** CRAZY WEEKEND ONLY DEALS - CPU's, RAM, GFX, SSD, HDD, LAPTOPS ALL INSIDE! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Right here is a handfull of truly cracking deals where were most likely the cheapest in the UK by considerable amounts. :D
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £227.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Lithography Process: 32 nm
- Cores: 4
- Threads: 8
- Frequency: 3.40 GHz (Turbo Mode 3.80GHz)
- Integrated HD 3000 (12 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1350MHz Turbo)
- Cache: 8 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 95W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 3yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.35-1.38v core voltage, doing so could limit lifespan of the CPU
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Was [£239.99] Inc. VAT
Only £227.99 inc VAT.
ORDER NOW
AMD Athlon II X2 Dual Core 255 3.10GHz (Socket AM3) - Retail @ £43.99 inc VAT
AMD Athlon II Dual-Core processors put the power of dual-core technology on the desktop. Dual-core processors contain two processing cores, residing on one chip, that perform calculations on two streams of data to increase efficiency and speed while running multiple programs and the new generation of multi-threaded software. AMD Athlon II Dual-Core processors deliver TRUE multi-tasking, allowing users to switch from one program to another without always pausing for the computer to catch up and reducing annoying processing pauses.
- Dual-core Technology
- 3.10Ghz clock speed (AM3 Socket)
- 2.0MB L2 Cache
- Cool & Quiet Technology for Energy Efficiency
- Enhanced Virus Protection
- 64-bit Technology
- Hyper Transport Technology
- Virtualization technology
- 3yr Warranty
- Retail Boxed with Heatsink & Fan
Was [£47.99] Inc. VAT
Only £43.99 inc VAT.
ORDER NOW
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) @ £44.99 inc VAT
Kingston's KHX1600C9D3X2K2/8GX is a kit of two 512M x 64-bit 4GB DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 8GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
Model Name: KHX1600C9D3X2K2/8GX
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
CAS Latency: 9-9-9-27 2N
Capacity: 8GB (4GBx2)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.50-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Was [£59.99] Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel Kit (OCZ3G1333LV4GK) @ £21.98 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the upcoming Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements at 1333MHz.
Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for the midrange desktops.
OCZ DDR3 PC3-10666 Gold Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1333MHz DDR3
- CL 9-9-9-20 (CAS-TRCD-TRP-TRAS)
- Gold Z3 XTC Heatspreader**
- Lifetime Warranty
- 1.55-1.65 Volts
- 240 Pin DIMM
Was [£24.99] Inc. VAT
Only £21.98 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6950 "Dual Fan Edition" 2048MB GDDR5 PCI-Express Graphics Card with FREE DIRT3 Game @ £199.99 inc VAT
The SAPPHIRE HD 6950 Dirt3 Special Edition is a new SAPPHIRE original model with a special cooler using a new dual fan configuration. Based on the latest high end AMD GPU architecture, it boasts true DX 11 capability and the powerful configuration of 1408 stream processors and 88 texture processing units. With its clock speed of 800MHz for the core and 2GB of the latest GDDR5 memory running at 1250Mhz (5 Gb/sec effective), this model speeds through even the most demanding applications for a smooth and detail packed experience.
A Dual BIOS feature allows enthusiasts to experiment with alternative BIOS settings and performance can be further enhanced with the SAPPHIRE overclocking tool, TriXX, available as a free download from http://www.sapphiretech.com/ssc/TriXX/
Features:-
- Core Clock: 800MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required (Power Adapters Provided)
- 450W minimum PSU recommended
- Warranty: 2 Years
- Supplied with Mini-DisplayPort too HDMI Cable
- Supplied with 1.8M HDMI High Speed Extension Cable
- Supplied with Dirt3 PC Game (Subject to availability)
Was [£229.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
Asus GeForce GTX 460 1024MB DirectCU GDDR5 PCI-Express Graphics Card @ £107.99 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Exclusive Voltage Tweak Technology
- Uprated DirectCU Cooling solution
- Core Clock: 675MHz
- Memory: 1024MB GDDR5
- Memory Clock: 3600MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 336
- Shader Clock: 1350MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
Was [£129.99] Inc. VAT
Only £107.99 inc VAT.
