)
- Case size (WxHxD): 207.4 x 440 x 521.2mm
Improvements from R2
- Improved air flow with updated fans
- Improved noise absorbing material
- Bigger hole in M/B plate for mounting of CPU Coolers
- Improved cable routing possibilities
- Reset button, located behind the front panel door
- Many small quality improvements, including improved scratch resistant coating
Was £79.99 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
"Ultima Tyrannosaur" Intel Core i7 2600K 3.40GHz @ 4.60GHz DDR3 Sandybridge System @ £1,420.00 inc VAT
The "Ultima Tyrannosaur" is the our Sandybridge flagship system. Named after the fearsome Dinosaur, strike fear into the hearts of your enemies with the ferocious power the "Ultima Tyrannosaur" has to offer. Equipped with the powerful GTX 580 graphics card delivering cinematic DX11 graphics and smashing through even the most demanding of games. The heart of the system is powered by the brand new Intel Core i7 2600K CPU overclocked to a massive 4.60GHz. With 4 cores and hyperthreading you will experience a seamlessly smooth computing experience. A choice of SSDs allows you to increase the speed of your system by ten fold. A massive 1TB Seagate drive brings in the storage for all your films, games and photos. Lay waste to all, with the "Ultima Tyrannosaur".
- A guaranteed 4.60GHz performance for the price of 3.40GHz
- Choose from a selection of graphics cards to meet your performance needs
- USB3, SATA 6GB/s, Intel Ethernet for next gen computing
- Case: Silverstone Raven 3 RV03B-W Case
- Power Supply: OCZ ZX 850 Gold Rated PSU
- CPU: Intel Core i7 2600K 3.40GHz Sandybridge overclocked to 4.60GHz
- Motherboard: Intel Z68 (Socket 1155) PCI-Express DDR3 Motherboard
- Cooler: Corsair H80 CPU Cooler
- RAM: 8GB (2x4GB) DDR3 Dual Channel Kit (16GB Upgrade Available)
- Hard Drive: Seagate Barracuda 7200.12 1TB 6GB/s SATA-II 32MB Cache & SSD Options
- Graphics Card: Nvidia GeForce GTX 580 1536MB GDDR5 PCI-Express Graphics Card
- Optical Drive: Samsung SH-B123L/RSBP 12x BD-ROM / 16x DVD Writer Drive - Black
Service Package
Harness the power of the "Ultima Tyrannosaur" with the all new Intel Sandybridge CPUs and Intel P67 Chipset. Hunt down your prey with the "Ultima Tyrannosaur" and be the ultimate predator.
Was £1,519.99 Inc. VAT
Only £1,420.00 inc VAT.
ORDER NOW
Home Server GT Intel Core i3 2100 3.10GHz DDR3 - Server @ £299.99 inc VAT
Introducing our brand new range of Home Servers, developed hand in hand with Microsoft for complete compatibility and optimal performance when using Microsoft Home Server 2011. Our "GT" spec server is our entry level model, featuring the low power Intel Core i5 2100 Dual core CPU for quick processes and cool operating temperatures. With a 1TB HDD and 4GB of memory as standard the "GT" offers ample storage capacity. For those who have a real hunger for storage, we offer both memory upgrades and additional HDDs as selectable options. Utilising Intel HD 2000 graphics for low power video output.
- Built and engineered speecifically for Microsoft Home Server 2011
- Low power consumption and quiet operation
- Case: Coolermaster Elite 342 - Black
- Power Supply: OCZ ZS Series 500W
- CPU: Intel Core i5 2100 3.10GHz Dual Core CPU
- Motherboard: Intel H61 (Socket 1155) MicroATX DDR3 Motherboard ** B3 REVISION **
- Cooler: Intel Stock Cooler
- Hard Drive: 1TB SATA 6GB/s (additional storage options available)
- Graphics Card: Onboard Intel HD2000 graphics
Service Package
The "GT" spec Home Server is perfect for those who want to set up a small home network. Small, quiet and power efficient are all useful attributes the "GT" features.
Was £319.98 Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Silverstone Raven 3 RV03B-W Full Tower Windowed Case - Black/Gold @ £124.98 inc VAT
The RAVEN team’s continued push to redefine and perfect the enthusiast tower chassis has resulted in yet another benchmark in the RAVEN RV03. With world-class cooling performance from the previous RAVEN chassis models retained by the included 180mm Air Penetrator fans, a rethinking of the interior layout enabled dramatic reduction in overall depth of the chassis compared to RAVEN RV02 while still matching RAVEN RV01’s ability to accommodate Extended ATX motherboard and graphics cards longer than 13 inches. Cable management was also improved with a new 5cm thick hard drive compartment to allow nearly all cables to be connected behind the motherboard tray with ease. An unconventional power supply compartment located in the lower front part of the chassis further add to facilitate cable routing so anyone can assemble a pristine looking system with maximum airflow efficiency.
Complementing the finely tuned and engineered interior, the RV03 has Champaign colored trimmings adorning an exterior with aggressive lines yet reserved profile. The stand out styling also fully utilizes the chassis’s powerful cooling ability to full effect by a set of smartly designed, dual-purpose front bezels that helps to keep the RV03 looking sharp and uniform whether the user is setting up for maximum air cooling or for a silencing build.
As a trend-setter and a computer chassis engineering showcase, the RAVEN RV03 has few equals. However, its advanced features are equally accessible that anyone from experienced enthusiasts to novice users will find easy to appreciate and utilize, making RV03 the most appealing RAVEN chassis yet!
- Revolutionary 90 degree motherboard mounting from RAVEN RV01
- Includes two Air Penetrator 180mm fans for superb performance and quietness
- Support up to seven 120mm fans for exceptional cooling flexibility
- Motherboard back plate opening behind CPU area for quick cooler assembly
- Supports Extended ATX motherboard
- Supports eight expansion slots and graphics cards of any length
- Mandatory cable management design for clean looking system on every build
- Hard drive compartment with independent cooling zone
- Upscale and aggressive styling with dual-purpose front panel bezels
- 7 x 5.25" Drive Bays
- 10 x 3.5" Drive Bays
- 2 x 2.5" Drive Bays
- Expansion Slots: 8
- Front I/O Ports: 2 x USB3.0 & 2 x Audio
- Front Cooling: 4 x 120mm Fan (optional)
- Rear Cooling: 1 x 120mm Fan (optional)
- Side Cooling: 1 x 120mm Fan (optional)
- Top Cooling: 1 x 120mm Fan (900RPM @ 18dBA)
- Bottom Cooling: 2 x 180mm Fans (700 or 1200 RPM @ 18 or 34dBA) or 3 x 120mm Fans (optional)
- Max CPU Cooler height: 163mm
- Dimensions: 235 x 522 x 570mm
- Max GPU lenght: 13.58"
Only £124.98 inc VAT.
ORDER NOW
OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-60G) @ £79.99 inc VAT
As the third generation of the Agility Series, OCZ Agility 3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Agility 3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Agility 3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Agility 3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
- Capacity: 60GB
- Controller: SandForce SF-2281
- Maximum Read: 525MB/sec
- Maximum Write: 475MB/sec
- Max I/O Per Second (IOPS): 50,000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Was £89.99 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Krypton Z68 650i Intel Core i7 2600K 3.40Ghz @ 4.60Ghz Overclocked Bundle @ £484.03 inc VAT
Designed by experts the "Krypton Z68 650i Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.60GHz overclock has the processing power and speed unseen at this price point ever before. The "Krypton Z68 650i Bundle" will accelerate your computer experience into the next level.
Why You Should Buy This Bundle?
- A solid, optimised 4.60GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 8GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- USB3, SATA 6GB/s, Intel Ethernet and EUFI graphical BIOS for next gen computing
Bundle Specification
- CPU: Intel Core i7 2600K 3.40GHz @ 4.60GHz Sandybridge CPU
- Motherboard: Asus P8Z68-V (default choice)
- RAM: Kingston HyperX Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Corsair A50 CPU Cooler
- Artic Silver 5 Thermal Compound
Service Package
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Was £496.03 Inc. VAT
Only £484.03 inc VAT.
ORDER NOW
"Radon Utahraptor" Intel Core i5 2500K 3.30Ghz @ 4.40Ghz Overclocked Bundle - MSI @ £337.98 inc VAT
Designed by experts the "Radon Utahraptor Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.40GHz overclock has the processing power and speed unseen at this price point ever before. The "Radon Utahraptor Bundle" will accelerate your computer experience into the next level.
- A solid, optimised 4.40GHz overclock profile provides outstanding processing performance
- 4GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- CPU: Intel Core i5 2500K 3.30GHz @ 4.40GHz Sandybridge CPU
- Motherboard: MSI P67A-G45 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- RAM: Kingston HyperX Blue 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Coolermaster Hyper 212 Cooler
Service Package
Was £349.98 Inc. VAT
Only £337.98 inc VAT.
ORDER NOW
Xenon AMD Phenom II X4 850 3.30GHz Bundle - Quad Core @ £159.99 inc VAT
Designed by experts the "Xenon AMD Phenom II 850 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Xenon AMD Phenom II X4 850 Bundle" offers you speed and silence in perfect combination.
- Prebuilt and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers fast load times
- CPU: AMD Phenom II X4 Quad Core 850 "95W Edition" 3.30GHz
- Motherboard: Gigabyte GA-M68MT-S2 (Socket AM3) DDR3 Motherboard
- RAM: 4GB (2x2GB) DDR3 1600MHz Dual Channel
- Cooler: AMD Stock Cooler
Service Package
Was £164.98 Inc. VAT
Only £159.99 inc VAT.
ORDER NOW
Corsair Enthusiast Series TX 650W V2 High Performance '80 Plus Bronze' Power Supply (CMPSU-650TXV2UK) @ £67.98 inc VAT
The Enthusiast Series TX V2 is part of Corsair’s best price-performance range of power supplies, designed to meet the exacting standards and performance needs of demanding enthusiasts. TX Series power supplies are ideal for performance enthusiasts who require an affordable, high-wattage, reliable and highly efficient PSU. Corsair TX V2 Series PSUs are compatible with the latest Intel and AMD platforms and NVIDIA and AMD multi-graphics configurations.
- The latest ATX12V v2.31 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems
- An ultra-quiet double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature
- 80PLUS Bronze certified, delivering up to 85% energy efficiency at real world load conditions.
- Active Power Factor Correction (PFC) with PF value of 0.99
- Universal AC input from 90~264V. No more hassle of flipping that tiny red switch to select the voltage input!
- A dedicated single +12V rail offers maximum compatibility with the latest components
- Over-voltage and over-current protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components
- High-quality Japanese capacitors provide uncompromised performance and reliability
- A five year warranty and lifetime access to Corsair¡¦s legendary technical support and customer service
- Safety Approvals: UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick
Was £74.99 Inc. VAT
Only £67.98 inc VAT.
ORDER NOW
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939 / AM2 / AM3 / 775 / 1155/ 1156 / 1366) @ £18.98 inc VAT
The Freezer 7 Pro Rev.2 is the upgraded version of the renowned Freezer 7 Pro. With the flexible mounting design, this version is compatible with the Intel Core i7, Core i5, as well as AMD Socket AM3. Featuring an ultra quiet 92mm fan and 6 heatpipes, the Freezer 7 Pro Rev.2 is one of the most efficient and quiet CPU coolers for power users.
The unique heatsink design consists of 42 fins, which significantly increase the heat dissipation area to distribute massive amount of heat faster and more efficient. Featuring a 92mm PWM fan , 6 heatpipes and pre-applied ARCTIC MX-2.,the Freezer 7 Pro Rev.2 offers performance far beyond stock coolers and achieves 130 Watts cooling capacity – becoming one of the most efficient CPU coolers for power users.
- Compatable Sockets: 939 /AM2 /AM2+ / 775 / 1155/ 1156 / 1366
- Compatible with Intel Core i7 and Core i5, as well as AMD sockets
- Excellent cooling performance - 130 Watts
- Ultra quiet 92mm PWM fan
- 6 heatpipes and 42 fins for efficient heat dissipation
- Patented vibration absorption to eliminate buzzing sounds
- Pre-applied ARCTIC MX-2
- Easy installation
Was £21.98 Inc. VAT
Only £18.98 inc VAT.
ORDER NOW
Western Digital Caviar Black 2TB SATA 6Gb/s 64MB Cache - OEM (WD2002FAEX) @ £112.99 inc VAT
nonl2br
<center>
<div id="docview"><object classid="clsid
27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0" width="728" height="90"><param name="movie" value="http://wdbrand.com/collateral/bannerad/Desktop/6Gb_728x90_EN.swf" /><param name="quality" value="high" vmode=transparent /><embed src="http://wdbrand.com/collateral/bannerad/Desktop/6Gb_728x90_EN.swf
" quality="high" pluginspage="http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" width="728" height="90"></object></div></center>
<br>
WD Caviar Black high-performance 3.5" SATA drives combine 7200RPM spin speed, 64MB cache, SATA 6 Gb/s interface, and an integrated dual processor for lightning-fast performance in demanding desktop, workstation, and multi-drive systems. Technologically advanced acoustics minimize noise and cool drive operation and enhanced reliability features help protect the drive and the data stored on it. With a massive 2TB of storage, these drives are ideal for power computing applications such as multimedia, video and photo editing, and maxed out gaming computers. Backed by a 5-year limited warranty.
<br>
<br>
- Backwards compatible with SATA-II
<br>
- Capacity: 2TB
<br>
- Cache: 64MB
<br>
- Interface: SATA 6Gb/s
<br>
- Spin Speed: 7200RPM
<br>
- Warranty: 5 Years
<br>
<br>
Only £112.99 inc VAT.
ORDER NOW
Corsair Hydro H80 High Performance Liquid CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3) @ £79.98 inc VAT
Corsair Hydro Series liquid CPU coolers provide a compact, easy-to-install, and maintenance free alternative to bulky, noisy air coolers, efficiently cooling and protecting your high-performance Intel® or AMD® CPU. The H80 features a double-thick radiator to maximize the surface area available for heat dissipation and dual performance matched fans. It also includes push-button control so you can select the fan speed and cooling performance setup that best suits your needs.
The Corsair Hydro Series H80 high-performance CPU cooler fully supports Corsair Link Digital connections, so you can be in complete control of your cooling. Monitor a wide range of parameters, including pump speed, coolant temperature, and fan speed, and customize your own performance profiles*.
* Requires the Corsair Link Commander, sold separately
The low-profile integrated pump and cold plate includes push-button control so you can select the fan speed and cooling performance setup that best suits your needs. The cool white LED display lets you know at a glance which profile is being used.
Double-up for excellent cooling
Featuring a double-thick radiator to maximize the surface area available for heat dissipation, and dual, performance matched fans, the H80 delivers cooling performance that lets your CPU keep its cool, even when pushed to the limit. And with all this cooling performance, the compact design still fits virtually any case with a 120mm fan mount.
- Corsair Link™ Digital compatibility means that you can be in complete control of your cooling.
- Push-button fan control so you can select the fan speed and cooling performance that best suits your needs.
- Double-thick 120mm radiator for increased surface area and cooling potential.
- Two all-new 120mm fans optimize static pressure and airflow for amazing performance.
- FEP tubing provides extraordinarily low coolant evaporation levels.
- A new improved micro-channel cold-plate design more efficiently transfers heat.
- Quick and easy installation brackets make it easier than ever to upgrade to watercooling.
