Grab a deal and save some cash with today's "Today Only's" Reduced prices on two items which will improve your gaming quality and experience.
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM @ £155.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Unlocked Multiplier
- Lithography Process: 32 nm
- Cores: 4
- Threads: 4
- Frequency: 3.30 GHz (Turbo Mode 3.70GHz)
- Integrated HD 3000 (12 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1100MHz Turbo)
- Cache: 6 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 95W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 1yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.35-1.38v core voltage, doing so could limit lifespan of the CPU
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Only £155.99 inc VAT.
ORDER NOW
MSI GeForce GTX 460 HAWK "Super-OC" 1024MB GDDR5 PCI-Express Graphics Card @ £125.99 inc VAT
Key Features<
Triple Over-Voltage Adjustment
The MSI N460GTX Hawk is the world's first graphics card to support voltage adjustment of the GPU, Memory and PLL making speeds, previously though of as impossible, easy to reach!
Twin Frozr II Thermal Design 18 Degrees Celsuis Cooler and 8.1 dB Quieter!!
- Dual 8CM PWM Fans : Air flow from dual fans can cool down GPU/Memory/Power Module at once.
- Four heat pipes with SuperPipe Technology
- Nickel-plated Copper Base : Large size of Copper Base can dissipate the heat of GPU faster.
7+1 Phase PWM Design
- Higher current to GPU Powerv
- Higher overclocking capability
- Better stability in peak load
Military Class Components
- Hi-C Cap provides more precise GPU voltage.
- SFC (Super Ferrite Choke) : 30% Higher Current Capacity, 10% Power Efficiency Improvement.
- All Solid CAP for longer lifespan.
APS (Active Phase Switching) & V-Check Points
- APS (Active Phase Switch) helps save power usage by controlling PWM automatically.
- V-Check Points allow users to read voltage directly by multi-meter.
Specifications
- Core Speed: 780MHz (Beyond 1000MHz possible but not guaranteed)
- Memory Speed: 1024MB GDDR5 3600MHz
- Shader Speed: 1560MHz (Upto 2000MHz possible but not guaranteed)
- Memory Type: GDDR5
- Memory Size(MB): 1024
- Memory Interface: 256 bits
- The world’s first graphics card supports voltage adjustment of GPU, Memory, and PLL.
- 7+1 Phase PWM design provides extra 30A current output power to GPU for better overclocking power capability.
- SSC (Solid State Chock) has No Buzz noise and higher current for better overclocking ability.
- Reduces power consumption by switching of power phases dynamically when not in use (active phase switching)
- Support Over Voltage function of GPU, PLL and Memory
- Support advanced fan speed control.
- Support burn-in stability test.
- Support PhysX technology effects for realist physics effect.
- Support 3DVision Surround technology to provide 3 monitor output simultaneously and real 3D image experience
Only £125.99 inc VAT.
ORDER NOW
- Cores: 4
- Threads: 4
- TDP: 95W
- Socket: LGA1155
- 1yr Warranty
ORDER NOW
Key Features<
Specifications
ORDER NOW