ORDER NOW
OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-60G) @ £79.99 inc VAT
As the third generation of the Agility Series, OCZ Agility 3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Agility 3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Agility 3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Agility 3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
- Capacity: 60GB
- Controller: SandForce SF-2281
- Maximum Read: 525MB/sec
- Maximum Write: 475MB/sec
- Max I/O Per Second (IOPS): 50,000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Was [£89.99] Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Western Digital Caviar Green 2TB SATA-II 64MB Cache - OEM (WD20EARS) @ £56.99 inc VAT
WD Caviar Green SATA hard drives reduce power consumption by up to 40% and offer best-in-class acoustics and operating temperature. Based on WD's exclusive GreenPower technology, these drives are designed to deliver power savings as the primary attribute. As hard drive capacities increase, the power required to run those drives increases as well. WD Caviar Green drives make it possible for energy-conscious customers to build systems with higher capacities and the right balance of system performance, ensured reliability, and energy conservation. They are ideal for PCs, external storage and other devices that require lower power consumption and cool, quiet operation.
- Capacity: 2TB
- Cache: 64MB
- Spin Speed: IntelliPower
- Warranty: 3 Years
Only £56.99 inc VAT.
ORDER NOW
Dell UltraSharp U2711 27" Widescreen LCD Monitor - Midnight Grey **1yr Warranty** @ £499.99 inc VAT
With its amazing colour accuracy and versatile connectivity, the high-performance Dell U2711 Monitor delivers stunning detail, depth and responsiveness. PremierColour technology allows the Dell U2711 Monitor to deliver reliable, true-to-life colour without the need for extensive calibration. 12-bit internal processing enables 1.07 billon colours and helps distinguish very low grayscale tones to deliver greater level of details in dark areas. Factory-tuned Adobe RGB and sRGB modes minimize the need for further colour calibration; each monitor arrives with a certified colour-calibration factory report. 100% sRGB and 96% AdobeRGB meets the needs of professional users involved in colour-centric work such as graphic design, CAD/CAM, gaming and media creation.Customize your viewing experience with the height-adjustable stand and tilt/swivel features - or save valuable desktop space by detaching the panel from the stand for wall mounting.
- Height Adjustable
- Swivel & Tilt Stand
- Screen Size: 27" IPS Widescreen
- Resolution: 2560x1440
- Contrast Ratio: 80000:1
- Brightness: 350cd/m²
- Response Time: 6ms
- Viewing Angles (H/V): 178°/178°
- Colours: 1.07 Billion
- Inputs: 1x Analogue, 2x DVI-D, 1x HDMI, 1x DisplayPort, 1x Composite & 1x Component
- 4-Port USB Hub
- 8-in-1 Card Reader
- VESA Compliant
- Dimensions: 646.71mm x 427.83mm x 199.95mm
- Weight: 7.72kg
- Warranty: 1 Year Return to base
Was [£649.99] Inc. VAT
Only £499.99 inc VAT.
ORDER NOW
BenQ G2222HDL 21.5" Widescreen LED Monitor - Black @ £104.99 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2222HDL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 504.6mm x 392.9mm x 175.0mm
- Weight: 3.8kg
- Warranty: 2 Years On-Site
Was [£109.99] Inc. VAT
Only £104.99 inc VAT.