- Includes mounting hardware compatible with all modern CPU socket designs
- Radiator Dimensions: 120mm x 38mm
- Fan Dimensions: 120mm x 25mm
- Fan Speed: Up to 2600 RPM
- Air Flow: 46 - 92 CFM
- Fan Noise: 22 -3 9bDA
Was £84.98 Inc. VAT
ORDER NOW
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) @ £62.99 inc VAT
nonl2br
<center>
<br>
WD Caviar Black high performance 3.5" SATA hard drives combine 7200RPM spin speed, 64MB cache, SATA 6Gb/s interface with an integrated dual processor for lightning-fast performance in demanding desktop, workstation, and multi-drive systems. Rock solid mechanical architecture and enhanced reliability features help protect the drive and the data stored on it. Backed by a 5-year limited warranty.
<br>
<br>
<br>
- Capacity: 1TB
<br>
- Cache: 64MB
<br>
<br>
<br>
- Warranty: 5 Years
<br>
<br>
Was £72.98 Inc. VAT
Only £62.99 inc VAT.
ORDER NOW
Zalman VF3000-F Graphics Card Cooler (GTX570 and GTX580) @ £39.98 inc VAT
The dual 92mm fans cool not only the heatsink and VGA RAM, but all other peripheral components surrounding the VGA chipset.
- Powerful Cooling Performance
- Ultra Quiet Design
- Ultra Quiet Green LED Fans
- Adjustable fan controller
- High Performance ZM-STG2 thermal grease
- Includes VRAM Sinks
PLEASE NOTE REMOVING THE STOCK COOLER MAY INVALIDATE YOUR GRAPHICS CARD WARRANTY
Was £44.99 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST3500413AS) @ £28.99 inc VAT
Combining proven components, state-of-the-art technology and industry-leading manufacturing expertise, the Seagate Barracuda 7200.12 drive - the 12th generation of this award-winning desktop hard drive family - delivers 250GB of high-performing, eco-friendly digital storage.
- Capacity: 500GB
- Cache: 16MB
- Seek Time: 8.5ms
- Warranty: 3 Years
Was £30.98 Inc. VAT
Only £28.99 inc VAT.
ORDER NOW
Coolermaster Sentinel Advance 5600dpi Gaming Mouse with OLED display @ £39.98 inc VAT
Gaming mice are funny things, each quite subjective to the person who will eventually be using it and there can't ever be one mouse for all hands - but the Sentinel comes pretty close.
The Sentinel Advance is a rodent with a serious twin-laser setup that gives it tracking of up to 5600dpi.
The Sentinel also comes with an OLED screen, interchangeable weights underneath the chassis, a gold-plated pimpin' USB plug and some neat-looking LED lights, so you can be sure to be noticed at a LAN with this under your cheesy-snack-coated mitts.
- 5600 DPI Twin Laser Sensor
- Interchangable weights to suit each user
- Rubber Gripped for comfort
- Dynamic Surface Adaptation
- Multicolour LED lighting
- Create you own custom logo to the OLED profile management screen
- Right Handed Design
- 64k/b onboard memory
Was £46.99 Inc. VAT
ORDER NOW
Logitech G9x Laser Mouse (910-001153) @ £45.98 inc VAT
The Logitech® G9x Laser Mouse offers more customisable features than any other gaming mouse, so you can tune for the way you play. Interchangeable grips let you choose a fit and feel that’s best for your playing style (includes XL and Precision grips). The next-generation gaming laser gives you game-changing precision at any hand speed. And on-the-fly adjustable dpi from 200 to 5000 dpi. Onboard memory lets you program up to five ready-to-play profiles (for keyboard macros, dpi settings and LED colours). The weight-tuning system gives you up to 28 g of extra weight. And the custom-colour LEDs let you match your mouse to your style.
- Interchangeable grips
- Up to 5000 DPI
- Next-generation gaming laser
- Onboard memory
- Weight-tuning system
- Custom-colour LEDs
Was £49.99 Inc. VAT
Only £45.98 inc VAT.
ORDER NOW
Logitech K300 Compact Keyboard (920-001488) @ £15.98 inc VAT
Control your media and smarten up your space with the Logitech® Compact Keyboard K300. Its stylish, backlit media controls provide an elegant and easy way to access to your music, videos and e-mail, with keys that blend cleanly into the streamlined styling. The K300 features a space-saving design with full-size keys that frees up space on your desk – and makes the keyboard easy to store or take with you. A full-size, integrated number pad makes data entry fast and effortless. The ultra-flat profile helps you type comfortably with keys move quietly and feel great, shifting your wrists toward a more neutral position. Plus, setup is easy: the K300 works right out of the box, with no software to install.
- Backlit media controls
- Full-size number pad
- Space-saving design
- Ultra-flat profile
- Easy setup
Was £17.99 Inc. VAT
ORDER NOW
Philips SPA2602 5.1 Surround Sound Speaker System @ £32.99 inc VAT
Perfect for MP3, PC, TV and more.
Connect your speakers to all your gear. A great way to listen to your MP3 player, PC, TV, CD, DVD and all your multimedia stuff.
Sound
- Bass enhancement: Analogue Bass Boost, Bass reflex
- Frequency response: 35 - 20 K Hz
- Loudspeaker Enhancement: Magnetic Shielded LSB
- Music Power: 90 W
- Volume Control: Analogue Volume Control
- Wires: Fixed Wires
- Output power (RMS): 45 W
Loudspeakers
- Satellite speaker drivers: 3"
- Subwoofer driver: 4.25"
Connectivity
- Audio input for data: Stereo Audio (3.5 mm jack) 1 x
- Cable length: 1.5 m
- Connector: 3.5 mm stereo
Was £34.99 Inc. VAT
Only £32.99 inc VAT.
ORDER NOW
TT eSports Challenger Pro Gaming Keyboard @ £46.98 inc VAT
Challenger Pro Gaming Keyboard will Illuminate your world and allow you to game freely.
- Red Illumination Back Light - Red illumination back light simulates the true-to-life gaming atmosphere
- 2x USB 2.0 Ports - Provide easy usage of other USB peripherals. Each USB port supports up to 100mA
- 10 Macro Keys - Program the combined action in a button to make a move ahead ofother gamers
- 6 Multimedia Keys - Instant access to multimedia function for quick audio control
- 64KB On Board Memory - Storage of up to 40 macro keys for action, shooting, RPG and strategy games
- On Board Profile Switch - On board profile switch to engage for instant game changes
- Back Light Switch - Back light switch allows gamers to choose the different levels of lighting depending on the mood
- Fan Device - Cooling fan not only keeps your hands dry and provides comfortable gaming experience
- Windows Dummy Keycaps - Enclosed with two Windows keys to disable the function; prevent from jumping out of the game by accident
- Smart Cable Management With Detachable Cable Design - Protects cable from damage of improper use. For easy storage and cable protection
Was £51.98 Inc. VAT
Only £46.98 inc VAT.
ORDER NOW
Qpad UC Medium Cloth Gaming Surface @ £9.98 inc VAT
nonl2br
If you're looking for a mousepad that gives you total control while letting you enjoy working the mouse, choose QPAD's new uncoated surface mouse pad the latest in a wide portfolio of proven QPAD products. Our new, four-millimeter thick pad features a soft yet resistant surface designed to let you feel the mouse's movement over the pad's uncoated surface for better control. Portable and robust, you can roll it up, stick it your pocket and slap it down for the next game. A cross-weave rubber underside firmly grips the table where you place it. With its signature winged shape designed for an extra-wide sweet spot, UC is a superior quality soft pad that lets you do the work and gives you a sense of mastery.<br><br>
- Size: 35x25.5cm<br>
- Thickness: 3mm<br>
- Color: Black<br>
- Surface: Uncoated cloth surface<br><br>
<font color="red"> <font size="3"> SRP <s>£13.27</s> <b>SAVE: 3.29 </font>
Was £12.98 Inc. VAT
Only £9.98 inc VAT.
ORDER NOW
Qpad UC Large Cloth Gaming Surface @ £11.99 inc VAT
nonl2br
If you're looking for a mousepad that gives you total control while letting you enjoy working the mouse, choose QPAD's new uncoated surface mouse pad the latest in a wide portfolio of proven QPAD products. Our new, four-millimeter thick pad features a soft yet resistant surface designed to let you feel the mouse's movement over the pad's uncoated surface for better control. Portable and robust, you can roll it up, stick it your pocket and slap it down for the next game. A cross-weave rubber underside firmly grips the table where you place it. With its signature winged shape designed for an extra-wide sweet spot, UC is a superior quality soft pad that lets you do the work and gives you a sense of mastery<br><br>
- Size: 42x30.6cm<br>
- Color: Black<br>
<font color="red"> <font size="3"> SRP <s>£14.29</s> <b>SAVE: 1.80 </font>
Was £13.99 Inc. VAT
Only £11.99 inc VAT.
ORDER NOW
Speedlink Vellu Gel Mousepad - Black @ £5.99 inc VAT
The mouse pad is perfect for maintaining the wrists in a relaxed position whilst working thereby preventing excessive straining. The gel filling allows the mouse pad to mould to optimally fit any wrist thereby improving use.
- Reduces posture-related injuries
- Adapts perfectly for any wrist
- Extremely soft covering
- Mousepad with gel filling
- Enables relaxed arm posture
Was £6.98 Inc. VAT
Only £5.99 inc VAT.
ORDER NOW
Samsung SH-S222AL/BEBE 22x DVD±RW SATA Lightscribe ReWriter (Black) - OEM @ £15.98 inc VAT
Samsung's 22x Serial SATA DVD Writer supports powerful over speed performance which allows writing with the high speed of 22x on a low cost 16x media and now includes the Lightscribe Labelling function.
Write Speed
- DVD-R: 22x
- DVD-R: 22x
- DVD-R DL: 12x
- DVD+R DL: 16x
- DVD+RW: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- CD-R:48x
- CD-RW: 4x
Read Speed
- DVD-R: 16x
- DVD+R: 16x
- DVD-R DL: 12x
- DVD+R DL: 12x
- DVD-RW: 12x
- DVD+RW: 12x
- DVD-RAM: 12x
- CD-R: 40x
- CD-RW: 40x
Was £16.99 Inc. VAT
ORDER NOW
Sony BWU-500S-WW 12x BluRay-RW / 16x DVD±RW Drive - Retail @ £84.98 inc VAT
The BWU-500S-WW writes BDs at 12x and DVDs at 16x. And because it can also play 3D movies, absolutely nothing is standing between you and your future enjoyment of 3D films, TV or PC games. The complete CyberLink software suite that comes with this burner means that anyone can plug in the BWU-500S-WW and start utilizing a wide range of programs.
Key Features
- 3D Playback & SD to HD upscaling with PowerDVD 9
- Reads and records all BD/DVD/ CD formats
- Comes with Cyberlink BD Suite 8
- Seamless Link Buffer Under-run Protection
- 12cm and 8cm CD/DVD/BD media supported
Read speed:
BD 8x /DVD 16x / CD 48x max
Write speed:
BD-R 12x /DVD+R/-R 16x max
DVD+RW: 8x max DVD-RW: 6x max
DVD+R9: 8x max DVD-R DL: 8x max
DVD-RAM: 12x max
Was £89.99 Inc. VAT
Only £84.98 inc VAT.
ORDER NOW
Samsung SE-S084F/RSBS 8x Slimline External USB DVD±RW - Black @ £24.98 inc VAT
The SE-S084C is the one of the smallest drives in the world, giving power via the USB cable, this drive is truely the most portable burners available.
- DVD+R: 8x, DVD-R: 8x
- DVD+R DL: 6x, DVD-R DL: 6x
- DVD+RW: 8x, DVD-RW: 6x
- DVD-ROM Read: 24x
- CD-R Write: 24x
- CD-RW Write 4x
- CD Read: 24x
- Access time: 130ms
- Buffer Size: 2MB
Was £26.99 Inc. VAT
Only £24.98 inc VAT.
ORDER NOW
Roccat Apuri USB Hub with Mouse Bungee @ £19.98 inc VAT
The first component of the ROCCAT™ Smart Desktop Management System (SDMS) offers you the perfect combination of style and functionality right there on your desktop. The Apuri won’t just power your USB devices; among other things it’ll also bring new order to your desktop by taking control of your mouse cable.
USB PORTS ALWAYS WITHIN REACH
The Apuri combines stability and practically in the way it takes over the job of managing your devices and cables on the desktop. The Apuri’s AC adapter delivers sufficient power to supply its USB ports with up to 2A each – allowing you to connect up to four USB devices without the need for additional power supplies. And if you don’t want to use the AC adapter, you can simply power the hub using the supplied USB cable.
500mA per port is then available in passive use – perfect for cell phones, cameras and other devices which don’t require their own separate AC adapter. The Apuri allows you to connect everything so it’s within reach, saving you the hassle of crawling around under the desk looking for ports and from the untidiness of cables hanging over the edge of the desk.
SMOOTH GAMING
Thanks to the flexible mouse bungee, the mouse cable in particular is optimally catered for. It is simply guided away from the mouse’s gliding area so that it doesn’t get in the way during game play. There won’t be any rubbing on the desktop or snagging of the cable on the edge of the desk to interfere with your gaming experience – you can even adjust the length of the cable to suit, and the flexible arm optimally flexes with your movements.
You’ll feel as if you’re using a wireless mouse, without the inherent disadvantages such as increased weight, sudden need to change batteries or long charging times. If you don’t want to use the mouse bungee, it can simply be detached from the hub. .
STYLE AND ATMOSPHERE
Contrary to many conventional hubs, which live out their existence as boring boxes, the ROCCAT™ Apuri adds style to your desktop. The unique tripod design gives the Apuri stability even during tense gaming situations. The design fits perfectly with ROCCAT’s new ‘stealth’ style series. Beveled edges and futuristic lines give the hub a unique look. The top features three ice blue LEDs while the base boasts an illuminated ROCCAT logo, which will cast an atmospheric aura onto your desktop.
- 4 high-speed USB 2.0 ports
- Output power active (using AC adapter): 2A each
- Output power passive (using USB cable): 500mA each
- Length of USB cable: 1.5m
- Length of power cable: 1.5m
- Detachable Mouse bungee
- 3 LEDs (top) + underlighting
- Stable tripod design
Was £22.99 Inc. VAT
Only £19.98 inc VAT.
ORDER NOW
Lepa W-Series 500W '80 Plus' Power Supply @ £42.98 inc VAT
Designed by CWT these mid range PSU's are ideal for any gaming systems. Lepa are new to the power supply market, but the company behind Lepa are one of the best known PSU manufacturers in the world. You cannot go far wrong with any of the Lepa series PSU's.
- 80 PLUS® certified with peak 85% efficiency
- High efficiency 5Vsb circuit helps system to meet EU ErP Lot 6 2010 standby low power consumption requirements
- 12cm fan with thermal programmed speed controller providing silent cooling performance
- Active PFC universal switching circuit improves Power Factor value up to 0.99, reducing AC line reactive power loss to minimum level and automatically adopting AC voltage from 100~240V
- 8P PCI-E connector supplied supporting extreme graphic cards
- Protected by Over Power, Over Voltage, Over Current, Short-Circuit, and Brown Out protections circuits
- CPU 12V connector rail with >18A output to support next generation >6 cores processor structure
- Extended CPU connector cable to 60cm facilitates installation with bottom-mounted-PSU chassis
- SATA power connector with 3.3V rail to support new generation SSD
- 3 year warranty
Was £46.99 Inc. VAT
Only £42.98 inc VAT.
