Screen Stutter and Sound
Basically I put together a new system yesterday. All went well, as aposed to a previous system I built which had a D.O.A psu and HD. I thought it was all running sweet until I started gaming later on.
After around 20-30 minutes of playing League of Legends or World of Warcraft or Call of Duty 4 or Brink (so basically any game) my game will start to lag and stutter, the sound will also stutter to. On my voice comms people talking will also cut out and repeat. I move forward on the game and I don't see the movement but after 1-2 seconds I appear where I wanted to move to. With the sound the game sound also stutter i.e. League of Legends normally would say "You have killed an enemy" but when I'm stuttering becomes "You ou ou have killed an an enemy my my" or to that effect.
This is really confusing me because I'm running core temp and it shows temps @ around 60 on the cpu. My gpu around 50-60. I have a gadget on my windows 7 which displays the cores of my Cpu and their activity and usage. I notice on this gadget that maybe 1 of my core peaks at around 80-90% usage (usually the second core) but then it drops back down to the average 50-60% usage like the other cores. I also have a memory gadget which shows the usuage of the memory and that stays normal, doesnt really move from around 30-40% usuage or a little more depending on game. The last gadget is the GPU one and that displays a normal usage of the GPU, a good average temp and no spiked usage. I also have Hard Disk Sentinal because I thought the HD was quite loud but after research found out the HD is actually loud. The Hard Disk Sentinal shows the HD is perfect.
The system is;
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
Asus P8P67 LE Intel P67 (Socket 1155) DDR3 Motherboard B3 Revision
Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
MSI GeForce GTX 460 HAWK "Super-OC" 1024MB GDDR5 PCI-Express Graphics Card
Western Digital Caviar Black 750GB SATA 6Gb/s 64MB Cache
Corsair Enthusiast Series TX 650W V2 High Performance '80 Plus Bronze' Power Supply
Im running windows 7 x64 aswell.
Anyone know of this issue or anything similar? Any help is appriciated
*Edit*
I've flashed and updated my Bios. I updated the onboard Audio drivers and updated to the latest nvidea drivers when I first had the issue.
*Edit* I have now also disabled the onboard sound and put in my Sound Blaster sound card. When the stutter/lag happens now the sound remains fine, doesnt break up like it did before. But the lag/stuttering is still happening.
*Edit* When this happens I notice that the cpu has picked up to 80degrees and that 1 of the cores will go to around 80% usuage while the others remain low, this usuage usually swaps between core 1 and core 2.
Is 80 degrees going to cause this? if so should i get a new heat sync? the case im using is a Coolermaster Silencio
The system is;
*Edit*