ORDER NOW
MSI GX660R 15.6" WLED TFT Intel I7-740QM, 6GB DDR3, 1TB HDD, ATI HD 5870 1GB GDDR5 Graphics, Win7 Home Premium 64-Bit - Black/Red @ £977.99 inc VAT
nonl2br
<img src="http://www.msimobile.com/img-overview/GX660/Topbanner.jpg" height="480" width="768" alt="GX660" /><br>
<br>
<Br>
<font size="4"><b>Key Features</b></font><br>
<br>
<b>• The latest Intel Quad Core i7-740QM 1.73GHz Processor</b><br>
• Genuine Windows 7 Home Premium<br>
• DTS Surround Sensation UltraPC<br>
• Exclusive TDE Technology<br>
• 16:9 Full HD LED Display<br>
• High-end ATi Radeon HD 5870M graphics<br>
• HDMI (High-Definition Multimedia Interface) Output<br>
• Built-in HD Webcam<br>
• 802.11 b/g/ n Wireless LAN with Bluetooth<br>
<br>
<br>
<font size="4"><font color="Blue"><b>New Level of Sound and Performance</b></font></font><br>
<font size="4"><b>MSI + Dynaudio = New Standard of Gaming Notebook</b></font><br>
<br>
<b>Dynaudio Premium Sound Technology</b><br>
<br>
The complex and interconnected elements that comprise excellent sound were painstakingly identified one by one to ascertain how to systematically develop the proper notebook technologies. After undergoing a very long process of cooperative development, Dynaudio and MSI have come up with the GX660. The four directions used to develop Dynaudio Premium Sound Technology are summarized below. For serious gamers who demand extreme audio performance, the GX660 is the best and only choice!<br>
<br>
<img src="http://www.msimobile.com/img-overview/GX660/speaker-1.jpg" align="centre" alt="GX660" /><br>
<br>
<b>Speaker Placement</b><br>
<br>
In the past, limited space on notebooks meant speaker position was always considered last, which resulted in muddled sound in notebook speakers. Because of this, speaker position was considered during the initial stages of the GX660's development to facilitate optimum audio performance and to avoid sacrificing audio quality for incorrect speaker placement.<br>
<br>
<b>EQ Tuning: Adjusted for Optimization of All Types of Sounds</b><br>
<br>
Different types of music represent distinct requirements for sound ambience. Jazz, pop, rock, or classical all possess special characteristics that affect computer game and movie sound performance and each has specific tone balance requirements. To express different types of music authentically, Dynaudio and MSI spent over 1,200 hours of continuous, repetitive testing and fine tuning of high, mid, and low range frequencies so authentic reproduction of different types of music can be achieved.<br>
<br>
<br>
<img src="http://www.msimobile.com/img-overview/GX660/inteli7" align="right" alt="" />
<font size="4"><font color="Blue"><b>Choose The Best!</b></font></font><br>
<br>
<b>Powerful Hardware Under the Hood Deliver Enhanced Horsepower and Blazing Speed</b><br>
The GX660 includes the world’s most advanced Intel® Core™ i7 quad core processor, which boasts superior multimedia performance and can retrieve data from Blu-ray disks or update online photo albums twice as fast as conventional dual core notebooks. The processor also comes with Intel’s Turbo Boost technology, allowing you to power up or down as necessary, depending on the load requirements of the task at hand.<br>
<br>
<br><img src="http://www.msimobile.com/img-overview/GX660/turbo.jpg" align="left" height="300" width="373" alt="GX660" /><br>
<br>
<br>
<b>Accelerated CPU Performance MSI’s Exclusive TDE Technology</b><br>
<br>
By overclocking the CPU and memory frequency, the TDE Technology brings more calculating speed to enhance the system performance. It benefits the video decoding/ encoding, gaming and art work designing. With MSI TDE Technology, you can experience fast-response time and efficient real-time data processing.<br>
<br>
<br>
<b>Exclusive Cooler Boost Technology</b><br>
Only one finger!! Exclusive Cooler Boost technology provides powerful cooling capabilities and receives real-time notification of the GX660's core temperature variations and fan speed.<br>
<br>
<br>
<br>
<br>
<br>
<font size="4"><font color="Blue"><b>Marvel At The Most Amazing Images Around</b></font></font><br>