ORDER NOW
OCZ Agility 3 240GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-240G) @ £334.99 inc VAT
- Capacity: 240GB
- Maximum Write: 500MB/sec
- Max I/O Per Second (IOPS): 45,000 IOPS (4KB File)
- Warranty: 3 Years
Was £349.99 Inc. VAT
Only £334.99 inc VAT.
ORDER NOW
OCZ Agility 3 120GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-120G) @ £152.99 inc VAT
- Capacity: 120GB
- Warranty: 3 Years
Was £159.98 Inc. VAT
Only £152.99 inc VAT.
ORDER NOW
OCZ Vertex 2 50GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTX50G) @ £69.98 inc VAT
Based on a cutting-edge new architecture, Vertex 2 Solid State Drives raise the bar once again and deliver unprecedented performance for the complete gamut of gaming and professional multimedia applications. OCZ designed the Vertex 2 to surpass the competition where it counts most, pushing the limits in both sequential and random read/write rates. With spectacular performance in 4k file writes up to 50,000 IOPS, these latest drives take productivity to the next level with over ten times the performance of the previous generation. Using the latest controller technology, Vertex 2 not only provides a faster, more responsive PC experience, but promotes cooler, quieter, and more energy efficient conditions compared to traditional mechanical hard drives. OCZ Vertex 2 SSDs come backed by a 3-year warranty and 2 million hour MTBF for ultimate peace of mind.
- Capacity: 50GB
- Controller: SandForce SF-1200
- Maximum Read: 285MB/sec
- Maximum Write: 275MB/sec
- Sustained Write: 250MB/sec
- Max I/O Per Second (IOPS): 50000 IOPS (4KB File)
- Warranty: 3 Years
Was £72.98 Inc. VAT
ORDER NOW
Samsung Port Duplicator with VGA, RS232 and RJ-45 @ £9.98 inc VAT
The Samsung port duplicator provides additional ports to your existing computer by using just 1 exisiting USB port!
- 15-pin VGA supporting max resolution of 1280x1024 at 16bit
- Two 3.5mm Audio: 1x Stereo out, 1x microphone in
- RS232 Serial
- RJ-45 Ethernet 10/100
- 2x USB 2.0 (white)
- 2x USB 2.0 Power Ports (Black providing up to 1AMP)
- 1x Software/Driver CD
Power and USB to host provided.
Requires a USB 1.1 to function however USB 2.0 is required for smooth video functionality.
Windows 2000 SP2 and above, Windows XP SP1 and above, Windows Vista and Windows 7 are supported.
Was £19.99 Inc. VAT
Only £9.98 inc VAT.
ORDER NOW
OCZ Vertex 2E 240GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE240G) @ £249.98 inc VAT
- Capacity: 240GB
- Warranty: 3 Years
Was £269.99 Inc. VAT
Only £249.98 inc VAT.
ORDER NOW
OCZ Vertex 2E 120GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE120G) @ £134.99 inc VAT
- Capacity: 120GB
- Warranty: 3 Years
- OCZACSSDBRKT2
Was £148.99 Inc. VAT
Only £134.99 inc VAT.
ORDER NOW
OCZ RevoDrive3 120GB PCI-E SSD - (RVD3-FHPX4-120G) @ £299.99 inc VAT
The OCZ RevoDrive 3 PCI-Express Solid State Drive Series was designed with power users and multimedia designers in mind and gives enthusiasts the cutting-edge storage they crave. Eliminating the SATA bottleneck, the PCIe-based Revo3 delivers ground-breaking 1GB/s of bandwidth and 130,000 4KB random write IOPS making this an ideal SSD for high performance applications, multimedia, and workstations. Along with unprecedented performance, the Revo3 features OCZ’s proprietary Virtualized Controller Architecture (VCA) 2.0 which provides features including TRIM support and SMART data monitoring, something previously unheard of with PCIe solutions. In addition, the Revo3’s SuperScale storage accelerator enables scalable SSD performance and significantly reduces the host CPU burden inherent to competing PCIe storage offerings. The RevoDrive 3 series is a premium feature rich storage solution that delivers superior performance and reliability through innovative design.
- Capacity: 120GB
- Controller: Dual SandForce SF-2281 (RAID)
- Maximum Read: 1000MB/sec
- Maximum Write: 900MB/sec
- Max I/O Per Second (IOPS): 130,000 IOPS (4KB File)
- Interface: PCI-Express x4
- Warranty: 3 Years
Was £319.99 Inc. VAT
ORDER NOW
Roccat Kave 5.1 Surround Sound Headset @ £61.98 inc VAT
nonl2br
<br>
A Desert Eagle isn't worth its fancy name, if you don't know where to aim. Imagine your advantage within the heat of the battle when you exactly hear where your opponents are before you can actually see them. Knowing the position of your enemy is half the frag. Realistic 3D surround sound makes you locate your opponents easily by the noise they generate. The desktop control enables you to adjust to situations quickly with sound and microphone mute buttons and volume control for different channels. <br>
<br>
- Real 5.1 Surround sound with speakers aligned at a 12° angle<br>
- Microphone with mute LED fully rotatable and completely removable<br>
- Tip’N’Control desktop remote for central management of all volume functions<br>
- Dual sound-profile with movie and game settings<br>
- Solid aluminium hinges enabling heavy duty use<br>
- Hand-sewn comfortable earcups featuring external noise cancelling<br>
- Adjustable vibration unit for a realistic gaming experience <br>
- Headband with three pads for equal weight distribution<br>
- Easy to carry folding and compact design <br>
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/125bfd1f2f2cc9251cc512dfde5e4fb1.jpg">
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/f620e869ce025933aeef18e4d0fd3894.jpg">
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/798d360d6701787365c7266f8cf96fbe.jpg">
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/48545abd6c12c63d38c082c343da0099.jpg">
<br>
<script type="text/css">
#youtube {
float:right;
margin-left: 50px;
</script>
<div id="youtube">
<iframe width="640" height="390" src="http://www.youtube.com/embed/yEyXafzsrB0" frameborder="0" allowfullscreen></iframe>
</div>
Was £64.98 Inc. VAT
Only £61.98 inc VAT.
ORDER NOW
Plantronics GameCom 367 Gaming Headset (79732-05) @ £16.98 inc VAT
The closed-ear GameCom 367 gaming headset delivers an immersive audio experience with 60mm stereo speakers and specially designed earpods that redistribute pressure for maximum comfort. When you’re ready to fire off orders, unveil the hidden, noise-canceling mic boom to strategize clearly with team members. Responses coming in? Adjust audio levels using in-line volume and mic mute controls. When you’re done, rotate and tuck the mic boom inside the headset - then let your score do the talking. This Plantronics headset is rugged, military-like design and extra-strength cables keep your hardware hardcore - game after game after game.
- Closed-ear headset delivers an immersive audio experience.
- Concealed mic boom stays hidden until you’re ready to use it.
- Specially designed ear pods redistribute pressure for maximum comfort.
- In-line volume and mic-mute controls allow for easy audio adjustment.
- Noise-cancelling microphone lets you communicate clearly.
- Rugged, military-like design and extra-strength cables make your hardware hardcore.
Was £19.98 Inc. VAT
Only £16.98 inc VAT.
ORDER NOW
Plantronics GameCom 777 USB 7.1 Surround Sound Headset @ £41.98 inc VAT
This open-eared headset with 7.1 Dolby Headphone technology gives you an unparalleled audio advantage that lets you hear your opponents before you see them. Connect with the Dolby USB sound card for a true 7.1 experience. But if needed, an analogue connection is also provided. Stay comfortable with a lightweight frame and specially designed ear pods that redistribute pressure. When you’re ready to fire off orders, unveil the hidden, noise-cancelling mic boom to strategize clearly with team members. Responses coming in? Adjust audio levels using in-line volume and mic-mute controls.
- Dolby Headphone technology delivers a 5-channel audio experience.
- Dolby USB sound card is the only way to get the 7.1 experience. If needed, an analog connection is also provided.
- Open-ear design keeps you connected to the game and your surroundings.
- Rugged, military-grade design and extra-strength cables make your hardware hardcore.
Was £47.98 Inc. VAT
Only £41.98 inc VAT.
ORDER NOW
Speedlink Spes Clip-On Metal Microphone (SL-8691-SBK) @ £5.99 inc VAT
The microphone is attractively designed and is extremely practical. The noise-suppression system filters out bothersome background noises and makes internet chat easy and uncomplicated. Furthermore, the clothing clip allows you to clip the mic anywhere you like.
- Lots of freedom of movement thanks to the 2.4m cable
- You'll hardly notice you're wearing the mic thanks to it's low weight
- Easy to attach to clothing thanks to the clip
- Highly sensitive microphone featuring noise suppression
- Robust design made from black metal
Was £6.98 Inc. VAT
Only £5.99 inc VAT.
ORDER NOW
OcUK HD 2 Megapixel Webcam Pearl - Black (W250) @ £14.99 inc VAT
The new award winning OcUK HD webcam stands out because of its stylish, deviating design and the good value for money. The webcam is available in 8 different colour settings. Thanks to the 2 MP sensor and the high-quality lens consisting of 5 elements with wide-angle position the user can enjoy razor sharp detailed pictures and moving images in HD quality. The adjustable stand offers the possibility of placing or hanging the webcam on or from the monitor or notebook. The plug & play USB webcam is equipped with a snapshot button and built-in microphone. Moreover, the webcam works with all known Instant Messaging applications, like Skype™, MSN™ etc.
- Built-in microphone
- Snap shot button
- 1600 x 1200 Sensor resolution
- Light exposure control
- USB powered
- LED indicators
- Face tracking
- PC / MAC
Was £16.98 Inc. VAT
Only £14.99 inc VAT.
ORDER NOW
Synology Diskstation DS110J Gigabit Ethernet Network Attached Storage Enclosure @ £113.98 inc VAT
The Synology Disk Station DS110j is designed to provide a cost-effective file storage and backup solution. The system firmware, Synology Disk Station Manager 2.2, delivers rich features for multimedia enjoyment, worry-free backup and file sharing across your network.
- Easy to use
- DLNA Certified
- 2.5" and 3.5" HDD Support
- Cool and Quiet
Was £116.98 Inc. VAT
Only £113.98 inc VAT.
ORDER NOW
TP-Link 300Mbps Wireless-N USB Adapter (TL-WN821N) @ £12.49 inc VAT
The TL-WN821N Wireless N USB Adapter complies with IEEE 802.11n, IEEE 802.11g, and IEEE 802.11b standards. Wireless transmission rates can reach up to 300Mbps. The adapter employs MIMO technology and has internal Intelligent Antennas providing even better wireless performance, transmission rates, stability and coverage. At the same time, CCA technology automatically avoids channel conflicts using its channel selection feature. This product supports 64/128-bit WEP encryptions, as well as WPA/WPA2 and WPA-PSK/WPA2-PSK encryptions and mechanisms in addition to the adapter’s QSS (Quick Secure Setup) feature, allowing users to quickly and easily setup wireless security. This product can also simultaneously operate bandwidth intensive applications such as voice, and video. Applications using a lot of bandwidth that are sensitive to interruptions such as voice and video applications are given priority in order to assure quality. It also works well with other 11g and 11n protocol wireless products.
- 300M Wireless transmission rate
- MIMO technology with stronger signal penetration strength, wider wireless coverage, providing better performance and stability
- CCA technology automatically avoids channel conflicts using its channel selection feature
- Compatible with 11g and 11b equipment, Intel Centrino Compatibility tested
- Supports Sony PSP for online game
Was £12.98 Inc. VAT
Only £12.49 inc VAT.
ORDER NOW
TP-Link AV200 200Mbps Mini Powerline Starter Kit (TL-PA211KIT) @ £38.99 inc VAT
nonl2br
<b>What This Product Does</b><br>
TP-LINK's powerline adapter TL-PA211 takes advantage of your home's existing electric wires to transfer data while transferring traditional power. That means, with no additional wiring required, users can simply plug the TL-PA211 into existing power sockets and establish networking infrastructure in a flash. With high-speed data transfer rates of up to 200Mbps, you can enjoy HD video streaming, online gaming, VoIP or any other high bandwidth intensive tasks all.<br><br>
<img src="http://www.tp-link.com/Resources/UploadFiles/Image/products/overview/PLC/nonewwirespa211.jpg"><br><br><br><br>
<b>Super Small Design</b><br>
With the new ultra-compact housing design, TP-LINK TL-PA211 is much smaller than most other 200Mbps Powerline Products. At just 30mm thick and with its high quality, elegant white shell, it almost blends in completely in front of any power outlet and additionally can be placed anywhere in the room.<br><br>
<img src="http://www.tp-link.com/Resources/Up...uct Features/[Features]super small design.jpg"><br><br><br><br>
<b>Up to 200Mbps, 300 Meters</b><br>
With advanced HomePlug AV technology, TL-PA211 provides users with stable, high-speed data transfer rates of up to 200Mbps on a line length of up to 300 meters. Together with its built-in Qos and powerful AES encryption, the TL-PA211 is a great choice for a whole home solution to connect all network compatible devices--from computers and game consoles to set-top boxes for IPTV to printers and NAS hard drives.<br><br>
<img src="http://www.tp-link.com/Resources/UploadFiles/Image/products/overview/PLC/PA211022.jpg"><br><br><br><br>
<b>Twin Pack Design</b><br>
The PLC connection is transmitting the data through the electric wire between two outlets, so it at least requires two PLC adapters pluged into the outlet to transform the data streaming. With twin pack design, the starter kit ensures to establish a powerline network for the first time.<br><br><br><br>
<b>Reduces Power Consumption Up to 65%</b><br>
The TL-PA211, a new-generation Powerline Adapter, with its logical practical product design and sophisticated Power-Saving Mode, it now consumes less power when compared with existing Powerline Adapters. When there is no data transmission or reception occurs over a certain period of time, it will automatically switch from its regular "Working" Mode to "Power-Saving" Mode that will reduce the energy consumption by up to 65%.<br><br><br><br>
<b>Pair Button for Easy Network Security</b><br>
Simply by pushing the Pair button on the adapters, users can set up a hassle-free Powerline network within minutes, complete with 128-bit AES encryption for network security and data protection.
It's that simple!
1. Plug the adapter into the power outlet
2. Connect the device via the network cable to the adapter
3. Press the encryption buttons—and you're done<br><br><br><br>
<img src="http://www.tp-link.com/Resources/Up...ct Features/[Features] PLC 'Pair' Button .jpg"><br><br><br><br>
- HomePlug AV standard compliant, high-speed data transfer rates of up to 200Mbps <br>
- Twin Pack design helps establish a powerline network initially <br>
- Super small design with a new exterior, blends in completely in front of any power outlet <br>
- No new wires, Easy Plug and Play operations, No configuration required <br>
- <b>UK Standard Plug <br></b>
- Patented Power-Saving Mode automatically reduces power consumption by up to 65%<br><br>
Was £39.98 Inc. VAT
Only £38.99 inc VAT.
ORDER NOW
Seagate Freeagent Goflex TV 1080p HD Media Player @ £55.98 inc VAT
nonl2br
Enjoy all of your movies, music and photos on your TV, in full 1080p HD with vibrant surround sound. The GoFlex TV HD media player makes it easy to access, view and play your digital media files on your home entertainment system. And because it works with just about every format available, you can enjoy all of your entertainment on your TV or in your home theater - from Flip videos to photos to DVDs - regardless of resolution.<br><br>
- Plays MKV File format<br><br>
- Plays your content on your TV directly from your GoFlex ultra-portable drive, or accesses your content from your digital camera, flash drive or other external drives (either Windows® or Mac®) through the additional USB port<br><br>
- Hooks up to your TV in seconds via a digital HDMI® cable
Connects to your PC or Mac computer, home network and the Internet via Ethernet or wirelessly with the optional Wi–Fi Adapter<br><br>
- Lets you watch streaming media direct from the Internet, your computer and your USB devices<br><br>
- Displays all the content that is included with your DVDs, including menus, commentator tracks and subtitles<br><br>
- Makes navigating and accessing your digital media files easy with the included remote control and intuitive on–screen menus<br><br>
- Creates exciting slideshows with your own music track for enjoying memories with friends and family
Fits seamlessly within your entertainment centre<br><br>
<b>Flexible options for accessing your content</b><br><br>
- Access content directly from your GoFlex or GoFlex Pro ultra-portable drive through the integrated GoFlex ultra-portable drive slot, or any USB external drive through the USB ports<br><br>
- Access content from your network through a GoFlex Net media sharing device, in-home media server, or network-connected PC or Mac<br><br>
<b>Access the Internet services you use every day</b><br><br>
Now you can enjoy some of the most popular Internet sites right on your TV, including:<br><br>
<img src="http://www.seagate.com/images/ProductPhoto/FreeAgent/freeagent-goflex/youtube-logo-86x57.jpg"><img src="http://www.seagate.com/images/ProductPhoto/FreeAgent/freeagent-goflex/vtuner-logo-90x60.jpg"><img src="http://www.seagate.com/images/ProductPhoto/FreeAgent/freeagent-goflex/flicker-logo-86x57.jpg"><br><br>
- YouTube<br>
- Paramount<br>
- vTuner<br>
- Mediafly<br>
- Picasa<br>
- Flickr<br>
- Video Feeds (RSS)<br>
- Text Feeds (RSS)<br>
- Finance Widget<br>
- Weather Widget<br><br>
<b>What's included?</b><Br><br>
- GoFlex TV HD Media Player<br>
- AV, component and Ethernet cables<br>
- Power supply<br>
- Remote control<br>
- 1-year limited warranty<br>
Was £64.98 Inc. VAT
Only £55.98 inc VAT.
ORDER NOW
Sennheiser PC 360 Gaming Headset @ £129.98 inc VAT
Developed with the top eSport team mTw, the PC 360 is a new flagship for pro gaming. It has an open design that makes sure you keep a cool head – and delivers a natural listening experience so you can stay in touch with your surroundings. Thanks to the ultracomfortable ear cups, pro microphone and quick-access controls, it’s also the only headset you’ll ever
need for music, videos and skyping.
Professional gaming with a cool head - the open design lets air in and delivers a natural listening experience;Sennheiser sound – excellent hi-fi sound and acoustics from your games, music, movies and internet calls;Noise canceling clarity – the microphone reduces ambient noise for crystal-clear conversations;All-in-one headset – when you want to enjoy movies or music, just move the microphone out of your way;Practical microphone mute – automatically mute the microphone by raising the boom.
- Cable length: 3m / 9.8ft
- Connector sockets: 2 x 3.5mm for desktop/laptop
- Weight: 300g
Frequency response:15–28,000Hz
- Sound pressure level: 112dB
- Microphone:
Frequency response: 50–16,000Hz
- Pick-up pattern: Noise canceling
Sensitivity: -38dBV/PA
Was £134.98 Inc. VAT
Only £129.98 inc VAT.
ORDER NOW
Logitech C510 HD 720p 8 Megapixel Webcam (960-000594) @ £28.98 inc VAT
With HD 720p video calling and one-click HD upload to Facebook, now you can share your HD world—anywhere, anytime.
- HD video calling (1280 x 720 pixels) with recommended system
- Video capture: Up to 1280 x 720 pixels
- Logitech More HD technology
- Photos: Up to 8 megapixels (software enhanced)
- Built-in mic with Logitech RightSound™ technology
- Hi-Speed USB 2.0 certified (recommended)
- Universal clip fits laptops, LCD or CRT monitors
- 2-year limited hardware warranty
Basic requirements:
- 1 GHz
- 512 MB RAM or more
- 200 MB hard drive space
- Internet connection
- USB 1.1 port (2.0 recommended)
- Windows® XP (SP2 or higher), Windows Vista® or Windows® 7 (32-bit or 64-bit)
For HD 720p video calling and recording:
- 2.4 GHz Intel® Core™2 Duo
- 2 GB RAM
- USB 2.0 port
- 1 Mbps upload speed or higher
- 1280 x 720 screen resolution
Was £31.98 Inc. VAT
Only £28.98 inc VAT.
ORDER NOW
Datawrite CD-R x52-Speed 700MB - 100 Discs @ £8.50 inc VAT
CD-R - 700MB - 52x Write Speed - Cakebox - 100 Pack
- Manufacturer: Datawrite
- Max Write Speed: 52x
- Max Storage Data: 700MB
- Max Storage Time: 80min
Was £8.99 Inc. VAT
Only £8.50 inc VAT.
ORDER NOW
Intel Core i3 550 3.20GHz (Clarkdale) (Socket LGA1156) - Retail @ £89.99 inc VAT
The wait is over - now everyone can move up to smart performance. As the first level in Intel’s new processor family, the new 2010 Intel Core i3 processor is the perfect entry point for a fast, responsive PC experience. The new 2010 Intel Core i3 processor also features Intel Hyper-Threading Technology, which enables each core of your processor to work on two tasks at the same time, delivering the performance you need for smart multitasking. Don’t let too many open applications slow you and your PC down. Get smart performance now.
- Lithography Process: 32nm
- Cores: 2
- Threads: 4
- Frequency: 3.20GHz
- Integrated Graphics Frequency: 733MHz
- Cache: 4MB Shared L3
- Memory Controller: Dual Channel DDR3 800/1066/1333MHz
- TDP: 73w
- Socket: LGA1156
Was £94.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
AMD Green Baseball Cap @ £1.19 inc VAT
Be the envy of the world with our exclusive limited time only AMD baseball cap. This cap is great as one size fits all, as it includes a unique sizing strap at the rear of the product. This will surely help increase your 'sex appeal', great for getting a girlfriend/boyfriend, especially now the warm weather is arriving soon. You will be the envy of everyone on the beach.
This cap will do it all.....
Was £1.99 Inc. VAT
Only £1.19 inc VAT.
ORDER NOW
AMD Athlon II X2 Dual Core 265 3.30GHz (Socket AM3) - Retail @ £47.99 inc VAT
AMD Athlon II Dual-Core processors put the power of dual-core technology on the desktop. Dual-core processors contain two processing cores, residing on one chip, that perform calculations on two streams of data to increase efficiency and speed while running multiple programs and the new generation of multi-threaded software. AMD Athlon II Dual-Core processors deliver TRUE multi-tasking, allowing users to switch from one program to another without always pausing for the computer to catch up and reducing annoying processing pauses.
- Dual-core Technology
- 3.30Ghz clock speed (AM3 Socket)
- 2.0MB L2 Cache
- Cool & Quiet Technology for Energy Efficiency
- Enhanced Virus Protection
- 64-bit Technology
- Hyper Transport Technology
- Virtualization technology
- 3yr Warranty
- Retail Boxed with Heatsink & Fan
Was £51.98 Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
AMD Phenom II X4 Quad Core 965 Black Edition "125W Edition" 3.40GHz (Socket AM3) - Retail @ £95.99 inc VAT
The AMD Phenom II processors are the most advanced processors for true multitasking offering true quad-core design. AMD Phenom II processors deliver virtually uninterrupted information flow between processor cores, main memory and graphics and video accelerators for amazingly rapid system response and phenomenal system performance. AMD Phenom II processors deliver unbeatable multi-core value with superior high definition computing, advanced multitasking performance, and innovative, energy efficient solutions.
- 3.40GHz clock speed
- 2MB L2 cache
- 6MB L3 cache
- DDR3-1333 support
- 45nm process technology (125W Edition)
- True Multi-core Processing
- Direct Connect Architecture
- Integrated Dual-Channel Memory Controller with up to DDR3-1333 support
- HyperTransport 3.0
- AMD Balanced Smart Cache
- AMD Wide Floating Point Accelerator
- AMD Memory Optimizer Technology
- AMD Digital Media Xpress 2.0
- AMD Virtualization with Rapid Virtualization Indexing
- Cool‘n’Quiet 3.0 technology
Was £109.99 Inc. VAT
Only £95.99 inc VAT.
ORDER NOW
AMD Phenom II X4 Quad Core 980 Black Edition "140W Edition" 3.70GHz (Socket AM3) - Retail @ £119.99 inc VAT
3DNow! instructions set, PowerNow! technology, HyperTransport technology, AMD64 technology, integrated memory controller, Enhanced Virus Protection, AMD Cool'n'Quiet Technology, AMD Virtualization, AMD CoolCore Technology
- 3.70GHz clock speed
- 2MB L2 cache
- 6MB L3 cache
- DDR3-1333 support
- 45nm process technology (140W Edition)
Was £139.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
AMD Phenom II X6 Six Core 1055T 2.80GHz (Socket AM3) - Retail @ £113.99 inc VAT
Six-core processing power for massive performance headroom - at the price of the competition's quad-core products. The AMD Phenom II X6 processor features AMD Turbo CORE technology that enables unlocked performance for cutting-edge applications, and dynamically switches to three cores for raw speed. Direct Connect Architecture that enables leading-edge performance and responsiveness, even on the most demanding applications. HyperTransport 3.0 Technology enables incredible system agility for 3D gaming and ultra-high resolution entertainment. AMD Dedicated Multi-cache that extends the memory bandwidth for intensive applications, delivering fast performance per core.
- Six Core Technology
- 2.80GHz Clock Speed
- 4.0 GT/s System Bus
- AM3 Socket
- 3MB L2 Cache
- 6MB L3 Cache
- 64-Bit Technology
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan Included
Was £119.99 Inc. VAT
Only £113.99 inc VAT.
ORDER NOW
AMD Phenom II X6 Six Core 1090T Black Edition 3.20GHz (Socket AM3) - Retail @ £125.99 inc VAT
- Multiplier Unlocked
- 3.20GHz Clock Speed
- AM3 Socket
- 3MB L2 Cache
- 6MB L3 Cache
- 64-Bit Technology
- 3 Year Warranty
Was £134.99 Inc. VAT
Only £125.99 inc VAT.
ORDER NOW
AMD Phenom II X6 Six Core 1100T Black Edition 3.30GHz (Socket AM3) - Retail @ £143.99 inc VAT
- 3.30GHz Clock Speed
- AM3 Socket
- 3MB L2 Cache
- 6MB L3 Cache
- 64-Bit Technology
- 3 Year Warranty
Was £149.99 Inc. VAT
Only £143.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport 12GB (3x4GB) DDR3 PC3-12800C10 1600MHz Triple Channel Kit (BL3KIT51264BA160A) @ £65.99 inc VAT
Overclockers UK brings you one of the most notable names in system memory today.
These high performance modules are engineered to deliver the fastest, most reliable memory for gaming and performance enthusiasts. Upgrading has never been this easy!
If you‘re new to performance memory and like what Ballistix has to offer, the Crucial Ballistix Sport Series is a great place to start. This line was created for mainstream users and general enthusiasts. They feature heat spreaders for thermal performance along with standard timings and voltages, making this reliable, quality module ideal for maximum stability and compatibility.
This memory allows you to plug it into your system and get back in the action for an affordable and easy upgrade for any X58 based system.
- PC3-12800 1600MHz CAS 10-10-10-28
- Designed for Entry-Level & Mainstream Users
- Integrated Heat Spreaders
- 1.5v VDIMM
- Triple Channel Memory Kit, Ideal for X58 Based Systems
- Limited Lifetime Warranty
Was £77.99 Inc. VAT
Only £65.99 inc VAT.
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C8) @ £71.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 8-8-8-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 8-8-8-24 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Was £79.99 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) @ £59.99 inc VAT
This 8GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 8GB memory kit (2 x 4GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 9-9-9-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
Was £67.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) @ £23.99 inc VAT
This 4GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 4GB memory kit (2 x 2GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- XMS Heat Spreader
- Sandybridge compatible (use sub 1.60v)
Was £27.98 Inc. VAT
Only £23.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel Kit (BL2KIT25664BA1339) @ £22.79 inc VAT
This memory allows you to plug it into your system and get back in the action for an affordable and easy upgrade, ideal for any Intel Sandybridge or AMD AM3 based system.
- PC3-10666 1333MHz CAS 9-9-9-27
- 1.5v VDIMM
- Dual Channel Memory Kit, Ideal for any Intel or AMD Dual Channel based system
Was £23.99 Inc. VAT
Only £22.79 inc VAT.
ORDER NOW
OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel Kit (OCZ3G1333LV4GK) @ £22.79 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the upcoming Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements at 1333MHz.
Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for the midrange desktops.
OCZ DDR3 PC3-10666 Gold Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1333MHz DDR3
- CL 9-9-9-20 (CAS-TRCD-TRP-TRAS)
- Gold Z3 XTC Heatspreader**
- Lifetime Warranty
- 1.55-1.65 Volts
- 240 Pin DIMM
Was £25.99 Inc. VAT
ORDER NOW
Kingston HyperX 4GB (2x2GB) DDR2 PC2-8500C5 1066MHz Dual Channel (KHX8500D2K2/4G) @ £53.99 inc VAT
HyperX DDR2 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. HyperX DDR2 offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR.
- Size: 4GB Kit (2x2GB)
- Speed: 1066MHz
- Timing: 5-5-5-15
- Format: 240-Pin DDR2 DIMM
- 2.1 Volts
- Lifetime Warranty
Was £59.99 Inc. VAT
Only £53.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport 4GB (2x2GB) DDR2 PC2-6400C5 800MHz Dual Channel Kit (BL2KIT25664AA80E) @ £47.99 inc VAT
This memory allows you to plug it into your system and get back in the action for an affordable and easy upgrade, ideal for any Intel or AMD Dual Channel based DDR2 system.
- PC2-6400 800MHz CAS 5-5-5-15
- 1.8v VDIMM
- Dual Channel Memory Kit, Ideal for any Intel or AMD Dual Channel based DDR2 system
Was £59.99 Inc. VAT
ORDER NOW
HIS ATI Radeon HD 6950 IceQ X Turbo 2048MB GDDR5 PCI-Express Graphics Card with FREE Dirt3 PC Game @ £199.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Core Clock: 840MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5120MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 450W minimum PSU recommended
- Warranty: 2 Years
- Supplied with Dirt3 Download Voucher (Subject availability)
Was £224.99 Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
XFX ATI Radeon HD 6870 Black Edition 1024MB GDDR5 PCI-Express Graphics Card with Dirt3 & Shogun 2 PC Games @ £131.99 inc VAT
With the 6000 series, XFX is literally putting you in the game. The AMD Radeon HD 6870 is 3-D ready and one of the first HDMI 1.4a and DisplayPort 1.2 solutions for Stereoscopic 3-D on the market.
The AMD Radeon HD 6870 ushers in a new era of gaming that takes users to an entirely new level. The AMD 3-D experience is truly immersive and seamless. AMD has also teamed up with other Open 3-D ecosystem partners to provide consumers with more choice, more innovation and lower cost.