<b>The ATI Radeon™ HD 5870 Graphics (with GDDR5 1GB VRAM)</b><br>
<img src="http://eu.msi.com/uploads/Image/product_img/other/nb/gx660/gx660_05.jpg" align="centre" alt="GX660" /><br>
The 1GB GDDR5 internal memory and the ATi Radeon™ HD 5870 graphics card provide a high-definition gaming experience that puts you right in the middle of the action sequences. Delivering full support for Microsoft DirectX® 11, the GPU enables richer and true-to-life graphics performance so that you can enjoy immersive games or movies.<br>
<br>
<b>16:9 Full HD* LED Backlit Display</b><br>
<img src="http://eu.msi.com/uploads/Image/product_img/other/nb/gt660/gx660_hd.jpg" align="centre" alt="GX660"/><br>
The 15.6” Full HD screen of the GX660 delivers more details of the high definition content; brings you more pleasure while playing games or watching movies.<br>
<br>
<font size="4"><b>Specifications</b></font><br>
<br>
<b>CPU</b> Intel Core™ i7-740QM 1.73GHz Processor <br>
<b>OS</b> Genuine Windows 7 Home Premium <br>
<b>Chipset</b> Intel PM55 <br>
<b>Memory</b> 6GB DDR3 1066 MHz<br>
<b>LCD Size</b> 15.6" FHD 1920*1080 TFT-LCD Display (LED Backlight) <br>
<b>Graphics</b> ATi Mobility Radeon HD 5870M <br>
<b>Graphics</b> VRAM GDDR5 1GB <br>
<b>HDD</b> 2x500GB in RAID 0 SATA <br>
<b>Optical Drive</b> Super-Multi DVDRW<br>
<b>Audio</b> 2 Theater Class Speakers +1 Subwoofer <br>
<br>
- HD Webcam <br>
- Card Reader XD/SD/MMC/MS <br>
- LAN 10/100/1000 <br>
- Wireless LAN 802.11 b/g/n <br>
- Bluetooth V2.0EDR <br>
- D-Sub (VGA)<br>
- HDMI<br>
- 2x USB 2.0 port <br>
- 2x USB 3.0 port <br>
- eSATA <br>
- 120W AC Adapter<br>
- 9 cell Battery<br>
Was [£1039.00] Inc. VAT
Only £977.99 inc VAT.
ORDER NOW
Corsair Gaming Audio Series HS1 USB Gaming Headset @ £51.98 inc VAT
nonl2br
The Gaming Audio Series HS1 USB Gaming Headset is designed for gamers who are serious about audio. Massive 50mm drivers deliver serious gaming punch, without sacrificing the sparkling sound quality you need to enjoy music and movies. Dolby Headphone surround sound gives you a competitive edge, and the noise-cancelling microphone ensures that your teammates and opponents hear you loud and clear. Extra-large earcups and fabric covered memory foam earpads provide a firm fit and excellent noise isolation without binding or pinching, so you’ll keep your cool and keep your head in the game for hours of playtime. The extra-large inline volume and microphone controller is easy to grab when things get fast, and the HS1 is designed and crafted with high-quality materials for years of use.
<br><br>
<object width="640" height="360"><param name="movie" value="http://www.youtube.com/v/A_ZvxB0aaPE?fs=1&amp;hl=en_GB&amp;rel=0&amp;hd=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/A_ZvxB0aaPE?fs=1&amp;hl=en_GB&amp;rel=0&amp;hd=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
<br><br>
- Massive 50mm drivers for high-quality audio reproduction<br>
- Frequency response tuned to deliver serious gaming punch without sacrificing audio quality for music and movies<br>
- Circumaural, closed-back earcups for superior noise isolation<br>
- Replaceable memory foam earpads with fabric covers for a firm fit without binding or pinching<br>
Was [£69.99] Inc. VAT
Only £51.98 inc VAT.
ORDER NOW
Logitech G19 Gaming Keyboard (920-000978) @ £99.98 inc VAT
When you’re gearing up for battle, you never compromise. Not on your team, not on your weapons, and certainly not on your hardware. If you take your gameplay seriously, you want the Logitech® G19 on your side.
- Tiltable, colour GamePanel™ LCD: The (320x240) display shows unprecedented levels of information, both in and out-of-game, including game stats, system information, VOIP communication data, video playback, image slideshows, and many other items.
- User-selectable backlit characters: Personalize the keyboard to better fit with the rest of your computer and gaming equipment, and easily locate keys - even in the dark.
- Twelve fully programmable G-keys with three macros per key: Program up to 36 single keypresses or complex macros; use the MR key to record new macros on-the-fly.