Along with the new series XFX debuts the 3E Trilogy, incorporating AMD Eye-Definition (utilizing AMD’s HD3D technology & DirectX 11 for explosive performance and stunning effects), AMD Eyefinity (which supports multi-display gaming) and AMD Eyespeed (improves video image quality and application performance for amazing visuals) technologies.
- Core Clock: 940MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4600MHz (Effective)
- Memory Bandwidth: 135.6GB/s
- Processing Cores: 1120
- HDCP Capable
- OpenGL 3.2 Support
- ATI Avivo HD
- Warranty: 2 Years
- Supplied with Dirt3 & Shogun 2: Total War PC Games (Subject to availability)
Only £131.99 inc VAT.
ORDER NOW
Asus ATI Radeon HD 6670 SILENT EDITION 1024MB GDDR3 PCI-Express Graphics Card @ £64.79 inc VAT
Packed with the latest GPU technologies, the Radeon™ HD 6670 graphics processors offer advanced video and display features, Eyefinity multi-display technology, as well as AMD’s 2nd generation support for DirectX® 11 to give you the ultimate in “visual immersion” for your PC.
The flattened copper heat-pipe contacts GPU directly for 0dB cooling experience. Super Alloy Power technology uses special alloy formula in critical power delivery components for a 15% performance boost, 35°C cooler operation and 2.5 times longer lifespan. Intelligent system monitoring for efficient overclocking with an intuitive slide bar. Real-time overclocking, benchmarking and video capturing in any PC game!
Features:-
- Effective and quiet DirectCU Silent 0dB thermal design
- Pump up graphics performance with Super Alloy Power that delivers 15% Performance boost, 2.5 longer lifespan, 35C cooler operation
- Core Clock: 800MHz
- Memory Clock: 1800MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 480
- Display Connectors: 1 Dual-Link DVI-I, 1 HDMI
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Was £67.99 Inc. VAT
Only £64.79 inc VAT.
ORDER NOW
Asus ATI Radeon HD 6450 SILENT EDITION 1024MB GDDR3 Low Profile PCI-Express Graphics Card @ £35.99 inc VAT
Packed with the latest GPU technologies, the Radeon™ HD 6450 graphics processor is a next-generation visual upgrade that delivers Eyefinity multi-display technology, HDMI 1.4a for stereoscopic (3D) displays, Displayport 1.2 as well as 2nd generation support for DirectX 11 for the most versatile solution for everyday computing.
Silent passive cooling runs 0dB quiet, perfect for hushed gaming and multimedia joy. Ideal for home theater PCs and multimedia centers with low profile design and high power efficiency. Reduces 66%* of electromagnetic interference both given off and received by the card - resulting in a stable signal, clearer screen display and a safer, healthier computing environment. Intelligent system monitoring for efficient overclocking with an intuitive slide bar. Real-time overclocking, benchmarking and video capturing in any PC game! Optimizes colors in various entertainment scenarios with five special modes — standard, game, scenery, night view and theater.
Features:-
- SILENT
- Core Clock: 625MHz
- Memory: 1024MB GDDR3
- Memory Clock: 1200MHz (Effective)
- Memory Interface: 64-Bit
- Processing Cores: 160
- HDCP Capable
- ATI Avivo HD
- Dimension 146(L)x22(W)x94(H) mm Size.
- Low Profile
- Warranty: 3 Years
Was £39.98 Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
Asus GeForce GTX 580 Matrix 1536MB GDDR5 PCI-Express Graphics Card @ £401.99 inc VAT
The Republic of Gamers consists only the best of the best. We offer the best hardware engineering, the fastest performance, the most innovating ideas, and we welcome the best gamers to join in.
In the Republic of Gamers, mercy rules are only for the weak, and bragging rights means everything. We believe in making statements and we excel in competitions. If your character matches our trait, then join the elite club, make your presence felt, in the Republic of Gamers.
TweakIt provides users with flexible overclocking control even when running benchmark programs! The “+” and “-” button puts overvolting adjustments in the user´s fingertips, offering them performance optimization options during game play to gain the competitive edge.
ProbeIt takes the guesswork out of locating the graphics card´s measurement points, identifying them clearly in the form of 6 sets of detection points so you´ll know exactly where to get quick yet accurate readings using a multimeter.
Safe Mode button resets the graphics card back to default frequencies & BIOS. This is a very welcomed feature for hardware enthusiasts, think of it like the "Clear CMOS" on a motherboard.
Built with exclusive 19-phase Super Alloy Power technology, the MATRIX GTX 580 guarantees much greater overclocking headroom, with a 15% performance boost, 2.5 times longer lifespan and 35°C cooler operation than the reference card design.
Cooling is well taken care of by exclusive DirectCU II technology that puts copper heat pipes in direct contact with the GPU. The pipes efficiently transfer heat through two massive fans that deliver 600% more airflow than the reference design, resulting in a 20% lower operating temperatures.
A multicolored LED MATRIX indicator at the rear of the ROG MATRIX GTX 580 gives an instant and easy-to-understand visual display of the current GPU load.
Features:-
- Overclocking hardware tools, TweakIt and ProbeIt are directly embedded onto the graphics card firmware, while a Safe Mode button offers an easy reset option worry-free hardware overclocking.
- All new GPU Tweak provides professional graphics overclocking for PC enthusiasts
- 19-phase Super Alloy Power technology provides more headroom for overclocking with a 15% performance boost, reduced running temperatures and prolonged product lifespan
- Award-winning DirectCU II thermal technology with sound-dampened dual fans provides 600% greater airflow and 20% cooler performance than the reference design.
- Core Clock: 816MHz (Fermi GF110) (Upto 950MHz core possible)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1536MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 512
- Shader Clock: 1632MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters), 1x DisplayPort.
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
Was £419.99 Inc. VAT
Only £401.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 580 "GOOD Edition" 1536MB GDDR5 PCI-Express Graphics Card @ £359.99 inc VAT
The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580. Experience blockbuster games like Call of Duty®: Black Ops and Tom Clancy's H.A.W.X® 2 in their full glory with everything cranked to the max. Not only does the NVIDIA GeForce GTX 580 rip through the latest games, it also runs quieter than the previous generation. And as you have come to expect from the GeForce GTX GPU, the GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX and SLI. With all these features and more, it is easy to see how the NVIDIA GeForce GTX 580 obliterates the competition.
Features:-
- Core Clock: 783MHz (Fermi GF110)
- Memory Clock: 4020MHz (Effective)
- Shader Clock: 1566MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Was £371.99 Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 560Ti OC 1024MB GDDR5 PCI-Express Graphics Card @ £182.39 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560Ti - arm yourself for battle.
Features:-
- Core Clock: 900MHz
- Memory Clock: 4000MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 384
- Shader Clock: 1800MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £199.99 Inc. VAT
Only £182.39 inc VAT.
ORDER NOW
MSI GeForce 8400GS 512MB SILENT GDDR3 "Low Profile" PCI-Express Graphics Card @ £23.99 inc VAT
co-development by MSI and Rivatuner, MSI releases the ultimate graphics card utility “Afterburner”. This utility enables all MSI graphics cards users to boost performance and to monitor all kinds of critical information in real-time. Afterburner is a completely free utility which is compatible with almost all MSI graphics cards.
MSI StarOSD is a very helpful utility for the avid PC gamers. Users can easily access the StarOSD to adjust the contrast, brightness, overclocking and temperature according to each user’s individual preference.
Note:Star OSD function that be used on different games has some difference cause the game different design.
MSI Live Update 4 is a single utility software that automatically checks BIOS, driver and utility updates and installs for you , which can save your time for searching and lower the risk while updating.
The HDCP provides a robust, cost-effective and transparent method for transmitting and receiving digital entertainment similar to DVI/HDMI-compliant digital displays. HDCP encrypts the date transmitted between the DVI/HDMI connector on the graphics adapter and the display.
MSI DOT Express Technology is the most advanced Dynamic Overclocking Technology Express enabling supreme overclocking, cooling and de-noise performance. It is an advanced overclocking engine, designed to deliver up to 10% extra performance and greatly enhances the synchronized GPU & DDR performance.
Dual-link DVI convertible output supports Video signal through DVI to HDMI interface, which drivers resolution of a digital display up to 1920x1200 or higher.
Both support the latest specifications of Blu-ray and HD DVD(High Definition DVD). It comes with the latest GPU and DDRIII superior processing performance in which users can easily enjoy the high-definition video of 1920x1080(1080p/i).
NVIDIA® CUDA™ technology is the world’s only C language environment that enables programmers and developers to write software to solve complex computational problems in a fraction of the time by tapping into the many-core parallel processing power of GPUs. With millions of CUDA™-capable GPUs already deployed, thousands of software programmers are already using the free CUDA™ software tools to accelerate applications—from video and audio encoding to oil and gas exploration, product design, medical imaging, and scientific research.
Was £25.99 Inc. VAT
ORDER NOW
Samsung S22A350H 22" Widescreen LED Monitor - Glossy Black @ £143.99 inc VAT
Brilliant colours and amazing picture clarity just aren’t enough these days. The Samsung SA350 LED monitor recognises today’s real needs and has introduced several new energy saving modes that let you enjoy the best visual experience while also conserving energy. With a host of Eco features, including the automatic Eco light sensor and the Eco motion sensor, reducing your footprint has never been so easy. The Eco motion sensor automatically turns your monitor off/on so that it is ever unnecessarily left on, the Eco light sensor automatically optimises your screen brightness for visibility and energy savings. Add to this the Samsung Magic features for unbelievable picture clarity, and you have a monitor that is loaded with huge potential and ready to transform the way you watch content.
Experience amazing new levels of colour, brilliance and picture quality through the very latest in Mega Dynamic Contrast Ratio. Samsung SA350 monitors deliver images so real-to-life that it will transform your whole viewing experience. Packed with breathtaking 5,000,000:1 contrast ratio, the highest level currently available, the SA350 monitor ensures that blacks are at their absolute darkest and (with pristine whites) colours are at their brightest. You will immediately notice the crystal clear picture and its unbelievable intensity. It is like an explosion of colours and leaves other screens seeming dull in comparison. So, take your viewing pleasure to the next level with Samsung Mega Dynamic Contrast Ratio – and enjoy your multimedia content with the professionalism it deserves.
Eco saving makes saving energy easy. It adjusts the brightness of your Samsung monitor based on how much energy you want to save. And with the choice of three energy saving modes (50%, 25% and Power Saving off), you can really tailor your monitor use to meet your own personal needs. Samsung’s commitment to saving energy is designed to help both you and the environment, and with up to 50% saving on consumption, you can really make a positive impact on your eco footprint. Take the effort out of saving energy and take control with Eco saving.
How do you like to watch movies? Do you like lying down on the couch? Sitting in your favorite chair? Cooking or exercising? Whether you’re standing, sitting or lying down, Samsung’s Magic Angle makes sure that the movie always takes center stage and that you’re always comfortable. This means, thanks to the 5-mode angle management, that whatever angle you watch your Samsung monitor, you will enjoy a full visual experience with amazing picture clarity. So, start seeing your favourite movies and other multimedia in total comfort and without limitations thanks to Magic Angle.
Features:-
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 50000000:1
- Brightness: 250cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x HDMI, 1x Analogue
- Warranty: 3 Years On-Site
ORDER NOW
LG D2342P 23" Passive 3D Widescreen LCD Monitor - Black @ £215.99 inc VAT
Redefine standards with the LG D42P, a full HD LED wall mountable 3D monitor, with a stylish slim design created for a new level of experience. Using its 3D player you can transform photos, home
videos or even movies, from 2D to 3D at the touch of a button. The D42P revolutionises the way you watch home content; giving you the power to watch 3D at will.
Get ready for the most Cinema 3D entertainment you're ever experienced - in the comfort of your home. Forget the heavy, uncomfortable glasses and the dizzying picture quality of conventional 3D technology. You can now enjoy what 3D was meant to be, just like at the movies. The LG Cinema 3D monitor, the standard in 3-dimensional excellence!
Features:-
- Screen Size: 23" Widescreen
- FPR 3D glasses included
- Contrast Ratio: 5000000:1
- Response Time: 5ms
- Inputs: 1x DVI-D & 1x HDMI
- VESA Compliant
Only £215.99 inc VAT.
ORDER NOW
Samsung S23A550H 23" Widescreen Ultra Thin LED Monitor - Glossy Black @ £173.99 inc VAT
Do you want the best-looking display on the market, both in terms of industrial design and image quality? How about a monitor that does more than just display content, one that simplifies your life and is eco-friendly? Samsung’s SA550 LED monitors deliver ultimate image quality, unparalleled elegance, and a suite of features that make them eco-friendly and easy to use.
You can make an artistic statement with a SA550 LED monitor because its design naturally blends subtle color gradations into the monitor frames. The bezel combines a crystal look with Samsung’s Touch of Color, and it is complemented by a transparent base. Also, the cables from the SA550 are hidden in the neck of the monitor so you always have a simple clean look.
The SA550 LED monitor has features to make it so easy to use, while helping you save energy. This monitor uses close to zero watts when it’s in power saving mode. The Eco Motion Sensor alerts the monitor when you sit down and when you walk away, automatically powering it on and off. And, the Eco Light Sensor automatically adjusts the monitor’s brightness to match the ambient lighting in a room. If the room is sunny, the picture shines brighter and in darker surroundings, the intensity is reduced. The result—reduced eye strain and smarter power consumption.
Features:-
- Contrast Ratio: 10000000:1
Was £179.99 Inc. VAT
Only £173.99 inc VAT.
ORDER NOW
ViewSonic VP2365wb 23" Premium IPS Panel Widescreen LCD Monitor @ £191.99 inc VAT
The VP2365wb is one of ViewSonic’s new LCD Professional Series monitors that utilizes the power of IPS panel technology. With IPS true colours, high contrast ratio and wide viewing angles coupled with 1920x1080 Full HD resolution, the VP2365wb is the perfect solution for designers, manufacturers, medical applications and movie production. A 4-port USB hub for cluster free connectivity, ergonomic functions with pivot, height adjust, tilt, swivel and slim bezel make the VP2365wb a feature-packed monitor.
- Screen Size: 23" IPS Widescreen
- Contrast Ratio: 1000:1
- Brightness: 300cd/m²
- Response Time: 14ms
- Viewing Angles (H/V): 178°/178°
- Inputs: 1x Analogue & 1x DVI-D
- 4-Port USB 2.0 Hub
- VESA Compliant
- Dimensions: 548.0mm x 433.0mm x 250.0mm
- Weight: 6.8kg
Only £191.99 inc VAT.
ORDER NOW
Iiyama ProLite B2409HDS 24" Widescreen LCD Monitor - Black @ £167.99 inc VAT
Iiyama's ProLite Business LCD, the B2409HDS is the latest product to follow the true HD resolution of 1920x1080. The Business Line models come with Height Adjustable and Portrait Mode base, complimented by a Slim Bezel design. The incredible 2ms Response Time and 20000:1 Contrast Ratio panel ensures vibrant images and blur free Video. Triple Input support of Analogue, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded Notebook outputs.
- Screen Size: 24" Widescreen
- Contrast Ratio: 20000:1
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Adjustable Stand
- Dimensions: 561.0mm x 413.5mm - 523.5mm x 249.0mm
- Weight: 7.7kg
Only £167.99 inc VAT.
ORDER NOW
Iiyama ProLite E2710HDS 27" Widescreen LCD Monitor - Black @ £215.99 inc VAT
The Prolite E2710HDS 27” LCD Display features a stunning 2ms Response Time and a High Definition 1920x 1080 Resolution. The 20000:1 Advanced Contrast Ratio and 400cd/m² brightness offer the user clear and vivid images, and the DVI, D-Sub and USB connections ensure compatibility across a range of devices including games consoles and work stations.
- Screen Size: 27" Widescreen
- Brightness: 400cd/m²
- VESA Compliant
- Dimensions: 642.0mm x 438.5mm x 210.0mm
- Weight: 6.9kg
Was £239.99 Inc. VAT
ORDER NOW
MSI GX660R 15.6" WLED TFT Intel I7-740QM, 6GB DDR3, 1TB HDD, ATI HD 5870 1GB GDDR5 Graphics, Win7 Home Premium 64-Bit - Black/Red @ £977.99 inc VAT
nonl2br
<img src="http://www.msimobile.com/img-overview/GX660/Topbanner.jpg" height="480" width="768" alt="GX660" /><br>
<br>
<Br>
<font size="4"><b>Key Features</b></font><br>
<br>
<b>• The latest Intel Quad Core i7-740QM 1.73GHz Processor</b><br>
• Genuine Windows 7 Home Premium<br>
• DTS Surround Sensation UltraPC<br>
• Exclusive TDE Technology<br>
• 16:9 Full HD LED Display<br>
• High-end ATi Radeon HD 5870M graphics<br>
• HDMI (High-Definition Multimedia Interface) Output<br>
• Built-in HD Webcam<br>
• 802.11 b/g/ n Wireless LAN with Bluetooth<br>
<br>
<br>
<font size="4"><font color="Blue"><b>New Level of Sound and Performance</b></font></font><br>
<font size="4"><b>MSI + Dynaudio = New Standard of Gaming Notebook</b></font><br>
<br>
<b>Dynaudio Premium Sound Technology</b><br>
<br>
The complex and interconnected elements that comprise excellent sound were painstakingly identified one by one to ascertain how to systematically develop the proper notebook technologies. After undergoing a very long process of cooperative development, Dynaudio and MSI have come up with the GX660. The four directions used to develop Dynaudio Premium Sound Technology are summarized below. For serious gamers who demand extreme audio performance, the GX660 is the best and only choice!<br>
<br>
<img src="http://www.msimobile.com/img-overview/GX660/speaker-1.jpg" align="centre" alt="GX660" /><br>
<br>
<b>Speaker Placement</b><br>
<br>
In the past, limited space on notebooks meant speaker position was always considered last, which resulted in muddled sound in notebook speakers. Because of this, speaker position was considered during the initial stages of the GX660's development to facilitate optimum audio performance and to avoid sacrificing audio quality for incorrect speaker placement.<br>
<br>
<b>EQ Tuning: Adjusted for Optimization of All Types of Sounds</b><br>
<br>
Different types of music represent distinct requirements for sound ambience. Jazz, pop, rock, or classical all possess special characteristics that affect computer game and movie sound performance and each has specific tone balance requirements. To express different types of music authentically, Dynaudio and MSI spent over 1,200 hours of continuous, repetitive testing and fine tuning of high, mid, and low range frequencies so authentic reproduction of different types of music can be achieved.<br>
<br>
<br>
<img src="http://www.msimobile.com/img-overview/GX660/inteli7" align="right" alt="" />
<font size="4"><font color="Blue"><b>Choose The Best!</b></font></font><br>
<br>
<b>Powerful Hardware Under the Hood Deliver Enhanced Horsepower and Blazing Speed</b><br>
The GX660 includes the world’s most advanced Intel® Core™ i7 quad core processor, which boasts superior multimedia performance and can retrieve data from Blu-ray disks or update online photo albums twice as fast as conventional dual core notebooks. The processor also comes with Intel’s Turbo Boost technology, allowing you to power up or down as necessary, depending on the load requirements of the task at hand.<br>
<br>
<br><img src="http://www.msimobile.com/img-overview/GX660/turbo.jpg" align="left" height="300" width="373" alt="GX660" /><br>
<br>
<br>
<b>Accelerated CPU Performance MSI’s Exclusive TDE Technology</b><br>
<br>
By overclocking the CPU and memory frequency, the TDE Technology brings more calculating speed to enhance the system performance. It benefits the video decoding/ encoding, gaming and art work designing. With MSI TDE Technology, you can experience fast-response time and efficient real-time data processing.<br>
<br>
<br>
<b>Exclusive Cooler Boost Technology</b><br>
Only one finger!! Exclusive Cooler Boost technology provides powerful cooling capabilities and receives real-time notification of the GX660's core temperature variations and fan speed.<br>
<br>
<br>
<br>
<br>
<br>
<font size="4"><font color="Blue"><b>Marvel At The Most Amazing Images Around</b></font></font><br>
<b>The ATI Radeon™ HD 5870 Graphics (with GDDR5 1GB VRAM)</b><br>
<img src="http://eu.msi.com/uploads/Image/product_img/other/nb/gx660/gx660_05.jpg" align="centre" alt="GX660" /><br>
The 1GB GDDR5 internal memory and the ATi Radeon™ HD 5870 graphics card provide a high-definition gaming experience that puts you right in the middle of the action sequences. Delivering full support for Microsoft DirectX® 11, the GPU enables richer and true-to-life graphics performance so that you can enjoy immersive games or movies.<br>
<br>
<b>16:9 Full HD* LED Backlit Display</b><br>
<img src="http://eu.msi.com/uploads/Image/product_img/other/nb/gt660/gx660_hd.jpg" align="centre" alt="GX660"/><br>
The 15.6” Full HD screen of the GX660 delivers more details of the high definition content; brings you more pleasure while playing games or watching movies.<br>
<br>
<font size="4"><b>Specifications</b></font><br>
<br>
<b>CPU</b> Intel Core™ i7-740QM 1.73GHz Processor <br>
<b>OS</b> Genuine Windows 7 Home Premium <br>
<b>Chipset</b> Intel PM55 <br>
<b>Memory</b> 6GB DDR3 1066 MHz<br>
<b>LCD Size</b> 15.6" FHD 1920*1080 TFT-LCD Display (LED Backlight) <br>
<b>Graphics</b> ATi Mobility Radeon HD 5870M <br>
<b>Graphics</b> VRAM GDDR5 1GB <br>
<b>HDD</b> 2x500GB in RAID 0 SATA <br>
<b>Optical Drive</b> Super-Multi DVDRW<br>
<b>Audio</b> 2 Theater Class Speakers +1 Subwoofer <br>
<br>
- HD Webcam <br>
- Card Reader XD/SD/MMC/MS <br>
- LAN 10/100/1000 <br>
- Wireless LAN 802.11 b/g/n <br>
- Bluetooth V2.0EDR <br>
- D-Sub (VGA)<br>
- HDMI<br>
- 2x USB 2.0 port <br>
- 2x USB 3.0 port <br>
- eSATA <br>
- 120W AC Adapter<br>
- 9 cell Battery<br>
Was £999.00 Inc. VAT
Only £977.99 inc VAT.
ORDER NOW
"Primo 6100i" Intel Core i3 550 3.20GHz DDR3 System @ £379.98 inc VAT
The "Primo 6100i" features a Intel Core i3 550 3.20GHz processor seamless multi-tasking capabilities which is perfect for home/office use. Awesome power contained within a small chassis the "Primo Ignition" has the option to upgrade to one of many of the latest Low Power, energy efficient Nvidia series graphics cards for extra graphical punch. Utilising Hyper threading technology the "Primo Ignition" makes short work of video encoding and multitasking.
Why You Should Buy This System?
- Intel Core i3 550 3.06GHz (Clarkdale) Processor with Hyperthreading technology for 4 Virtual cores
- 500GB Hard drive gives massive storage capacity including DVD Re-Writer Make this system perfect for data backup
System Specification
- Case: OcUK EZCool NA-705 microATX Case
- Power Supply: OcUK 500W PSU
- CPU: Intel Core i3 550 3.20GHz (Clarkdale)
- Motherboard: Intel H55 (Socket 1156) DDR3 microATX Motherboard
- Cooler: Intel Approved Cooler
- RAM: 4GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: Western Digital Caviar Blue 500GB SATA 6GB/s
- Graphics Card: Onboard Intel GMA graphics or a choice of energy efficient graphics cards
- Sound: High Definition 7.1 Onboard Sound Card
- Optical Drive: LG GH22NS50 22x DVD+RW SATA ReWriter
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
With multiple video outputs, compact size and advanced hyperthreading technology the "Primo 6100i" is perfect for the user looking for a highperformance system for a low price.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £389.98 Inc. VAT
Only £379.98 inc VAT.
ORDER NOW
Antec 902 Nine Hundred Two (V3) Ultimate Gaming Case (with USB3.0 Support) - Black @ £104.99 inc VAT
Antec’s popular and award-winning Nine Hundred gaming case became an instant favorite among gamers, delivering versatility, style and performance to establish itself as “The Ultimate Gaming Case.” Now Antec introduces the Nine Hundred Two, the next generation in premier gaming enclosures. Building on the tried-and-true designs of both the Nine Hundred and the powerful Twelve Hundred gaming cases, the Nine Hundred Two maintains popular features such as a perforated front panel, up to six variable-speed fans for maximum cooling, and a sleek, aggressive aesthetic. The Nine Hundred Two adds exciting improvements such as a top 200mm Big Boy TriCool™ fan now with blue LED, fan control knobs plus built-in washable air filters right in the front panel, and eight expansion slots for even greater versatility. Dominate your competition and maximize cool with the Antec Nine Hundred Two: “The Ultimate Gaming Case, Evolved.”
- 9 drive bays
- External 3 x 5.25"; Internal 6 x 3.5" for HDD, or
- External 6 x 5.25"; Internal 3 x 3.5" for HDD, or
- External 9 x 5.25"
- Advanced cooling system:
- 1 rear 120 x 25mm TriCool™ blue LED exhaust fan
- 1 top 200 x 30mm “Big Boy” TriCool™ blue LED exhaust fan
- 2 front 120 x 25mm special black blue LED intake fans with front speed control
- 1 side (Optional) 120 x 25mm fan mount
- 1 middle (Optional) 120mm fan mount
- Built-in washable air filters
- 8 expansion slots to support multiple graphics cards, including NVIDIA 3-way SLI®
- Front mounted I/O ports
- 2 x USB 2.0
- 1 x eSATA
- Audio In and Out (AC’97 and HDA compatible)
- Motherboard: Mini-ITX, microATX, Standard ATX
- No power supply included
Only £104.99 inc VAT.
ORDER NOW
Cooler Master CM-690 II Case Window Side Panel @ £15.98 inc VAT
Make your case components gleam with the new side window for all models of the CM-690 II case. Makde with an appealing design, much better than most generic square windows.
- 120mm vented fitment for side fan to give an optimal cooling solution
- Studded window fitment
Was £17.99 Inc. VAT
Only £15.98 inc VAT.
ORDER NOW
Cooler Master CM-690 II Advanced Dominator Case - Black @ £79.98 inc VAT
The CM 690 II Advanced raises the bar again with practical improvements over the top-selling CM 690. The spacious mid-tower will keep enthusiasts happy with room for up to 3 vga cards, high-end CPU coolers, top or bottom mount water cooling radiator and 1.8"/2.5" drive adapter. It also features much improved airflow with oversized mesh and enough space for up to 10 fans. Maintenance will be a breeze with the tool-free drive bays, new cable management and CPU cooler retention hole.
- Dimensions: 214 x 511 x 528mm
- Motherboard Compatiblity: ATX, Micro-ATX, Mini-ITX
- Room for 120 x 240mm Radiator inside the top and bottom
- External SATA HDD dock
- Includes SSD Adapter
- Cable management and CPU retaining holes for easy maintainence
- Support Tri-GFXs
- 4 x 5.25" Drive Bays
- 7 x 3.5" Drive Bays
- I/O Panel: USB2.0, 1 x eSATA, 2 x Audio
- Front Cooling: 1 x 140mm Blue LED Fan
- Rear Cooling: 1 x 120mm Fan
- Top Cooling: 1 x 140mm Fan
- Bottom Cooling: 2 x 120mm Fans (optional)
- Right Side Cooling: 2 x 120 or 140mm Fans (optional)
- Left Side Cooling: 1 x 80mm Fan
- HDD Cage Cooling: 1 x 120mm Fan (optional)
- VGA Holder: 1 x 80mm Fan (optional)
Was £84.98 Inc. VAT
Only £79.98 inc VAT.
ORDER NOW
"Titan Triceratop" Intel Core i5 2500K 3.30GHz @ 4.40GHz DDR3 Sandybridge System @ £583.98 inc VAT
Strong, resolute, powerful, the "Titan Triceratop" the natural enemy of the T-Rex. Providing immense graphical power and CPU processing speed. The "Titan Triceratop" has a ludicrous 4.40GHz overclock, which enables you to power through the latest games and applications. Own your game with the "Titan Triceratop"!
- A guaranteed 4.40GHz performance for the price of 3.40GHz
- True DX11 gaming performance available from a choice of compatible graphics cards
- Precision built and cabled by Overclockers UK expert technicians
- SATA 6GB/s and Intel Ethernet for next gen computing
- Case: Coolermaster Elite 335 Case - Black
- Power Supply: OCZ ZS 650W PSU
- CPU: Intel Core i5 2500K 3.30GHz Sandybridge overclocked to 4.40GHz
- Motherboard: Intel P67 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Cooler: Xigmatek Dark Knight
- Graphics Card: Choice of the latest DX11 Graphics cards
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
Powerful and reliable. The two qualities you need to get you through your game, the "Titan Triceratops" lauches you into the next generation of computing.
Was £603.97 Inc. VAT
Only £583.98 inc VAT.
ORDER NOW
Fractal Design Define R3 Midi Tower Case - Black Pearl @ £69.98 inc VAT
The Define R3 case is reaching new heights in combining stylish, contemporary design with maximum functionality and noise absorbing features. The minimalistic, yet stunning front panel design, fitted with noise absorbing material on the inside, creates an aura of exclusivity. The patent pending feature ModuVent™, in which you can choose whether to have side and top panels open or not, makes the case appealing for users seeking optimal silence, as well as the performance hungry ones. The sleek black interior is matched with pre-fitted, dense noise absorbing material on the side panels, efficiently absorbing noise and vibrations. You can fit an astonishing total of eight(!) hard drives into this case, using the user friendly HDD-trays. All painted in a nice white color and using black silicone mounts. PSU is mounted in the bottom of the case, with a convenient pull-out filter beneath it. Are you one of those users always ending up with a case full of tangled cables? No more. The Define R3 offers a convenient and good looking way of hiding them away. The motherboard has rubber covered holes in which you can easily route the cables behind the motherboard.