- Multi-key input: Use up to five keys at once to perform multiple complex actions.
- Game/desktop mode: Disable the Windows/Context Menu keys so they won’t interrupt your game if pressed accidentally.
- Two powered Hi-Speed USB 2.0 ports: Transfer data to and from peripherals, such as MP3 players and flash drives - while also charging battery-powered devices.
- Intelligent cable management: Keep mouse, headset, and other cords out of the way by routing them through channels on the underside of the keyboard.
- Instant media access: Use the convenient one-touch controls for volume and media playback.
Only £99.98 inc VAT.
ORDER NOW
Logitech X-540 5.1 Speaker System (970223-0120) @ £59.99 inc VAT
Introducing the powerful Logitech X540 5.1 Speaker System. Strengthen your gaming with a harmonized soundfield that surrounds you. Get full, lush audio even from 2-channel sources for a 5.1 surround sound experience
The Logitech X-540 5.1 Surround Sound Speakers allows you to engross yourself in games and movies with a full 360° of audio. The Logitech X540 includes Matrix Modes which allows you to enjoy a 5.1 surround sound effect from 2-channel stereo source.
Frequency directed dual drivers provide a balanced, uniform sound without inconsistent even spots. Logitech have included real-time bass equalization in the Logitech X540 which maximizes bass response and minimize distortion.
Making life easier:
- The Logitech X540 speakers, mount directly onto most flat-panel displays with it Center channel LCD clip Just rotate the stands to switch from desktop to wall.
- Easily access power, volume, bass, Matrix Mode and your headphone jack on the convenient control pod which comes with the Logitech X540 speakers
- Enjoy your music, movies and games privately with the integrated
- Set up is easy just Plug and Play as the Logitech X-540 speaker system easily connect to PCs, CD and MP3 players.
- Total 70W RMS
Only £59.99 inc VAT.
ORDER NOW
Antec TruePower New Modular 650W '80 Plus Bronze' Power Supply @ £67.98 inc VAT
New features. Same true power. The TruePower New series by Antec offers users an advanced power supply solution, striking the perfect balance of reliability, efficiency and quality. With DC to DC voltage regulator modules, a 120mm PWM fan, and 80 PLUS® Bronze certification, TP-650 is the ideal solution for elite system builders and quality-minded enthusiasts alike.
- NVIDIA™ SLI™ - ready certified
- 80PLUS® Bronze Certified saves energy and lowers your electric bill
- DC to DC voltage regulator modules for greater system stability
- 120mm PWM fan runs up to 50% quieter than standard fans
- Advanced Hybrid Cable Management improves airflow and reduces clutter
- Double layer PCB optimizes cooling efficiency and allows for heavy duty components
- Universal Input and Active Power Factor Correction
- Supports dual GPUs and dual/quad core CPUs
- 4 +12V output circuits provide stable power
- ATX12V v2.3 and EPS12V v2.91
- 1 x 6 pin and 1 x 8 (6+2) pin PCI-E graphics card connectors for TP-550
- 2 x 6 pin and 2 x 8 (6+2) pin PCI-E graphics card connectors for TP-650, TP-750 and - Industrial grade protection
- Safety approval: UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick, BSMI
- Dimensions: 86mm (H) x 150mm (W) x 150mm (D)
Was [£79.99] Inc. VAT
Only £67.98 inc VAT.
ORDER NOW
Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp - OEM @ £20.99 inc VAT
The Xonar DG sound card combines Dolby Headphone 5.1 high definition surround with Asus’ own GX 2.5 gaming audio engine and an on-board headset amplifier. These result in accurate and deep audio that brings every nuance and sound across fully, making the new Xonar DG an ideal sound card for gamers who want to remain totally aware of their play environments.
- Built-in Headphone AMP
- Powers up every sound detail in gaming
- 3 gain modes for different usage scenarios
- Dolby Headphone for an immersive 5.1 surround imaging
- GX2.5 for realistic 3D audio effects
**Supplied with Driver disk, Manual, Low profile PCI bracket and Xonar DG card - All thats missing is the box!**
Only £20.99 inc VAT.
ORDER NOW