- Stunning front panel design
- Patent pending ModuVent™ design, allowing the user to either have optimal silence or optimal airflow
- Pre-fitted with dense, noise absorbing material
- 8 white painted HDD-trays, with silicone mounting
- A total of 7 fan slots (2x120mm in front, 2x 120/140mm in top, 1x120mm in back, 1x 120/140mm in side panel, 1x 120/140mm in bottom)
- 2x 120mm Fractal Design 120mm fans included
- Fan controller for 3 fans included
- Easily removable front fan filters with clip-on holders for 120mm fans
- Supports graphic card lengths up to circa 290mm and CPU coolers with height of maximum circa 165mm
- 1 rear Fractal Design 120mm @ 1350rpm included
- 1 front Fractal Design 120mm @ 1350rpm included
- 1 front 120mm fan (optional)
- 1 bottom 120mm/140mm fan (optional)
- 1 side panel 120mm/140mm fan (optional)
- 2 top 120mm/140mm fan (optional)
- Case size (WxHxD): 207.4 x 440 x 521.2mm
Improvements from R2
- Improved air flow with updated fans
- Improved noise absorbing material
- Bigger hole in M/B plate for mounting of CPU Coolers
- Improved cable routing possibilities
- Reset button, located behind the front panel door
- Many small quality improvements, including improved scratch resistant coating
Was £79.99 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
"Ultima Tyrannosaur" Intel Core i7 2600K 3.40GHz @ 4.60GHz DDR3 Sandybridge System @ £1,420.00 inc VAT
The "Ultima Tyrannosaur" is the our Sandybridge flagship system. Named after the fearsome Dinosaur, strike fear into the hearts of your enemies with the ferocious power the "Ultima Tyrannosaur" has to offer. Equipped with the powerful GTX 580 graphics card delivering cinematic DX11 graphics and smashing through even the most demanding of games. The heart of the system is powered by the brand new Intel Core i7 2600K CPU overclocked to a massive 4.60GHz. With 4 cores and hyperthreading you will experience a seamlessly smooth computing experience. A choice of SSDs allows you to increase the speed of your system by ten fold. A massive 1TB Seagate drive brings in the storage for all your films, games and photos. Lay waste to all, with the "Ultima Tyrannosaur".
- A guaranteed 4.60GHz performance for the price of 3.40GHz
- Choose from a selection of graphics cards to meet your performance needs
- USB3, SATA 6GB/s, Intel Ethernet for next gen computing
- Case: Silverstone Raven 3 RV03B-W Case
- Power Supply: OCZ ZX 850 Gold Rated PSU
- CPU: Intel Core i7 2600K 3.40GHz Sandybridge overclocked to 4.60GHz
- Motherboard: Intel Z68 (Socket 1155) PCI-Express DDR3 Motherboard
- Cooler: Corsair H80 CPU Cooler
- RAM: 8GB (2x4GB) DDR3 Dual Channel Kit (16GB Upgrade Available)
- Hard Drive: Seagate Barracuda 7200.12 1TB 6GB/s SATA-II 32MB Cache & SSD Options
- Graphics Card: Nvidia GeForce GTX 580 1536MB GDDR5 PCI-Express Graphics Card
- Optical Drive: Samsung SH-B123L/RSBP 12x BD-ROM / 16x DVD Writer Drive - Black
Service Package
Harness the power of the "Ultima Tyrannosaur" with the all new Intel Sandybridge CPUs and Intel P67 Chipset. Hunt down your prey with the "Ultima Tyrannosaur" and be the ultimate predator.
Was £1,519.99 Inc. VAT
Only £1,420.00 inc VAT.
ORDER NOW
Home Server GT Intel Core i3 2100 3.10GHz DDR3 - Server @ £299.99 inc VAT
Introducing our brand new range of Home Servers, developed hand in hand with Microsoft for complete compatibility and optimal performance when using Microsoft Home Server 2011. Our "GT" spec server is our entry level model, featuring the low power Intel Core i5 2100 Dual core CPU for quick processes and cool operating temperatures. With a 1TB HDD and 4GB of memory as standard the "GT" offers ample storage capacity. For those who have a real hunger for storage, we offer both memory upgrades and additional HDDs as selectable options. Utilising Intel HD 2000 graphics for low power video output.
- Built and engineered speecifically for Microsoft Home Server 2011
- Low power consumption and quiet operation
- Case: Coolermaster Elite 342 - Black
- Power Supply: OCZ ZS Series 500W
- CPU: Intel Core i5 2100 3.10GHz Dual Core CPU
- Motherboard: Intel H61 (Socket 1155) MicroATX DDR3 Motherboard ** B3 REVISION **
- Cooler: Intel Stock Cooler
- Hard Drive: 1TB SATA 6GB/s (additional storage options available)
- Graphics Card: Onboard Intel HD2000 graphics
Service Package
The "GT" spec Home Server is perfect for those who want to set up a small home network. Small, quiet and power efficient are all useful attributes the "GT" features.
Was £319.98 Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Silverstone Raven 3 RV03B-W Full Tower Windowed Case - Black/Gold @ £124.98 inc VAT
The RAVEN team’s continued push to redefine and perfect the enthusiast tower chassis has resulted in yet another benchmark in the RAVEN RV03. With world-class cooling performance from the previous RAVEN chassis models retained by the included 180mm Air Penetrator fans, a rethinking of the interior layout enabled dramatic reduction in overall depth of the chassis compared to RAVEN RV02 while still matching RAVEN RV01’s ability to accommodate Extended ATX motherboard and graphics cards longer than 13 inches. Cable management was also improved with a new 5cm thick hard drive compartment to allow nearly all cables to be connected behind the motherboard tray with ease. An unconventional power supply compartment located in the lower front part of the chassis further add to facilitate cable routing so anyone can assemble a pristine looking system with maximum airflow efficiency.
Complementing the finely tuned and engineered interior, the RV03 has Champaign colored trimmings adorning an exterior with aggressive lines yet reserved profile. The stand out styling also fully utilizes the chassis’s powerful cooling ability to full effect by a set of smartly designed, dual-purpose front bezels that helps to keep the RV03 looking sharp and uniform whether the user is setting up for maximum air cooling or for a silencing build.
As a trend-setter and a computer chassis engineering showcase, the RAVEN RV03 has few equals. However, its advanced features are equally accessible that anyone from experienced enthusiasts to novice users will find easy to appreciate and utilize, making RV03 the most appealing RAVEN chassis yet!
- Revolutionary 90 degree motherboard mounting from RAVEN RV01
- Includes two Air Penetrator 180mm fans for superb performance and quietness
- Support up to seven 120mm fans for exceptional cooling flexibility
- Motherboard back plate opening behind CPU area for quick cooler assembly
- Supports Extended ATX motherboard
- Supports eight expansion slots and graphics cards of any length
- Mandatory cable management design for clean looking system on every build
- Hard drive compartment with independent cooling zone
- Upscale and aggressive styling with dual-purpose front panel bezels
- 7 x 5.25" Drive Bays
- 10 x 3.5" Drive Bays
- 2 x 2.5" Drive Bays
- Expansion Slots: 8
- Front I/O Ports: 2 x USB3.0 & 2 x Audio
- Front Cooling: 4 x 120mm Fan (optional)
- Rear Cooling: 1 x 120mm Fan (optional)
- Side Cooling: 1 x 120mm Fan (optional)
- Top Cooling: 1 x 120mm Fan (900RPM @ 18dBA)
- Bottom Cooling: 2 x 180mm Fans (700 or 1200 RPM @ 18 or 34dBA) or 3 x 120mm Fans (optional)
- Max CPU Cooler height: 163mm
- Dimensions: 235 x 522 x 570mm
- Max GPU lenght: 13.58"
Only £124.98 inc VAT.
ORDER NOW
OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-60G) @ £79.99 inc VAT
As the third generation of the Agility Series, OCZ Agility 3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Agility 3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Agility 3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Agility 3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
- Capacity: 60GB
- Controller: SandForce SF-2281
- Maximum Read: 525MB/sec
- Maximum Write: 475MB/sec
- Max I/O Per Second (IOPS): 50,000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Was £89.99 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Krypton Z68 650i Intel Core i7 2600K 3.40Ghz @ 4.60Ghz Overclocked Bundle @ £484.03 inc VAT
Designed by experts the "Krypton Z68 650i Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.60GHz overclock has the processing power and speed unseen at this price point ever before. The "Krypton Z68 650i Bundle" will accelerate your computer experience into the next level.
Why You Should Buy This Bundle?
- A solid, optimised 4.60GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 8GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- USB3, SATA 6GB/s, Intel Ethernet and EUFI graphical BIOS for next gen computing
Bundle Specification
- CPU: Intel Core i7 2600K 3.40GHz @ 4.60GHz Sandybridge CPU
- Motherboard: Asus P8Z68-V (default choice)
- RAM: Kingston HyperX Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Corsair A50 CPU Cooler
- Artic Silver 5 Thermal Compound
Service Package
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Was £496.03 Inc. VAT
Only £484.03 inc VAT.
ORDER NOW
"Radon Utahraptor" Intel Core i5 2500K 3.30Ghz @ 4.40Ghz Overclocked Bundle - MSI @ £337.98 inc VAT
Designed by experts the "Radon Utahraptor Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.40GHz overclock has the processing power and speed unseen at this price point ever before. The "Radon Utahraptor Bundle" will accelerate your computer experience into the next level.
- A solid, optimised 4.40GHz overclock profile provides outstanding processing performance
- 4GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- CPU: Intel Core i5 2500K 3.30GHz @ 4.40GHz Sandybridge CPU
- Motherboard: MSI P67A-G45 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- RAM: Kingston HyperX Blue 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Coolermaster Hyper 212 Cooler
Service Package
Was £349.98 Inc. VAT
Only £337.98 inc VAT.
ORDER NOW
Xenon AMD Phenom II X4 850 3.30GHz Bundle - Quad Core @ £159.99 inc VAT
Designed by experts the "Xenon AMD Phenom II 850 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Xenon AMD Phenom II X4 850 Bundle" offers you speed and silence in perfect combination.
- Prebuilt and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers fast load times
- CPU: AMD Phenom II X4 Quad Core 850 "95W Edition" 3.30GHz
- Motherboard: Gigabyte GA-M68MT-S2 (Socket AM3) DDR3 Motherboard
- RAM: 4GB (2x2GB) DDR3 1600MHz Dual Channel
- Cooler: AMD Stock Cooler
Service Package
Was £164.98 Inc. VAT
Only £159.99 inc VAT.
ORDER NOW
Corsair Enthusiast Series TX 650W V2 High Performance '80 Plus Bronze' Power Supply (CMPSU-650TXV2UK) @ £67.98 inc VAT
The Enthusiast Series TX V2 is part of Corsair’s best price-performance range of power supplies, designed to meet the exacting standards and performance needs of demanding enthusiasts. TX Series power supplies are ideal for performance enthusiasts who require an affordable, high-wattage, reliable and highly efficient PSU. Corsair TX V2 Series PSUs are compatible with the latest Intel and AMD platforms and NVIDIA and AMD multi-graphics configurations.
- The latest ATX12V v2.31 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems
- An ultra-quiet double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature
- 80PLUS Bronze certified, delivering up to 85% energy efficiency at real world load conditions.
- Active Power Factor Correction (PFC) with PF value of 0.99
- Universal AC input from 90~264V. No more hassle of flipping that tiny red switch to select the voltage input!
- A dedicated single +12V rail offers maximum compatibility with the latest components
- Over-voltage and over-current protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components
- High-quality Japanese capacitors provide uncompromised performance and reliability
- A five year warranty and lifetime access to Corsair¡¦s legendary technical support and customer service
- Safety Approvals: UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick
Was £74.99 Inc. VAT
Only £67.98 inc VAT.
ORDER NOW
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939 / AM2 / AM3 / 775 / 1155/ 1156 / 1366) @ £18.98 inc VAT
The Freezer 7 Pro Rev.2 is the upgraded version of the renowned Freezer 7 Pro. With the flexible mounting design, this version is compatible with the Intel Core i7, Core i5, as well as AMD Socket AM3. Featuring an ultra quiet 92mm fan and 6 heatpipes, the Freezer 7 Pro Rev.2 is one of the most efficient and quiet CPU coolers for power users.
The unique heatsink design consists of 42 fins, which significantly increase the heat dissipation area to distribute massive amount of heat faster and more efficient. Featuring a 92mm PWM fan , 6 heatpipes and pre-applied ARCTIC MX-2.,the Freezer 7 Pro Rev.2 offers performance far beyond stock coolers and achieves 130 Watts cooling capacity – becoming one of the most efficient CPU coolers for power users.
- Compatable Sockets: 939 /AM2 /AM2+ / 775 / 1155/ 1156 / 1366
- Compatible with Intel Core i7 and Core i5, as well as AMD sockets
- Excellent cooling performance - 130 Watts
- Ultra quiet 92mm PWM fan
- 6 heatpipes and 42 fins for efficient heat dissipation
- Patented vibration absorption to eliminate buzzing sounds
- Pre-applied ARCTIC MX-2
- Easy installation
Was £21.98 Inc. VAT
Only £18.98 inc VAT.
ORDER NOW
Western Digital Caviar Black 2TB SATA 6Gb/s 64MB Cache - OEM (WD2002FAEX) @ £112.99 inc VAT
nonl2br
<center>
<div id="docview"><object classid="clsid
" quality="high" pluginspage="http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" width="728" height="90"></object></div></center>
<br>
WD Caviar Black high-performance 3.5" SATA drives combine 7200RPM spin speed, 64MB cache, SATA 6 Gb/s interface, and an integrated dual processor for lightning-fast performance in demanding desktop, workstation, and multi-drive systems. Technologically advanced acoustics minimize noise and cool drive operation and enhanced reliability features help protect the drive and the data stored on it. With a massive 2TB of storage, these drives are ideal for power computing applications such as multimedia, video and photo editing, and maxed out gaming computers. Backed by a 5-year limited warranty.
<br>
<br>
- Backwards compatible with SATA-II
<br>
- Capacity: 2TB
<br>
- Cache: 64MB
<br>
- Interface: SATA 6Gb/s
<br>
- Spin Speed: 7200RPM
<br>
- Warranty: 5 Years
<br>
<br>
Only £112.99 inc VAT.
ORDER NOW
Corsair Hydro H80 High Performance Liquid CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3) @ £79.98 inc VAT
Corsair Hydro Series liquid CPU coolers provide a compact, easy-to-install, and maintenance free alternative to bulky, noisy air coolers, efficiently cooling and protecting your high-performance Intel® or AMD® CPU. The H80 features a double-thick radiator to maximize the surface area available for heat dissipation and dual performance matched fans. It also includes push-button control so you can select the fan speed and cooling performance setup that best suits your needs.
The Corsair Hydro Series H80 high-performance CPU cooler fully supports Corsair Link Digital connections, so you can be in complete control of your cooling. Monitor a wide range of parameters, including pump speed, coolant temperature, and fan speed, and customize your own performance profiles*.
* Requires the Corsair Link Commander, sold separately
The low-profile integrated pump and cold plate includes push-button control so you can select the fan speed and cooling performance setup that best suits your needs. The cool white LED display lets you know at a glance which profile is being used.
Double-up for excellent cooling
Featuring a double-thick radiator to maximize the surface area available for heat dissipation, and dual, performance matched fans, the H80 delivers cooling performance that lets your CPU keep its cool, even when pushed to the limit. And with all this cooling performance, the compact design still fits virtually any case with a 120mm fan mount.
- Corsair Link™ Digital compatibility means that you can be in complete control of your cooling.
- Push-button fan control so you can select the fan speed and cooling performance that best suits your needs.
- Double-thick 120mm radiator for increased surface area and cooling potential.
- Two all-new 120mm fans optimize static pressure and airflow for amazing performance.
- FEP tubing provides extraordinarily low coolant evaporation levels.
- A new improved micro-channel cold-plate design more efficiently transfers heat.
- Quick and easy installation brackets make it easier than ever to upgrade to watercooling.
- Includes mounting hardware compatible with all modern CPU socket designs
- Radiator Dimensions: 120mm x 38mm
- Fan Dimensions: 120mm x 25mm
- Fan Speed: Up to 2600 RPM
- Air Flow: 46 - 92 CFM
- Fan Noise: 22 -3 9bDA
Was £84.98 Inc. VAT
ORDER NOW
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) @ £62.99 inc VAT
nonl2br
<center>
<br>
WD Caviar Black high performance 3.5" SATA hard drives combine 7200RPM spin speed, 64MB cache, SATA 6Gb/s interface with an integrated dual processor for lightning-fast performance in demanding desktop, workstation, and multi-drive systems. Rock solid mechanical architecture and enhanced reliability features help protect the drive and the data stored on it. Backed by a 5-year limited warranty.
<br>
<br>
<br>
- Capacity: 1TB
<br>
- Cache: 64MB
<br>
<br>
<br>
- Warranty: 5 Years
<br>
<br>
Was £72.98 Inc. VAT
Only £62.99 inc VAT.
ORDER NOW
Zalman VF3000-F Graphics Card Cooler (GTX570 and GTX580) @ £39.98 inc VAT
The dual 92mm fans cool not only the heatsink and VGA RAM, but all other peripheral components surrounding the VGA chipset.
- Powerful Cooling Performance
- Ultra Quiet Design
- Ultra Quiet Green LED Fans
- Adjustable fan controller
- High Performance ZM-STG2 thermal grease
- Includes VRAM Sinks
PLEASE NOTE REMOVING THE STOCK COOLER MAY INVALIDATE YOUR GRAPHICS CARD WARRANTY
Was £44.99 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST3500413AS) @ £28.99 inc VAT
Combining proven components, state-of-the-art technology and industry-leading manufacturing expertise, the Seagate Barracuda 7200.12 drive - the 12th generation of this award-winning desktop hard drive family - delivers 250GB of high-performing, eco-friendly digital storage.
- Capacity: 500GB
- Cache: 16MB
- Seek Time: 8.5ms
- Warranty: 3 Years
Was £30.98 Inc. VAT
Only £28.99 inc VAT.
ORDER NOW
Coolermaster Sentinel Advance 5600dpi Gaming Mouse with OLED display @ £39.98 inc VAT
Gaming mice are funny things, each quite subjective to the person who will eventually be using it and there can't ever be one mouse for all hands - but the Sentinel comes pretty close.
The Sentinel Advance is a rodent with a serious twin-laser setup that gives it tracking of up to 5600dpi.
The Sentinel also comes with an OLED screen, interchangeable weights underneath the chassis, a gold-plated pimpin' USB plug and some neat-looking LED lights, so you can be sure to be noticed at a LAN with this under your cheesy-snack-coated mitts.
- 5600 DPI Twin Laser Sensor
- Interchangable weights to suit each user
- Rubber Gripped for comfort
- Dynamic Surface Adaptation
- Multicolour LED lighting
- Create you own custom logo to the OLED profile management screen
- Right Handed Design
- 64k/b onboard memory
Was £46.99 Inc. VAT
ORDER NOW
Logitech G9x Laser Mouse (910-001153) @ £45.98 inc VAT
The Logitech® G9x Laser Mouse offers more customisable features than any other gaming mouse, so you can tune for the way you play. Interchangeable grips let you choose a fit and feel that’s best for your playing style (includes XL and Precision grips). The next-generation gaming laser gives you game-changing precision at any hand speed. And on-the-fly adjustable dpi from 200 to 5000 dpi. Onboard memory lets you program up to five ready-to-play profiles (for keyboard macros, dpi settings and LED colours). The weight-tuning system gives you up to 28 g of extra weight. And the custom-colour LEDs let you match your mouse to your style.
- Interchangeable grips
- Up to 5000 DPI
- Next-generation gaming laser
- Onboard memory
- Weight-tuning system
- Custom-colour LEDs
Was £49.99 Inc. VAT
Only £45.98 inc VAT.
ORDER NOW
Logitech K300 Compact Keyboard (920-001488) @ £15.98 inc VAT
Control your media and smarten up your space with the Logitech® Compact Keyboard K300. Its stylish, backlit media controls provide an elegant and easy way to access to your music, videos and e-mail, with keys that blend cleanly into the streamlined styling. The K300 features a space-saving design with full-size keys that frees up space on your desk – and makes the keyboard easy to store or take with you. A full-size, integrated number pad makes data entry fast and effortless. The ultra-flat profile helps you type comfortably with keys move quietly and feel great, shifting your wrists toward a more neutral position. Plus, setup is easy: the K300 works right out of the box, with no software to install.
- Backlit media controls
- Full-size number pad
- Space-saving design
- Ultra-flat profile
- Easy setup
Was £17.99 Inc. VAT
ORDER NOW
Philips SPA2602 5.1 Surround Sound Speaker System @ £32.99 inc VAT
Perfect for MP3, PC, TV and more.
Connect your speakers to all your gear. A great way to listen to your MP3 player, PC, TV, CD, DVD and all your multimedia stuff.
Sound
- Bass enhancement: Analogue Bass Boost, Bass reflex
- Frequency response: 35 - 20 K Hz
- Loudspeaker Enhancement: Magnetic Shielded LSB
- Music Power: 90 W
- Volume Control: Analogue Volume Control
- Wires: Fixed Wires
- Output power (RMS): 45 W
Loudspeakers
- Satellite speaker drivers: 3"
- Subwoofer driver: 4.25"
Connectivity
- Audio input for data: Stereo Audio (3.5 mm jack) 1 x
- Cable length: 1.5 m
- Connector: 3.5 mm stereo
Was £34.99 Inc. VAT
Only £32.99 inc VAT.
ORDER NOW
TT eSports Challenger Pro Gaming Keyboard @ £46.98 inc VAT
Challenger Pro Gaming Keyboard will Illuminate your world and allow you to game freely.
- Red Illumination Back Light - Red illumination back light simulates the true-to-life gaming atmosphere
- 2x USB 2.0 Ports - Provide easy usage of other USB peripherals. Each USB port supports up to 100mA
- 10 Macro Keys - Program the combined action in a button to make a move ahead ofother gamers
- 6 Multimedia Keys - Instant access to multimedia function for quick audio control
- 64KB On Board Memory - Storage of up to 40 macro keys for action, shooting, RPG and strategy games
- On Board Profile Switch - On board profile switch to engage for instant game changes
- Back Light Switch - Back light switch allows gamers to choose the different levels of lighting depending on the mood
- Fan Device - Cooling fan not only keeps your hands dry and provides comfortable gaming experience
- Windows Dummy Keycaps - Enclosed with two Windows keys to disable the function; prevent from jumping out of the game by accident
- Smart Cable Management With Detachable Cable Design - Protects cable from damage of improper use. For easy storage and cable protection
Was £51.98 Inc. VAT
Only £46.98 inc VAT.
ORDER NOW
Qpad UC Medium Cloth Gaming Surface @ £9.98 inc VAT
nonl2br
If you're looking for a mousepad that gives you total control while letting you enjoy working the mouse, choose QPAD's new uncoated surface mouse pad the latest in a wide portfolio of proven QPAD products. Our new, four-millimeter thick pad features a soft yet resistant surface designed to let you feel the mouse's movement over the pad's uncoated surface for better control. Portable and robust, you can roll it up, stick it your pocket and slap it down for the next game. A cross-weave rubber underside firmly grips the table where you place it. With its signature winged shape designed for an extra-wide sweet spot, UC is a superior quality soft pad that lets you do the work and gives you a sense of mastery.<br><br>
- Size: 35x25.5cm<br>
- Thickness: 3mm<br>
- Color: Black<br>
- Surface: Uncoated cloth surface<br><br>
<font color="red"> <font size="3"> SRP <s>£13.27</s> <b>SAVE: 3.29 </font>
Was £12.98 Inc. VAT
Only £9.98 inc VAT.
ORDER NOW
Qpad UC Large Cloth Gaming Surface @ £11.99 inc VAT
nonl2br
If you're looking for a mousepad that gives you total control while letting you enjoy working the mouse, choose QPAD's new uncoated surface mouse pad the latest in a wide portfolio of proven QPAD products. Our new, four-millimeter thick pad features a soft yet resistant surface designed to let you feel the mouse's movement over the pad's uncoated surface for better control. Portable and robust, you can roll it up, stick it your pocket and slap it down for the next game. A cross-weave rubber underside firmly grips the table where you place it. With its signature winged shape designed for an extra-wide sweet spot, UC is a superior quality soft pad that lets you do the work and gives you a sense of mastery<br><br>
- Size: 42x30.6cm<br>
- Color: Black<br>
<font color="red"> <font size="3"> SRP <s>£14.29</s> <b>SAVE: 1.80 </font>
Was £13.99 Inc. VAT
Only £11.99 inc VAT.
ORDER NOW
Speedlink Vellu Gel Mousepad - Black @ £5.99 inc VAT
The mouse pad is perfect for maintaining the wrists in a relaxed position whilst working thereby preventing excessive straining. The gel filling allows the mouse pad to mould to optimally fit any wrist thereby improving use.
- Reduces posture-related injuries
- Adapts perfectly for any wrist
- Extremely soft covering
- Mousepad with gel filling
- Enables relaxed arm posture
Was £6.98 Inc. VAT
Only £5.99 inc VAT.
ORDER NOW
Samsung SH-S222AL/BEBE 22x DVD±RW SATA Lightscribe ReWriter (Black) - OEM @ £15.98 inc VAT
Samsung's 22x Serial SATA DVD Writer supports powerful over speed performance which allows writing with the high speed of 22x on a low cost 16x media and now includes the Lightscribe Labelling function.
Write Speed
- DVD-R: 22x
- DVD-R: 22x
- DVD-R DL: 12x
- DVD+R DL: 16x
- DVD+RW: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- CD-R:48x
- CD-RW: 4x
Read Speed
- DVD-R: 16x
- DVD+R: 16x
- DVD-R DL: 12x
- DVD+R DL: 12x
- DVD-RW: 12x
- DVD+RW: 12x
- DVD-RAM: 12x
- CD-R: 40x
- CD-RW: 40x
Was £16.99 Inc. VAT
ORDER NOW
Sony BWU-500S-WW 12x BluRay-RW / 16x DVD±RW Drive - Retail @ £84.98 inc VAT
The BWU-500S-WW writes BDs at 12x and DVDs at 16x. And because it can also play 3D movies, absolutely nothing is standing between you and your future enjoyment of 3D films, TV or PC games. The complete CyberLink software suite that comes with this burner means that anyone can plug in the BWU-500S-WW and start utilizing a wide range of programs.
Key Features
- 3D Playback & SD to HD upscaling with PowerDVD 9
- Reads and records all BD/DVD/ CD formats
- Comes with Cyberlink BD Suite 8
- Seamless Link Buffer Under-run Protection
- 12cm and 8cm CD/DVD/BD media supported
Read speed:
BD 8x /DVD 16x / CD 48x max
Write speed:
BD-R 12x /DVD+R/-R 16x max
DVD+RW: 8x max DVD-RW: 6x max
DVD+R9: 8x max DVD-R DL: 8x max
DVD-RAM: 12x max
Was £89.99 Inc. VAT
Only £84.98 inc VAT.
ORDER NOW
Samsung SE-S084F/RSBS 8x Slimline External USB DVD±RW - Black @ £24.98 inc VAT
The SE-S084C is the one of the smallest drives in the world, giving power via the USB cable, this drive is truely the most portable burners available.
- DVD+R: 8x, DVD-R: 8x
- DVD+R DL: 6x, DVD-R DL: 6x
- DVD+RW: 8x, DVD-RW: 6x
- DVD-ROM Read: 24x
- CD-R Write: 24x
- CD-RW Write 4x
- CD Read: 24x
- Access time: 130ms
- Buffer Size: 2MB
Was £26.99 Inc. VAT
Only £24.98 inc VAT.
ORDER NOW
Roccat Apuri USB Hub with Mouse Bungee @ £19.98 inc VAT
The first component of the ROCCAT™ Smart Desktop Management System (SDMS) offers you the perfect combination of style and functionality right there on your desktop. The Apuri won’t just power your USB devices; among other things it’ll also bring new order to your desktop by taking control of your mouse cable.
USB PORTS ALWAYS WITHIN REACH
The Apuri combines stability and practically in the way it takes over the job of managing your devices and cables on the desktop. The Apuri’s AC adapter delivers sufficient power to supply its USB ports with up to 2A each – allowing you to connect up to four USB devices without the need for additional power supplies. And if you don’t want to use the AC adapter, you can simply power the hub using the supplied USB cable.
500mA per port is then available in passive use – perfect for cell phones, cameras and other devices which don’t require their own separate AC adapter. The Apuri allows you to connect everything so it’s within reach, saving you the hassle of crawling around under the desk looking for ports and from the untidiness of cables hanging over the edge of the desk.
SMOOTH GAMING
Thanks to the flexible mouse bungee, the mouse cable in particular is optimally catered for. It is simply guided away from the mouse’s gliding area so that it doesn’t get in the way during game play. There won’t be any rubbing on the desktop or snagging of the cable on the edge of the desk to interfere with your gaming experience – you can even adjust the length of the cable to suit, and the flexible arm optimally flexes with your movements.
You’ll feel as if you’re using a wireless mouse, without the inherent disadvantages such as increased weight, sudden need to change batteries or long charging times. If you don’t want to use the mouse bungee, it can simply be detached from the hub. .
STYLE AND ATMOSPHERE
Contrary to many conventional hubs, which live out their existence as boring boxes, the ROCCAT™ Apuri adds style to your desktop. The unique tripod design gives the Apuri stability even during tense gaming situations. The design fits perfectly with ROCCAT’s new ‘stealth’ style series. Beveled edges and futuristic lines give the hub a unique look. The top features three ice blue LEDs while the base boasts an illuminated ROCCAT logo, which will cast an atmospheric aura onto your desktop.
- 4 high-speed USB 2.0 ports
- Output power active (using AC adapter): 2A each
- Output power passive (using USB cable): 500mA each
- Length of USB cable: 1.5m
- Length of power cable: 1.5m
- Detachable Mouse bungee
- 3 LEDs (top) + underlighting
- Stable tripod design
Was £22.99 Inc. VAT
Only £19.98 inc VAT.
ORDER NOW
Lepa W-Series 500W '80 Plus' Power Supply @ £42.98 inc VAT
Designed by CWT these mid range PSU's are ideal for any gaming systems. Lepa are new to the power supply market, but the company behind Lepa are one of the best known PSU manufacturers in the world. You cannot go far wrong with any of the Lepa series PSU's.
- 80 PLUS® certified with peak 85% efficiency
- High efficiency 5Vsb circuit helps system to meet EU ErP Lot 6 2010 standby low power consumption requirements
- 12cm fan with thermal programmed speed controller providing silent cooling performance
- Active PFC universal switching circuit improves Power Factor value up to 0.99, reducing AC line reactive power loss to minimum level and automatically adopting AC voltage from 100~240V
- 8P PCI-E connector supplied supporting extreme graphic cards
- Protected by Over Power, Over Voltage, Over Current, Short-Circuit, and Brown Out protections circuits
- CPU 12V connector rail with >18A output to support next generation >6 cores processor structure
- Extended CPU connector cable to 60cm facilitates installation with bottom-mounted-PSU chassis
- SATA power connector with 3.3V rail to support new generation SSD
- 3 year warranty
Was £46.99 Inc. VAT
Only £42.98 inc VAT.
ORDER NOW
